Question about EliteGroup ECS P4M800-M Socket 478/P4M800/FSB800/A&V&L/M-ATX Motherboard (MOTEC18)
Is motherboard dead?
This is only a quicktest to see if the motherboard is no longer working.
I am using a mother board model of ECS P4KM800-m7. It only serve me for almost a year only, then it crashes.
If I remove all the peripherals including the add on cards and the memory(RAM) and the processor (INTEL P4 1.45Ghz), and what is left connected to the motherboard is the monitor connected to the onboard graphics, would it display anything or none at all? Or will it sound or beep, if there is nothing connected in it?
My test results were it doesnt show anything on the screen and no beeping sound. Is this mean motherboard is no longer working.
Hoping for your advice. thank you.
  • Reynante Manriquez
    Reynante Manriquez Dec 17, 2007
    i have already find the solution and it is only due to the POWER SUPPLY, I cant beleive it.
    On my previous troubleshooting, I have already check the possibility of power supply failure, by checking the voltage level of each pins corresponding to its color coding. All level was fine at that time. I cant believe that it is not enough just to check the level of voltage..
    This weekend, I visit my friend who is also a computer whiz and tried to do the final test and I supposed is the most effective of all troubleshooting. He has a computer working, and all I have done was to put the suspected devices such as processor, add on cards and memory to the working one. But, unluckily he was unable to tell me that we havent have both processor chipset for the motherboard.
    Thank GOD I also bought my POWER SUPPLY because I also suspect that it may have somehow fail, even though I tested it.
    EUREKA!! when i connected it to his PC, the same problem occur, so that concludes that the power supply is not working anymore.
  • 95 Answers
Either motherboard, ram module or if no power at all sounds more like a power supply. If the computer has on board video you will need the ram to get any video. But with it removed the board should still beep if the case speaker is connected to the board. Have seen a lot of these less expensive motherboards fail. If there is no power up at all or lights coming on on the case I would think it is a power supply problem. Happens all the time and quite easy to repair. Just put on a new power supply.
Posted on Dec 12, 2007
Biostar g41 m7 wont power up after installing cpu
have you an ATX/BTX PSU?
with 24pins ATX + 4pins P4 connector?
if you haven't that it's normal that's don't work
else your PSU 5Vsb or/and your motherboard are dead
Nov 19, 2012 | Biostar G41-M7 Motherboard - Socket 775,...
I dont have a software for my on board video card, can you please send me?
You can download the latest drivers from the ECS website. They have two versions of the board listed: P4M800-M7 (V1.0) and P4M800-M7 (V3.1). Click on the link for the one you have (the version is marked on the board) and you can download what you need.
Thanks for using Fixya! If this has helped you, please take a moment to give a thoughtful rating.
Oct 22, 2010 | EliteGroup ECS P4M800-M7...
Does a core 2 duo processor work on an ecs 661FX-M7 motherboard?
Your motherboard was set up for a pentium 4 or celeron d only and neither are dual cores, So the short answer is no,'
But there are many 3+ ghz celeron d's that are less then 50 online
Oct 06, 2010 | EliteGroup ECS 661FX-M7 SiS 661FX Chipset...
ECS MOTHERBOARD NO BOOTING UP
They must have correct ram installed.
Hard to believe all 10 are faulty.....sounds like a ram fault.
Could also be wrong / faulty CPU
Apr 12, 2010 | EliteGroup ECS P4M800-M7(3.1) LGA775 ALL...
Usb not recognised motherboard G31T-M7
You have got an unnessacerily usb for your required mother board system.
Nov 28, 2009 | EliteGroup ECS G31T-M Motherboard - Quad...
Sound driver
Your motherboard is a BIOSTAR right ?
Ok there are 2 versions I will post the drivers for those 2 versions.
P4M800-M7A v1.0
http://www.biostar-usa.com/app/en%2Dus/mb/driver.php?S_ID=92
These are the complete drivers, the sound driver is there too under onboard audio.
P4M800-M7A v7.0
http://www.biostar-usa.com/app/en%2Dus/mb/driver.php?S_ID=93
From what I can see they both use the same drivers.
I hope this helps.
The elitegroup website has a similar name but no A at the end
P4M800-M7
http://www.ecs.com.tw/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=531&DetailName=Driver&DetailDesc=&CategoryID=1&MenuID=6&LanID=0
So from your model I would say it is a biostar, get it from the links above, if it is an elitegroup (ECS) get it from the last link.
Sep 06, 2009 | EliteGroup P4M800-M7 Motherboard
Im looking for all drivers for mercury kobian 740 ecs?
here it is...
http://www.ecs.com.tw/ECSWebSite/Downloads/Category_Download.aspx?MenuID=6&LanID=0
select motherboard in the 1st drop down
select lga 775 in the next drop down
select 661fx-m7
select ver number in the next drop down
click submit
and there we go
please rate the service you have recieved
Apr 24, 2009 | EliteGroup ECS 661FX-M7 SiS 661FX Chipset...
P4M800-M7 no sound
Here is the link :
http://www.biostar.com.tw/app/en-us/mb/driver.php?S_ID=91
Select the one that says "On board Audio". There are two options: one for WIN Vista and the other for Win XP/2000, etc
Cheers,
Lolita
Apr 09, 2008 | EliteGroup P4M800-M7 Motherboard
Motherboard User Manual - Can not find one
When you bought the mother board, the manual should be at the bottom of thte box. Unfortunately, the company who made that motherboard no longer supports it, or lists it in the archives. You may look more here: http://www.ecsusa.com/ECSWebSite/Index.aspx?MenuID=0&LanID=9. This is the ECS website.
Feb 10, 2008 | Computers & Internet
EliteGroup ECS P4M800-M Socket 478/P4M800/FSB800/A&V&L/M-ATX Motherboard (MOTEC18) Logo
104 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Computer Links
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
