Question about Frigidaire GLER341A Electric Dryer
Frigidaire GLER341AS2 smells like its burning when its on
  • 1 more comment
  • bttrfli8 Oct 01, 2008
    i have the same dryer and it has not been wanting to dry clothes now for a week or so then yesterday it smells like it is burning. Could this be the heating element
  • Asiah Oct 02, 2008
    My dryer is running but it is not getting hot or drying my clothes what do you suggest I check first?
  • erinburdette Dec 05, 2008
    I have the same problem, but I have cleaded it out. I took the drum out cleaned it and all around it. The top of my dryer is getting to hot to where you can not even put your hand on it.
    New Friend:
The only way to repair this design flaw in Frigidaire Affinity dryers is to have the experience in appliance repair to pry open and clean out the (inaccessible to the normal consumer) burner duct which will accumulate debris through the too large vent holes allowing the lint, small stuff drop down into the vent which in turn will burn up when it gets close enough to the burner to ignite. If you don't have the experience to manually disassemble the dryer, you're out of luck. There's no other way to clean out that sealed unit. If you don't clean it out, it can cause a fire.
Posted on Aug 28, 2013
    Novelist:
    Champion:
  • 244 Answers
U may have to clean it out on the inside what it will be is lint that comes from your clothing all dryers should be cleaned 2 a year cause what can happen is the lint can set a fire which is 1 cause of house fires u will have to take the lid of aswell as the back and all u do is vac it out also make sure u clean around the heater element m8
Posted on Dec 12, 2007
Frigidaire model# GLER341AS2 humming noise
Hello friend, thanks for your inquiry!
I understand that your Frigidaire dryer, GLER341AS2, is making a humming noise. It could be a possible issue within your belt, motor, or the blower assembly. The manufacture provides to a dryer preventative maintenance kit part number 5304457724 and it costs $45.12 plus tax and shipping. I would also recommend contacting a professional to help avoid any unnecessary purchases. I hope this helps. -Matt
Aug 15, 2014 | Frigidaire Dryers
Frigidaire dryer gler341as2
Good Afternoon Friend, this is Z. I am happy to assist you!
I see you have a Frigidaire dryer, GLER341AS2; however what exactly is your concern? Are you seeking an Owner's Guide or is your dryer experiencing an issue? With this information I can better address the issue at hand. Thank you!
Jul 25, 2014 | Frigidaire Dryers
Microwave smell like burning rubber
I understand that you are receiving a burning rubber smell from your Frigidaire microwave. I also see that your appliance will run for a couple of seconds, and then you hear a weird noise, followed by a burning rubber smell. I suggest contacting your local authorized technician, especially when dealing with your microwave. They will be able to diagnose your appliance and determine what is causing that sound as well as the burning rubber smell. Hope this is helpful.
-Best Regards-
WP
Jun 17, 2014 | Frigidaire Microwave Ovens
I have a Frigidaire Dryer model number GLER341AS2. The dryer runs fine, but won't get hot. I pulled the dryer from the wall to see anything obvious. I noticed what I thought at first to be anim
Are you mechanically inclined? You may have several problems. 1st, heating element is most likely burnt out. Then I would check ball and socket assembly that back of drum fits into. Also check felt in front of machine that drum rides on. May need competent service person on this.
Sep 13, 2017 | Frigidaire Electric Dryer
My frigidaire dryer model number gler341as2 is giving me a burning smell why is that?
Hi kmcgilvery...
That burning smell is probably a lint build up in the blower system of the dryer.
You will need to remove the back of the dryer and look for the vent tubing going to the hose connected to the outside. Once you find the tubing then disassemble and clean the tubing and blower wheel of dust...then clean your flexible vent tubing you have attached to the back of the dryer.
Please take time to rate me
Sep 05, 2011 | Frigidaire GLER341A Electric Dryer
Frigidaire gallery oven purchased at Loews in October. Can't use the oven because it smells. Told the smell will burn off but after several hours of running it still smells awful. Frigidaire rep said this...
Sorry to read about your problem, I hope this helps you out.
yes lots of oil, that has to burn off... if you put it into clean mode..it will burn alot away.. plan on going out to dinner or the bar..while this is being done and leave the windows open..
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 24, 2010 | Frigidaire Kitchen Ranges
My Frigidaire electric dryer GLER341AS2. The
Does it shut down completely? If it does, and the timer ceases turning, your problem may be a blocked vent pipe or Lint buildup.Your high limit switch is designed to kill power to your heater coils and sometimes the motor in case of overheat.
Mar 09, 2010 | Frigidaire GLER341A Electric Dryer
Dryer not getting hot
Bad thermal fuse or heating element
Nov 02, 2008 | Frigidaire GLEH1642DS Front Load Stacked...
Frigidaire dryer model #GLER341AS2
along back edge are 4 screws remove and slide top forward
May 10, 2008 | Frigidaire FEQ1442ES Electric Dryer
Frigidaire GLER341A Electric Dryer Logo
280 people viewed this question
Top Frigidaire Dryers Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
