Make sure its an original Osram or Philips bulb inside the housing. If its a cheap lamp it will act this way. If it is an original lamp, then you may have a power supply issue. It shouldn't affect your TV but you may want to try resetting the lamp timer by following the instructions that came with the lamp.
TY-LA1001 Timer reset
While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
Hi, While holding Volume Down button on TV Front and press and hold Play/ PIP button on tv Remote at same time for 6 or more seconds to reset lamp hours. TV will show lamp reset message on screen. Thanks.
Check the Lamp if no picture, audio may be present. Screen is completely dark. Lamp LED
flashes 2X every 5 seconds, Power LED flashes GREEN for 140 seconds then
flashes RED. Check the ballast if no picture, audio may be present. Screen is completely dark. Lamp LED
flashes 3X every 5 seconds, Power LED flashes GREEN for 140 seconds then
flashes RED.
It seems you ballast is going out, i recommend you replaced, don't waste money buying lamps with this issue, get the ballast, they run around 60dll so it's a good deal, go to discountdashmerchantdotcom i've been getting parts from them and they offer great service, it's worth giving them a shot :)
