Question about Brother MFC-8500 All-In-One Laser Printer
Won't scan I put paper in machine, push scan button. Window says "connecting to pc", but then nothing else happens. I checked the cable and also under "my computer" it says it is connected. The software looks like it is installed too. It was working before for a long time.
  • Gejen Mar 15, 2008
    I am having the exact same problem with my Brother MFC-8500. Help!
Hi there, this problem was posted over a year ago so I boubt you will check this but the best help I ever get is from discussion boards so I think its time to return the favor. I spent 3 hours on this one and finaly figured it out. After following all the steps on solutions.brother.com you need to fully uninstall all brother drivers and reinstall the correct drivers based specifically on your model. In this case mfc 8500. I did this and even went as far as downloading (from above website) the official uninstall tool. I then tried it again and still my driver install would bug at the "click next when connected" But when i connect my printer it doenst let me click next.
Anyways for me the answer to my problem lay in the simple answer of the usb cable i was using. I had a labtop connected to a USB connector conected to a paralell port adapter connected to the printer. I had a theory that the parallel port and usb werent communicating. Keep in mind that the before all this the printer worked fine but the scanner and email fax did not. I then diconected the paralell port from the printer and found a usb entry (weird shape not sure of the term) at the back of the printer. Looked through my cables and sure enough had the usb/weird shape usb cable. Once i connected that to the labtop like a flash everything worked. This was grueling but i hate to admit defeat to computer problems. if you read this..i hope it helps.
Get official uninstall
decompress and use it.
restart. (will not work if you dont)
Get updated driver and software package
Only Connect Usb to labtop now
Only now Turn printer/plug in printer now
Complete instalation
DONE!
Posted on Feb 06, 2010
I have the same problem with my Brother 240C. Did you guys find a solution?!
Posted on Jun 03, 2008
I have the same problem. Just spent 2 days on phone with Brother techies who can't solve problem. All they want to do is load and unload the MFC program over and over.
Posted on May 15, 2008
Power window goes up but not down
That tells me the switch is faulty. The switch uses the same power and ground wires in, and reverses the connection out depending on which way the switch is pushed.
Sep 23, 2012 | Cars & Trucks
HP Deskjet f4435 will print, but won't scan. Orange light blinks
When I press the scanner button the top power button starts blinking but the machine does not scan. I have not used the scanning function on this machine before. Please help...you may need to reinstall your ..
Aug 16, 2011 | HP DeskJet F380 All-In-One Printer
I put in the paper push scan push start and it just says sleep nothing happens
you need to have mfc connected to computer with scan software running in order to scan, if you want to copy you just press copy and it will scan and print without computer connected.
Oct 29, 2009 | Brother MFC-5840CN All-In-One InkJet...
My dell photo 942 won't scan
I would try deleting the scanner driver and software and reinstall. then plug the usb cable from the printer to the pc.
Jul 31, 2009 | Dell 924 All-in-One InkJet Printer
Printer x6570 won`t print photos and data, or scan...
try uninstall the driver and insatll it after that reboot and connect printer!
Jun 05, 2009 | Lexmark X6570 InkJet Printer
Lexmark C1150 printer doesn't print
First I try to uninstall the printer, it didn't work, so I reinstall the the printer anyway, it worked for one print only.
As second attempt I disconnected the printer completely, turned the PC off, and after few minutes on again. Uninstalled printer.
Reconnected the cables again, install the printer - it works well!
Dec 05, 2008 | Lexmark X1150 All-In-One InkJet Printer
It says that it is not connected. It doesn't turn on anymore. Nothing happens when I push on the power button.
Have a thorough virus scan of ur HDD. if it is OK, then the culprit is the connection. Check the cable and re-setup the connection process/procedure.also try to have an external MODEM or separate LAN card (whatever, with which u connect to the internet). Lastly I recommend u atleast 1GB of RAM.
Oct 11, 2008 | Computers & Internet
Brother MFC-640CW All-In-One InkJet Printer Scanning Issue
The first thing to do would be to download and reinstall scanning software and drivers on pc, something there is missing / changed I would guess.
Nov 03, 2007 | Brother MFC-640CW All-In-One InkJet...
Brother MFC-8500 All-In-One Laser Printer Logo
161 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
