Question about RCA P46921 46" Rear Projection Television
Cracked Screen Where can you buy a replacement lenticular/fresnelscreen for a RCA Model P46921 tv?
    President:
  • 4,402 Answers
Try here:
http://www.mcminone.com/content/content.asp?pid=promo/mfr/rca&CMP=authrca
Posted on Jan 02, 2008
I am looking for the lenticular screen for my RCA model P46732BA television. Could anyone point me in the right direction. Thanks in advance copyguy69
Screens are expensive from RCA. Usually you have to buy both the lenticular and fresnel screens together which is very expensive. You should look for someone selling one of these Tv's or giving it away and rob the screen.
Apr 15, 2009 | Televison & Video
Help I need a replacement screen
You can find a new OEM RCA replacement lenticular screen and Fresnal screen (availble together as the screen assembly) for a model # R52WH73 from a major RCA distributor at the following links:
RCA R52WH73 Replacement Part Screen Assembly (Fresnal Screen w/ Lenticular Screen)
And here's a link for the protection screen if needed:
RCA R52WH73 Replacement Part Protection Screen / Super Shield
Apr 10, 2009 | RCA HD52W59 HDTV Projection Television
My Tv RCA P46921 Chassis PTK195MA has a bad flyback with PN 15128
shopjimmy.com for $14.95. put freeship in promotion box for free shipping!!!!!!
Feb 24, 2009 | RCA P46921 46" Rear Projection Television
Crack in the screen 42" sony kdf-e42a10
You can find a new Sony replacement lenticular screen and fresnal screen for a model # KDF-E42A10 from a major Sony distributor at the following links:
Sony KDF-E42A10 Replacement Part Lenticular Screen
Sony KDF-E42A10 Replacement Part Fresnal Screen
Feb 16, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
I have a RCA P46921, the screen is cracked. Need a new one.
I got one for a p46731at for $150 plus shipping which may need to be trimmed if you still need one. Call Electron Resort at 1-919-735-9139
Nov 21, 2008 | RCA P46921 46" Rear Projection Television
Need to replace a cracked screen
WD-57731 & WD-65731 Front Disassembly
57” & 65” Models Screen Frame
Removal
1) Pull off the Speaker Grill.
2) Remove all the screws (b) from the
upper rear cover (except one at an
upper corner to support the frame).
3) Remove 10 screws (a) from the
front of the screen frame.
4) Remove the remaining ***** (b)
(supporting the frame). Carefully
pull the Screen Frame from the TV
and disconnect the ES and LE
connectors.
57” & 65” Models Screens Removal from Frame
1) From the rear of the Screen Frame remove 20 screws (a) from the top and bottom rails
2) Remove 6 screws (b) from each side rail.
3) Carefully lift the Screen assembly from the Frame.
MODEL: WD-52631 / WD-57731 / WD-65731
Screen Replacement
CAUTION: Wear gloves when handling the Lenticular Screen and Fresnel Lens.
This prevents cuts and finger prints. Do not place Fresnel Lens in the sun.
This may cause fire and heat related injuries.
Lenticular Screen and Fresnel Lens Replacement
1) Apply LENS-TAPE along the rear top edge of the Lenticular Screen.
2) Place the Fresnel Lens on top of the Lenticular Screen, and apply pressure along the top edge.
3) Place the screens in the screen frame and reinstall the cushions, top, bottom and side rails.
NOTE: The Lenticular Screen label must face the front and the Fresnel Lens label face the rear.
4) Reverse the Screen Removal Procedure and insert the screens in the Bezel.
Lenticular Screen and Fresnel Lens Removal
1) Remove the top, bottom and side HOLDER-SCREEN rails and their cushions from the Screen Frame.
2) Lift the screens as a single unit from the frame.
2. Separate the Lenticular Screen and Fresnel Lens.
Note: When separating the Lenticular Screen from the Fresnel Lens, use caution
while prying the Screen and Lens apart. Use a slot type ***** driver, and
remove the pressure sensitive double sided tape.
Mar 11, 2008 | Mitsubishi WD-65731 65" HDTV
Replacement of outer screen for a Toshiba TP50H60 projection tv
A frosted sheet of plexiglas works well. I put a plexiglass screen on my own 62 inch projection TV. It must be frosted to received the image being projected.
Jan 03, 2008 | RCA R52WM24 52" HDTV Projection Television
CRACKED SCREEN
the outer screen on these units easly replaced. RCA #258797 their called supersheilds.. rca charges about 70 dollars for the item...If it is just that i have seen people just use a clear sheet of plexi. removeing the screens requires removein several torx 20 screw around the outer and remove the frame.. then the clear peice of plexi is attache with serval brackets.
Dec 25, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Cracked screen
The lenticular and fresnal screen for that unit are sold together under RCA p/n# 258513 and are available from Vance Baldwin for about $260.00 plus shipping.. They make for an oversized item so the shipping is probably 70% of the part cost.
www.vancebaldwin.com
Hope this helps!
Bill
Dec 07, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA P46921 46" Rear Projection Television Logo
658 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
