Question about OKI C5200n Laser Printer
Check toner cartridge
Just about every time I go to print something I always get "Check toner cartridge 543:K toner sensor error" I have taken it out, cleaned it, everything I can think of and I still get the error. It is becoming a MAJOR pain in my a**. Can you help?
  • 4 more comments
  • Okiproblem Dec 14, 2007
    Identical problem.
  • wendydot Dec 15, 2007
    Ditto........major pain to reset toner cartridge so frequently.
    Does this have anything to do with using non OEM cartridges?
  • Signgirl Dec 18, 2007
    I am using the OEM Cartridges! Still doesn't seem to make a difference.
    Today it's my C toner giving me errors. I hate this aggravation.
  • ladyavon Mar 31, 2009
    I am having the same problem with my Oki. I have cleaned the eyes, vaccumed the whole printer where the drums sit, I have vac ea toner. and so far....I am not having any luck! Does anyone have a update to this problem?
    Thanks!!
  • Anonymous Mar 28, 2014
    Just changed the toner and I am getting the 543 error. Lots of toner in the tray and took it out and cleaned it up still have the error --- help :)
  • OKI Master
  • 1,113 Answers
Yes to non OEM's and those of you who are using them they cause heap em troubles.
It can be the drum they sit on, or toner dust on contacts of drums, machine base, and toner cart sides , also machine has eyes that get dusty, on machine frame at every toner/drum.
Pull out a tonerlook at side of handle there is a rectangle cut out silver/or black inside this lines up with "eyes" in side of printer frame, clean em.
I have also found a lot of import oki toners going around causing grief too, but fix is always sucessfull by A new gen non import toner and drum and ensuring contacts are free from toner dust.
Another thing I find customers doing is not replacing toners when machine requests them ie at REPLACE TONER, instead they find that just openning and closing lid keeps them going, but these machines hold a complete toner in the drum unit too, so all they are doing is depleting that and when they do finally provide a toner it goes straight into filling up the drum and therefore shortly will display repalce toner again.
Signgirl - your using OEM's so I suspect drum/contacts/eyes what % are t drums at and are they oem too?
Wendy - dont recommend aftermarket/refills all the money you save will be paid to someone like me to come and fix the problems they end up causing.
OKiproblem - ever use aftermarket carts/drum, and what are % of consumables?
Posted on Dec 20, 2007
Why is there black line printed across the page in 3 different areas when something is printed. I changed the toner catridge.
This is nearly always the fault of the toner cartridge. The previous cartridge may have left toner on the transfer roller and this may have contaminated the new toner cartridge. Take the toner cartridge out and inside the printer under where the toner cartridge goes you will see a felt roller that goes across the printer and has a gear at one end. Wipe this roller with a dry clean lint free cloth, rotating it to make sure it is completly clean.
Check the blue coloured drum on the toner cartridge to see if there is a black line going across it. If so clean it with the same dry clean cloth.
If this does not work then I suggest you buy a genuine toner cartridge and try that.
Jun 10, 2011 | Samsung ML-2510 Laser Printer
543:K toner sensor error. How do I fix it?
Hi dianabusk:
You have a bad K (Black) toner cartridge or the sensor is dirty,the sensors are located on the toner cartridge and in the machine where the toner cartridge seats. Try cleaning the sensors and/or replace the K (black) toner cartridge. The sensors are a silver color.
Hope this helps
Sep 26, 2009 | OKI C5150n Led Printer
I have a C3530 MFP and it won't print because it says check toner cartridge black. Toner Sensor Error
Hi
Thanks for using FixYa. Toner sensor error is related to the agitator inside the toner cartridge, it occasionally falls out of its housing so it does not move the toner sensor which is the white plastic piece that moves up and down on the coloured handle, the toner sensors themselves see this white flag if it doesn’t move then the printer thinks the sensor is broken so toner sensor error is flagged and if the flag moves too quickly the machine thinks the toner is empty. To resolve the issue your printer is facing with please check that toner lock lever is in position and follow the following procedure---
Press the cover release and open the printer’s top cover fully. Make sure the Toner Cartridge in question is correctly positioned and the right hand clip is pushed back. While holding it by its top centre, lift the image drum, complete with its toner cartridge, up and out of the printer. On the Right hand side of the toner look for a sensor patch, make sure this is not dirty. If it is dirty clean it with a soft object such as cotton wool. Now look inside the printer opposite to where the sensor patch would sit. There is a black square with a sensor located inside and check that this is not dirty. Now replace the drum and toner, and close the printer cover. Try to print a test page and it will start printing normally.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jul 30, 2009 | OKI C3530N Color MFP Printer
Poor quality since changing ink.
If you didn't have this problem with the last toner than more then likely the new one is deffective. It seems to be having a ghosting issues which happens when the dr blade inside the toner does not clean properly. You need to try another toner cartridge.
Jan 07, 2009 | HP LaserJet 1022 Printer
Oki Printer c3200 error code
Suggest you order a black drum, which may include a black cartridge. Replacing BOTH the cartridge and the drum should solve the sensor problem, then you can swap parts to isolate where the problem is.
May 27, 2017 | OKI C3200n Led Printer
Clean the sensor. Reset the printer and that should help you with this error. If thet doesn't work replace the toner cartridge.
Sep 01, 2008 | OKI C3200n Led Printer
Rotate Toner Button and Replace Cartridge Messages
Hello
take out all toners and pc drum, use pressure air to clean chip reader under the toner rack (right side) also use some alcohol to clean chips on toners and reinstall.
May 20, 2008 | Minolta magicolor 2400W Laser Printer
Message to order new k immager
After replacing a bad drum and toner cartridge, I'm receiving a 543: K Toner Sensor Error. It won't go away, we can't print :)
So i know its not a starter cartridge, and i've 'utilized' OKI's site for all its worth. Was hoping someone knew a possible solution. Thanks!
Mar 09, 2008 | OKI C5200n Laser Printer
Toner sensor error
Feb 11, 2008 | OKI C5200n Laser Printer
Fatal error 163
Fatal Error 161-Toner Sensor Error, Color:Magenta
When magenta toner sensor error has occurred
Fatal Error 163-Toner Sensor Error, Color:Black
Both are Sensor errors....You would first check the lock levers that hold the toner cartridges in, if everything is fine with them then you could possible have toner dust on the sensors. First take out the cartridge that you are having problems with, then use a dust off can and carefully clean out any axcess toner that you can see where the toner sits. there is a sensor that looks like a clear plastic or glass eye that reads the cartridges and it sometimes gets dirty.
Jan 11, 2008 | OKI C5200n Laser Printer
OKI C5200n Laser Printer Logo
1,287 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
