According to Pivotrim, it will fit your trimmer, BUT... I can see your dilemma here. Here is a link to the installation tips page for your type of trimmer: http://www.pivotrimhelp.com/Installation/Default.aspx It is recommended for your model to use "Installation Method 3", here is the instructional video: Now, It does look like the threaded, exposed end is a bit short. From personal experience with this model of trimmer, I found that the entire shaft would slip out overtime form the motor housing. With an allan key, you can loosen the joint where the shaft meets the motor housing near the throttle control. When loosened ensure that the shaft is as far up as it can go, then tighten again.
The long bolt coming down at the end shaft like place reel over bolt then turn back and forth slowly while pushing upward and it should lock in and take knob or bolt at end and tighten to the right.
"Echo Power Blend Universal 2-Stroke Oil can be used in all of our 2-cycle air-cooled equipment ever made. You may also use this oil in any other brand of 2-cycle air cooled equipment, but it should always be mixed at the 50:1 ratio whether or not it was a 32:1 or 16:1 etc. machine. This oil is the highest quality 2-cycle oil on the market today. There is no need to have more than 1 tank of fuel for your 2-cycle equipment any more." The above excerpt is from the Echo FAQs (6) here: http://www.echo-usa.com/faqs/
Oil Mix Ratio: The following ratios have been recommended for the last 10-15 years. Dolmar, Echo, Efco, Homelite, Husqvarna, Jonsered, Makita, Oleo-Mac, Red Max, Ryobi, Shindaiwa, Solo, Spear & Jackson, Stihl & Tanaka; all recommend 50:1. • 1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil. • 4 liters of premium fuel to 80 milliliters of quality 2-cycle oil. McCulloch, Poulan & Wen; recommend 40:1. • 1 gallon of premium fuel to 3.2 ounces of quality 2-cycle oil. • 4 liters of premium fuel to 100 milliliters of quality 2-cycle oil. Chinese chainsaws recommend 25:1.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck. Lou Thank You for using FixYa.
I need to replace the gas filter in a featherlite weedeater 18cc. it rotted off and I dont know what line it goes on? is the other gas line a return gas line?
Make sure your gas supply is fresh...not from last year... Secondly, clean and service the air filter element... you may need to reoil it before installation...check your manual. Disconnect the fuel line and drain it and what little is in the carb...push on the prime bulb if it's got one... Then with a clean air filter and fresh gas... give it a start and after start, disengage the choke.. Let me know how you do.. K
