Question about Philips GoGear HDD6330 MP3 Player
Software for windows vista
Where i can find? the cd do not instal, only on windows xp
  • Anonymous Dec 30, 2007
    please help me.I have a gogear 6330 30 gb and I lost my software.Could you give it to me please.For xp.Thanks
  • 476 Answers
Installing the jumpstart advanced 1stgrade cd rom that has 4 cds to it and I can't get it to install.
Jumpstart advanced 1stgrade cd rom installation.
System Requirements
Windows: 98/ME/2000/XP; Pentium II 266MHz (Pentium II 300MHz or faster for XP); 64 MB RAM (128 MB RAM for XP); 100 MB HD; 12x CD-ROM drive; 16-Bit color; Windows compatible sound card
If you are installing on a newer OS ie Vista, or Win 7, due to software incompatibility the software might not install, or even you can install the software might no work.
You can try using the "compatibility mode" in Vista or Win 7 to install the programs as "administrator" but no guarante this will work.
Alternatively, you can get a newer version which is compatible to your Operating System.
Hope it helps.
Jul 25, 2010 | Jump Start JUMPSTART ADVANCED 1ST GRADE...
I have purchased an hp550 computer with the Vista operating system. i wish to downgrade to the win XP operating system. how is this done ?
There is no direct path to downgrade Vista to XP. You can’t simply insert the XP installation CD media into the CD-ROM drive and hope to ‘upgrade’ and replace the Vista with Windows XP usual install routine because Vista won’t allow it to be overwritten. XP will treat Vista as ’superior’ operating system and refuse to install over it. There’re actually few options available instead of completely uninstall Vista as listed below. But if you decide to downgrade from Vista to install XP, there is also a simple guideline that you can observe to ensure that the migration goes smoothly.
Option 1 – Dual Boot:
It’s by far the easier and best method to run XP instead of Vista if you have another partition or hard disk. Simply boot up any XP setup media and install XP into different partition or hard drive than the Vista installation. Once completed, you can choose to boot up either XP or Vista, and has the best of both world.
Option 2 – Virtual Machine:
Install VMware Server or Virtual PC 2007 (both free) or any other virtualization software, and then install Windows XP into the virtual machine
environment. You will get XP which runs inside Vista, with minor compromise on speed, performance and have to go through Vista first on every bootup.
Option 3 – Format the Hard Drive, Wipe Off Vista and Install XP:
For those who totally fed up with Vista and just want XP, or prefer a clean installation of OS has only this option to rely on. To downgrade to XP from Vista, you have to basically delete the whole hard disk that installed with Vista, and start anew with XP. Here’s a simple guide and procedures that you can try to follow to switch to XP. However, each system configuration is different, so you may have to adapt the steps to suit your own need.
1. Download all drivers for your system for Windows XP from the manufacturer’s website(in case if you don't have the CD/DVD installers). Copy the drivers files to a USB flash driver or external hard drive or burn them to CD/DVD.
2. Find a Windows XP installation CD (should be pretty easy to find or else you can search in torrent sites such as Demonoid to download via BT network such as uTorrent and BitComet or search and download via ED2K network client such as eMule. You can also use Volume Licensing (VL) CD, retail (FPP) disc, or system builder hologram CD provided by Microsoft.
3. You will also need a XP product key even if you legally can downgrade from Vista Ultimate or Business edition. The Vista serial number won’t works with XP. (try to search for XP product key on web).
4. Backup to USB flash disk, external portable hard disk or CD/DVD every data files and any other things such as documents, downloads, pictures, movies, programs and etc that you need and want to keep. You can also create a second partition with disk management utilities such as Acronis Director or Partition Magic, and then move the data files to the new partition.
5. Ensure that also you have CD or DVD setup media for the software applications that you want to install and use after wiping off your system from Vista.
6. If your OEM doesn’t provide you with recovery CD/DVD discs and Windows setup media discs (it’s because they’re stored in the hard disk in hidden location), you may want to burn a copy of recovery CD to CD/DVD first before you proceed, just in case the hidden partition is lost and you want to recover your computer to original state. (How-to Guide: IBM/Lenovo ThinkPad recovery CD)
7. If the system has SATA (Serial ATA) hard drive, locate the driver for SATA controller and put it in USB flash drive, diskette or CD first. If you have PATA (normal IDE) hard disk, simply go to BIOS CMOS to disable SATA or Native SATA mode if you don’t want to install XP on SATA hard drive. Else, you can also create an XP install disc with the SATA drivers integrated by using tool such as nLite.
8. In the BIOS, also set the CD or DVD optical drive as the first boot device in the boot sequence.
9. Put in the Windows XP installation CD into CDROM drive and boot up the computer by using the CD. You probably need to press a key when prompted with “Press Any Key to Boot from CD…”.
10. If you’re using SATA hard disk with driver on external media (not integrated into XP setup disk), remember to press F6 when you see the message at the status base: “Press F6 if you need to install a third party SCSI or RAID driver…” during the very initial stage of setup to load the SATA driver so that the SATA hard disk can be recognized.
11. Run through the setup wizard at per normal. However, when prompting for where to install Windows Vista, delete (by pressing D and then confirmation), create and format the Vista disk drive or partition (if you have multiple partition). And then choose to install on that just formatted partition or hard drive.
IMPORTANT: If you choose the wrong hard disk or partition with data to delete, you will lose your essential data.
Note: If the setup does not allow you to delete or format the Vista partition or drive, you will need to find a third party software that can recognize and read NTFS filesystem to clear the drive or partition first.
12. Enter any product key for XP. Vista product key will not work.
13. If you own a legitimate Windows Vista edition that allows for downgrade (See Vista downgrade rights), call Microsoft after performing the clean install of Windows XP Pro to activate the XP installation. Notify Microsoft that you’re downgrading from Vista and require to activate XP Professional or other version allowed newly installed. You won’t get a new Windows XP product key though. You will have to read out the long Installation ID plus your original Vista serial key, and Microsoft will provide an activation ID that will make the XP usable.
14. Install the drivers for your system devices.
15. Reinstall any software programs that you want to use.
16. Move back the data files and documents.
Nov 03, 2009 | HP Business Notebook 550
I hate Vista. I want XP.
Yea that's true Vista sucks.....XP best!
If you want to install completely with XP then as usual procedure format the system with your Windows XP CD(C:/ drive only, with FAT32 or NTFS).
Aug 23, 2009 | Microsoft Windows XP Professional SP3 Full...
Canon MP500 all in one printer is not compatible with Windows Vista. Is there a solution for this problem, or do I need to buy a different printer?
My Canon PIXMA MP500, purchased in mid-2006, came with the (then) ScanSoft OmniPage SE2 software on a CD. The PC had WinXP Installed. I had no use for the ScanSoft it so I made no effort to install it.
Fast Forward:
Two PC crashes later, July 2009. Using Win Vista Home Premium
LOST, important WinWord document file, only a hard copy available.
I tried to recover, scanning the "Xerox" copy. The SE Version of OmniPage was very complicated but I succeeded in producing a replacement *.doc file.
It appears that newer editions of WinVista contain the right printer drivers for this Canon Model.
Apr 26, 2009 | Canon Pixma MP500 All-In-One InkJet...
Upgrading the OS Windows XP not possible
Upgrading from OS Windows XP:
you can upgrade from Windows XP to Windows Vista(ultimate, premium, home, business.......),
you have to buy a Windows Vista CD and install a fresh copy or format.
Some Minimum Requirements:
i) Min 2GB RAM or atleast 1GB RAM(if you have>1GB RAM installation of Windows Vista will not continue)
II) External Graphic Card. for some versions of Windows Vista(to run Aero Interface, special feature only   in some versions of Windows Vista)
"Windows Vista Upgrade Advisor" is a software from Microsoft which you can download from internet, this  can help you determine which features and edition of Windows Vista will run on your computer.
 i.e., when u load this software on windows xp it will suggest which upgrade version of windows vista          will suit your system(based on you system configuration. or hardware components.) and then            you can install the upgraded version of windows xp(mostly windows vista home,.........)
Thanking You
M. Sridhar
Dec 26, 2008 | Computers & Internet
I recently bought Brother MFC-235C.I have Compaq with original Windows XP Home Edition.Problem I have is: - after all installation with CD (it is for Vista and xp 64 Vista) written on CD and correct...
Go to the Brother web site and download software and drivers for windows XP, delete the vista one, and install windows xp stuff. Windows does't read much of the vista software.
Aug 03, 2008 | Office Equipment & Supplies
Brother's MFC-3240C All-In-One
I do not know if Windows Vista driver software for the MFC-3240C is available on CD/DVD.
You can download either the Full Driver & Software Package or the Add Printer Driver Wizard for Windows Vista ("regular" edition) from this page.
You can download either the Full Driver & Software Package or the Add Printer Driver Wizard for Windows Vista x64 Edition from this page.
Jun 20, 2008 | Brother MFC-3240C All-In-One InkJet...
My laptop contains windows vista and i want to install Windows XP
i am using toshiba satellite l300model laptop. My laptop also contains windows vista. i want to install Windows XP as well. Some of my music software does not support Vista. Can you
please help me on how can i install Windows XP and how can i download the
XP drivers. I... Read more
May 20, 2008 | Computers & Internet
How to install driver in preinstalled vista in notebook OR download xp driver
No vista drivers will not be supported. Recently i did the same thing and ran into troube getting back to vista. Your best bet is to download software updates that are compatible with vista, most things are now. Or if you want to install something if you right click the intall file first and got to properties, then compatibility and change it ro run in xp sp2, apply, ok. see if this helps
Dec 06, 2007 | Microsoft Windows XP Professional With...
Software won't work with vista
Uninstall Windows Vista. Do a fresh install of Windows XP Professional Sp2. Download XP drivers and install camera. Many software programs have trouble initializing in Windows Vista. Good luck!
Oct 12, 2007 | Microsoft LifeCam VX-6000 Webcam
Philips GoGear HDD6330 MP3 Player Logo
43 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
