Question about HP Color LaserJet 2600n Printer
HP Color Laser Jet 1600 Problem
My laser printer leaves a light black cloudiness over the printed page. If I stop the page before the fuser it is not there, it is only there after it goes through the fuser.
  • 1 more comment
  • G-MAN1944 May 20, 2008
    I also get the greyish black "watermark" look all over every printed page plus I am also getting a very colour faded right hand side. What is the fuser and where is it?
  • jeshergo2002 Sep 26, 2008
    I try to clean the diffuser but still the same.
  • Anonymous Mar 19, 2014
    FUSER ERROR 50.1
Hey I have 1 problem I have the printer of 2600n when i give print Command of RED Colour its come orange and right side i get light print and left side i get little dark print , what is the problem i don't understand any can help me . Thank u Morgan.M
Posted on Jun 26, 2008
  • 3 Answers
I solved this by doing the following:
- ran the Clean ETB function from the engineering menu - press the [tick] button, then press the [left arrow] and [stop] buttons at the same time
- did this again!
- printed a cleaning page
- replaced the black cartridge (refurbished)
Seems to be OK
Posted on Mar 12, 2009
We have a friend who has gone into business, refurbishing toner.....
I should have learned my lesson many years ago, and let friends be friends and business be business.......
I had great copies until I loaded this refurbished cartridge.
Lesson learned.
Posted on May 21, 2008
  • HP Master
  • 1,113 Answers
If you are sure that saw the print image on the paper when you stopped it before the fuser (ie must be stop pre fuser but after image to verify fuser fault.) then it will need fuser assem replace
There is a fuser cleaning page that can be done on these i think not sure where, but if above is true then here is a link to a..Fuser Ass'y, 110V, Color LJ 1600/2600n part no. RM1-1820-000 ..note there is a 240 volt one too but thats for countries like mine that use 240v supply, you in US I beleive use 110V
otherwise it is the black cartridge, but fault would be seen "pre fuser/After image" if that was the case.
Posted on Dec 12, 2007
Hp color laser jet 1600
If you can rub off the colors easily with your finger then it is the fuser wire. Maybe the high voltage isn't enough to pull the toner to the drum. It's not something you can fix. Needs to go into a repair shop.
Jan 28, 2014 | Office Equipment & Supplies
My boss want to replace the black ink cartridge for one that prints color. Can this be done with the HP 12-a cartridges? HP Laser jet 1022
Unfortunately laser printers don't work this way. The laserjet 1022 was designed for black and white prints only. In order to do color printing with a laser printer you will need to purchase one that is designed to print in color. The laser printers work a bit differently than the inkjets - the laser printers have 4 toner cartridges, one each for Cyan, Magenta, Yellow, and Black, that work together to print a full color page. With the old inkjets you could just replace a black cartridge with a color one.
So, short answer: Sorry but no you can't make a laserjet 1022 print in color. :)
I would recommend looking at an entry level color laser printer from hp, such as the CP2025 (http://h10010.www1.hp.com/wwpc/us/en/sm/WF25a/18972-18972-3328060-15077-236268-3673580.html) if you are looking into purchasing a color laserjet.
Hope this helps
Please rate this post, thanks!
Mar 09, 2011 | HP 645A Magenta Toner Cartridge (C9733A)...
Hp 1600 laser, entire page comes out sligtly black
How old is it?
Page getting dark sounds like the drum getting old.
Mar 12, 2010 | HP Hewlett Packard LaserJet 1600 Printer
My hp lazer jet 1600 is making big black horozonal
Measure your marks and replace whatever is indicated by this chart.
Measurement Component
24.7 mm (0.97 inch) Developer sleeve
26.7 mm (1.05 inches) Charge roller
32.9 mm (1.3 inches) RS roller
37.7 mm (1.48 inches) Transfer roller
54.5 mm (2.15 inches) ETB rollers
56.6 mm (2.22 inches) Fuser sleeve
62.8 mm (2.47 inches) Pressure roller
75.4 mm (2.97 inches) OPC
Nov 09, 2009 | Office Equipment & Supplies
How do I clean the rollers on my laser jet printer, it prints with a long black strip in the middle of the page. Hp laser jet 1320
Most likely the heat roller is breaking down in the fuser. The fuser must be replaced. But before going that far, replace the toner cartridge, as it may have a bad cleaning blade. 85% of all print quality defects are cartridge related. This particular model of machine has a very brittle heat roller that more often than not wears out prematurely. This is true across the board for all of the newer HP low end laser printers unfortunately.
Sep 30, 2009 | HP LaserJet 1320 Printer
Color Laser Jet 3800 leaving roller marks on paper
Pull out the fuser at the rear of the machine.
Feb 07, 2009 | HP Color LaserJet 3500 Printer
Smudge mark along entire right side of every page.
HP 1600 is quite a decent little printer, so you shouldn't be dissapointed - if it's working properly, which clearly it's not in this case.
It seems that you have 2 problems here.
Firstly it shouldn't click loudly, so you need to be talking to whoever you bought the printer from.
The smudging - is probably a dirty fuser.
There are laser printer cleaning sheets, that will work quite well, but ideally it needs a little bit of dismantling to get at the fuser to clean the two fuser rollers.
I've seen lots of these with dirty fusers, and a clean with IPA does the trick.
Jan 03, 2009 | HP LaserJet 1600 Printer
My HP Laser Jet (color) 1600 is printing color on pages with no color!!
the wastage part of ur pink toner is full a is dropping the powder on paper.get it cleaned to continue good printing.wish u success
Jun 04, 2008 | HP LaserJet 1600 Printer
HP Color LaserJet 2600n Printer Logo
1,660 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
