Machine stains all my clothes
Hi, i've got a daewoo air power. for the last few weeks all the light colour clothes i wash get like a oil stain and it doesn't come off. i've washed the inside of the machine and rinsed it out but it still continues. is there a filter somewhere that is dirty? it also has a funny smell. please help
    Novelist:
    Champion:
  • 244 Answers
No not any filter this will more then likely bearings leaking grease that is packed into it just c if your inner drum moves up or down by placing your hand on the outer part of the inner door and place your fingers on the inner drum now lift your fingers up if it does move then your bearings are starting to collapse which is quite an exspensive job average price £125.00 to replace the bearings but if this washer is still under guarantee then get them out and thats what the stain comes from and it will alwys do it also if it doesnt move it can still be a bearing problem that its just leaking through the rubber seal and the bearings are fine eva way it comes frim the bearings m8
Posted on Dec 12, 2007
My LG Front Load washing machine is leaving black streaks and smudges on my clothing. These streaks and smudges are ruining my clothes!
There can be several things that can cause this problem. The most common are:
1. Fabric softener - did you switch brands lately?
2. Chlorine bleach - if added at the wrong time
3. A mechanical problem with the washer, like a leaky transmission leaking oil.
4. Rust staining, sometimes caused by the water being used in the machine.
Here is a link to a site that discusses this issue more in depth:
http://www.stain-removal-101.com/washing-machine-stains.html
Jul 26, 2015 | LG Washing Machines
OIL STAIN ON A CLOTHES out of washing machine E12477
Are they getting the oil stain from the washing machine? If so, you need to get a tech out to inspect your washing machine. If you are putting oily clothes into the washing machine hoping it will come out, it's too late, you need to pre-wash with Shout or Tide to remove oils and grease. The more you wash and dry it the deeper the stain will set. Sounds like you need to throw those clothes away.
Jan 20, 2015 | Washing Machines
Yellow stains on my clothes
Check carefully inside the drum. There may be something coloured like a crayon jammed in there that rubs against your clothing.
You could also try purchasing a washing machine " Cleaning solution" from your local hardware store and putting that through a cycle to flush out the machine.
After that, if this persists, the next suspect is "the dreaded oil or grease leak" from machine bearings. That unfortunately usually means a complete machine stripdown and rebuild to rectify and may be unviable economics for you.
Poppa
http://www.cdbaby.com/cd/poppamadison
Jun 25, 2012 | LG WM2277H Front Load Washer
Agitator was screeching, now there is grease/oil stains on clothes
Main seal and bearing have gone bad and needs to be replaced
Jun 02, 2009 | Washing Machines
Oil spots on clothes
HI Friend,
First of all relax alright, you are in safe hands.
See every washing machine has a turbine at the bottom f the washing bowl and below that there is a motor. And there wud be a safety valve or (washer ) which basically looks like a ring made out rubber or plastic and when this ring gets outdated or torn it stops controlling the oil flow and thats the reason y ur clothes have the oil stains ,so once it is replaced you will not have this issue.
This would surely help you in getting the clothes clean and tidy.!!!!!!!!!!!!
Have a great day!!!!!!!!!!!!!!!!!!
And please rate me so that I can improve myself(vote).
Prasanth83:):):)
May 13, 2009 | Washing Machines
I have been getting brown stains in the shape of a line on items of clothing washed in my Whirlpool duet washer. I can not get these stains out with anything and they are ruining numerous items of...
I have been getting brown stains in the shape of a line on items of clothing washed in my Whirlpool duet washer. I can not get these stains out with anything and they are ruining numerous items of clothing. I have no idea what is causing them - I have manually cleaned the inside of the washer. same thing here. I have been having this problem for a few weeks, cant wash anything white without ruining it.
Apr 23, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Oil-like stains on wahsed clothing.
Around the white plastic rim right above the steel tub, link gets caught. I have only been able to remove it with my fingers every week or so and this seems to stop the "spotting/striping" of stains on my cloths. I would also like to know the RIGHT answer to this one. Thanks
Mar 28, 2009 | Speed Queen AWS52NW Top Load Washer
My Washing machine stains clothes; they come out with brown rusty stains. Otherwise the washing machine works fine. my washing machine is lessthen three years old and always give brown stains in white...
I had the same problem, and it turns out that it is NOT the seal. It is the liquid fabric softener. The fabric softener dispenser needs to be cleaned periodically or it gets a black waxy, goopy, build up. It is this same buildup that ends up staining your clothes with dark brown or black stains. Just remove the dispenser and wash it our very well and the problem will be gone.
Oct 25, 2008 | Washing Machines
Black particles in clothes after using a top loading samsung fully automatic washing machine
You said these particles stick to the clothes, do they come off and then leave a stain? It may be grease or oil coming from a leaking drum bearing seal.
If it is, This is a major repair and not one for DIY.
Sep 28, 2007 | Washing Machines
Washing Machines Logo
202 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
