Question about RCA L32W11 32 in. HD-Ready LCD Television
Please help me
I bought a used rca l32wd12 32in lcd flatscreen and when i pressed the channel buttons before it went to cable,comp 1,dvd etc... i dont have a remote i was messing with the menu and now i cant get to any channel at all just 14 blank tried auto search tryied everything i could but still no can i reset the tv or fix this problem without the remote????
  • ra64 Feb 01, 2009
    my rca is **** too. My screen goes black. then you shut it off then turn it back on and it works again for two sec. do this for about 15 mins. an then i can watch tv. Ill never buy an rca product again!
  • Anonymous Mar 29, 2014
    cant get picture have tried various channels etc to no avail
I bought one too! It failed in 6mos. I sent the $ and returned the bad one for another of the same "no choice". Now they suddenly "lost" my replacement. Fix that, haha. Do you have a fax# for RCA?
Please help me.
Posted on Nov 18, 2008
The player does play the dvd's and everything but the picture wont show up in my television. I already connected the RCA connectors into the television and the player but still no picture. Please Help.
Assuming you used the standard YELLOW-WHITE-RED RCA cable, between the unit and the TV, the colours of each of the plugs should match both the outputs on the rear of the unit and the respective inputs at the rear of the TV. The TV must also be on an AV input 'channel' to receive the connected unit. (for example, AV1 or VIDEO 1)
Try changing the RCA cables - just in case the ones you currently have are defective in some way.
Being a combo unit, there should be a DVD-VCR common output on the rear - using RCA cable, the YELLOW is video, the WHITE is left channel, the RED is right - these MUST match the input on the TV, and the TV AV input must be selected in order to view the pictures and audio from the unit. To enjoy both VCR and DVD, using the RCA connection, the common output on the rear of the combo unit is recommended.
Better quality video is possible using S-Video cable (available from electronics stores such as Radio Shack etc. but this does not provide audio; you would still require RCA RED-WHITE cable for that, and your TV may not have S-Video input). Your TV may have a TV/AV button on the front - select the correct AV 'channel' with that if necessary.
It makes sense to check everything twice before assuming anything is broken.
Jun 28, 2011 | RCA DRC8300N DVD Recorder/VCR
What channel does video player work on?
your line in or front RCA yellow/white/red cable input is usually defaulted to channel -1 and is accesible by either pressing the tv/video button on tv or remote or sometimes by scrolling down channels past 1
Mar 30, 2010 | RCA 20F424T 20" TV
I'm confused how to connect my DVD player with the TV. which cables connect where. I dont have a user manual.
good day,to connect your DVD to TV screen follow this steps.
1) prepare your RCA cable ( 3 colored cable yellow/red/white)
note: always remember this
yellow = video
red and white = Audio (left and right)
2) at the back or front display of your TV screen you'll see RCA socket marked as "AV1 input" "AV2 input" etc... if your screen is only mono sound you can only see two sockets Yellow=video white= audio
3) at the back of your DVD player connect the RCA cable following the color code yellow to yellow white to white and red to red. after you connect the cable to your dvd player now connect the other end of thr RCA to your TV screen input.
make sure you'll connect it to "A/V input" not "A/V out" then after connecting all the cables, from the remote commander of your TV screen press a button indicating "A/V" some mark as "TV/AV" press this button until your screen display the back ground display of your DVD player.
Jan 30, 2009 | Spectroniq PDV-70X
HI Boss. You can find the codes in this pdf
You can also use this alternate method that a guest posted on FixYa:
1) Manually turn on the device (TV, DVD) to be controlled.
2) Press and hold code search button until the red indicator stays on. Release the code search button.
3) Press and release the desired mode button (TV, DVD,etc)
4) Press the Channel Up button repeatedly (up to 300 times) until the device to be controlled changes channel.
5) Press and release the Mute button to install the code.
Jan 28, 2009 | Televison & Video
Hi, I have a RCA 27" console color tv without the original remote. It has the RCA cable ports. I bought a Toshiba DVD and it needs the TV to have an external channel which can only be set by remote? Is...
After market remotes only work the most basic of functions - ie., volume channel changes , on/off. They do not get into menus, change inputs, etc. If you can change channels on the console tune it to 3 or 4 and get an rf adapter for your dvd player outputs, set it to one of those channels, and connect to tv antenna input. Ir will work but the picture will not be as good as it can be.
Mar 03, 2017 | RCA G27647 27" TV
Remote codes for dish network remote?
1. Mmanually turn on the device (TV, DVD, etc.)
2. Press and hold the CODE SEARCH button until the red indicator stays on, then release the CODE SEARCH button.
3. Press and quiclkly release the desired mode button 9TV, DVD, etc.). The red indicator blinks off once.
4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device (TV, DVD, etc.) changes channel. The red indicator blinks once with each button press. If you accidentally overshoot the code required, use the CHANNEL DOWN button to backtrack through the library until the device again changes channel. Pressing the CHANNEL UP changes direction to forward again.
5. Press and release the MUTE button to install the code.
or try these
002 009 109 202 209 210 310 402 408 508 510 807 901 914 917 good luck its one of these!
Oct 25, 2008 | Philips 20PF5120 20 in. EDTV-Ready LCD...
Problems playing my Phillips DVD/ VHS with my new WESTENHOUSE HDTV
I notice this was made in 2008 and I hope you have found the answer. But if you or others have not here is my answer. Are using the RCA cable from the output on the DVD Player and you have plugged it into the RCA in ports then you need to use the remote to move through the on screen menu. My INSIGNIA has a Source List menu on the remote that shows on screen. I can scope through the MENU for TV, Composite Side, S-Video Rear, S-Video Side, Composite 1, Composite 2, VCR, HDMI 1, HDMI 2, HDMI 3. That is found using either the INPUT button on the upper left on the remote or the buttons; VIDEO, COMP, HDMI, AND TV across the top of the remote. Hope this helps.
Apr 13, 2008 | Philips Televison & Video
Rca tv
1) Buy RCA remote part # 240895 original about $25.00
2) Enter channel 00 for video sometimes works
3) Channel down 4-3-2-Vid 1, Vid 2, etc. sometimes works
4) Try Auto-Program Channels selection ( can be accessed on
front of set buttons or remote
Let me know ...........................................T.
Nov 04, 2007 | RCA F32649 32" TV
Frozen on a menu screen
Just fixed ours with the same problem. You need to hit the volume buttons on the remote during the time the screen goes black but BEFORE it gives you the "Connect cables" message.It should trick the TV into giving you a blank channel.
Sanyo TVs are made notoriously cheap, and have little glitches like this. Best of luck, space cowboy.
Oct 13, 2007 | Sanyo HT27546 TV
RCA L32W11 32 in. HD-Ready LCD Television Logo
161 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
