see the next steps , use the VOM and fix it. God bless you
Check the power diodeThis
electronic component is responsible for transmitting current in one
direction. If the diode becomes defective it will cause your microwave
to not heat. Test the diode and replace it if necessary.
High voltage capacitorResponsible
for storing electricity, this part is a key component in any microwave.
Remove, discharge, and test the capacitor to determine if it requires
replacement.
Damaged magnetronResponsible
for generating waves and producing heat. When your microwave is no
longer heating properly, replacement will be required.
Thermal CutoffsExamine
the thermal cutoffs on both the magnetron and the oven itself. Take off
one of the leads and using a volt-ohm meter on RX1, check the terminals.
If you get a result other than zero, replace the thermal cutoffs.
sounds like possible magnatron or diode thats the case its not worth repairing. but if your handy then google model nuber and get the part be extreamly careful because of the power capacitor holds extream volts. turn off and allow to sit 15min before working on
okay thats sounds like you have to take your microwave to a repair man.the HV capacitor can be open or the magnetron is bad these 2 components i mention are responsible for the heating of your microwave if they go bad..then your microwave wont heat.good luck.
Likely problem: Blown magnetron. On microwaves, this can generally go dead, usually with a popping sound. Solution: A: Call an appliance repairman to replace the magnetron in the device, or B: buy a new microwave. Depending on how much you paid for it, you might be getting a better deal on either end.
