Question about Linksys Wireless-G WRT54GS Router (e125894)
File sharing Can I file share between my laptop and desktop using my Linksys  wireless router without a separate program? If not, what's a good program? Thanks, Gary
  • Bruddah Dec 12, 2007
    Thanks for your help. I'll try it.
    Regards,Bruddah
    Hi Benimur,
    I am using Windows XP home on both my desktop and laptop,
    Thanks,
    Bruddah
    Brigadier General:
  • 6,966 Answers
File Sharing could be easily done between your laptop & desktop assuming both are running some Windows version with no other program needed to install. You have to right click on the filename/folder and enable sharing. Of course both computers must belong to the same network group for easy access.
Should you need additional information, pls post back your Windows version.
Good luck and kind regards.
Posted on Dec 12, 2007
  • Louie  Role
    Louie Role Dec 12, 2007
    Hi again,
    Glad to be of help and appreciate the rating.
    Cheers.
Can't acess laptop computer but can see on desktop
To allow access between both the laptop and desktop the hard drives or folders on both computers must be made shareable.
Right click on the C drive or folders or other hard drive then click on Sharing and Security - Sharing. Then in Network Sharing and security - tick Share this folder on the network and enter a share name that identifies this computer and drive/folder.
Apr 05, 2010 | Linksys Wireless-N WRT150N Router
How do I set up the Linksys 54G router so that I can access my wired desktop from my wireless laptop and visa versa? Thanks. Fred
Are you asking about sharing files between the 2 systems? if so, no action is required on the router. you need to setup both computers to share files. see this link: http://support.microsoft.com/kb/304040.
There is another option. www.teamviewer.com has a program that actually lets you view the desktop of the other system. This works anywhere in the world. Allows you to share files. And best of all, it's free for personal use.
Either option works, but you do not need to change anything on your router.
Oct 27, 2009 | Linksys Wireless-G WRT54G Router
Shared folder no long accesible xp and vista
Assuming that you have created a shard folder before, "Sharing Files and Folders" should be enabled on your machine.
Go to your Control Panel -> Folder Options adn click the "View" tab. Scroll all the way down and disable "Use simple file sharing (Recommended)".
Now the "Sharing and Security" option should appear again if you right-click a folder.
Microsoft has a write-up on this for general information. See here.
In regards to the possible Trojan - I would need the exact file name to find more information. What you can do from your end is to run an online scan with Kaspersky WebScanner.
Note: You should use Internet Explorer to run this scan, and you must disable your Anti Virus program during the scan.
Click the Accept button.
You will be prompted to install an ActiveX component from Kaspersky, Click Yes.
* The program will launch and then begin downloading the latest definition files:
* Once the files have been downloaded click on NEXT
* Now click on Scan Settings
* In the scan settings make that the following are selected:
o Scan using the following Anti-Virus database:
Extended (if available otherwise Standard)
o Scan Options:
Scan Archives
Scan Mail Bases
* Click OK
* Now under select a target to scan:
Select My Computer
* This will program will start and scan your system.
* The scan will take a while so be patient and let it run.
* Once the scan is complete it will display the results if your system has been infected.
o Now click on the View scan report link:
* Click the Save report as button
* Under Save as type, choose Text file (*.txt)
* Save the file to your desktop as Kaspersky.txt
* Copy and paste that information in your next post if you like.
If you have any more questions, or file sharing is still not working, just come back here and leave a comment - I'm happy to help.
Jul 14, 2009 | Computers & Internet
Wireless Laptop and Wired Desktop cannot communicate
Simply printer sharing should be enabled on both computers as well as file sharing.
Helpful Links
Printer Sharing
Jun 25, 2009 | NetGear RangeMax WPN824 Wireless Router...
Adding Dell Dimension 4600 to existing wireless network?...
Go to Staples and purchase a Linksys USB wireless-G (only G needed - the new "N" protocol is overkill) adapter (~$60.00). Insert the Linksys CD and follow the instructions. When prompted, plug the USB adapter into the Dell (frt or back) doesn't matter. If his "roomies" have security enabled on their router, you'll need to know the level, password/passphrase, and the network name that they assigned.
Good luck.
gurutim
Mar 21, 2009 | Dell Dimension 4600 PC Desktop
File sharing problem after installing Netgear DG834G ADSL/Wireles
- Run the Windows Network Wizard in each computer on the network.
Mar 10, 2009 | NetGear DG834G Router
Desktop won't connect with printer connected to laptop
Make sure both computers can share files and can ping each other, if not, it's just a firewall issue. Try to disable your firewall first.
Oct 23, 2008 | Linksys Wireless-G WRT54G Router
D-link DI-524 wireless - lan network connection
Yep. Vista sucks :-)
In the vista machine, you have to turn on a whole bunch of options. Right click Network, hilghlight properties and left click and it opens up Network and Sharing Center. Down at the bottom, you have a list of options. Start by turning on the options you need: File Sharing, Public File sharing, Printer Sharing etc. I'm pretty sure it's already done in the XP machine, but if not, check there too.
It should start to show network files between machines.
Carl
Oct 19, 2008 | D-Link AirPlus DI-524 Wireless Router
Trying to network xp pc to wireless laptop
Right click on the drive you want to share. Ex: C:\Vol-xx = name. In the pop up window click Sharing & Security. This needs done to all the drives you want access too. To share a printer. Everyone must have the printer drivers installed. The Pc that has a direct connection to the printer must also Share the printer on the network. Open Printer & Faxes, highlight the printer you want to share. Click File than click Sharing follow windows instructions.
Small suggestion regards to the wireless side of the network. Suggest you setup security so others close too you can not tap into your network. (common).
Feb 14, 2008 | Linksys Wireless-G WRT54G Router
Help please....printer name does NOT appear
You must have a network set up, and you must enable file and printer sharing on the desktop. The laptop and the desktop should be in the same workgroup. Some firewalls will cause this problem.
Start with the network setup wizard in Settings/Network.
Jan 25, 2008 | D-Link NETWORK CARD DFE550TXREF Network...
Linksys Wireless-G WRT54GS Router (e125894) Logo
47 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
