Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum
Problem for Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum
Bissell Proheat only sprays for a few seconds.
By searcyjm on Sep 15, 2009
My bissell proheat will only spray water from the floor or the hose for a few seconds each time I pull the trigger. I dissasembled the unit twice and checked all the lines and the heater for clogs. I even tested the motor by taking a couple hoses lose and put the intake in a bucket of water with unit running and it pumped the water at a decent pressure. I think the unit isn't getting enough water from the tank. So, I have ordered a new tank autoload reciever fitting, in hopes that this will solve the problem. Any suggestions?
Solution #1
posted on Sep 16, 2009
Somewhat Helpful)
andrew1872
Rank: Guru
Rating: 87%, 85 votes
When was the last time you changed the flat belt? Even if it isn't broken it could be so stretched out that when the brush hits the floor it slows or stops the pump from spraying. If its a new belt then and your sure there arent any clog's that usually means the pump is bad. Also if youve ever used anything other than bissell shampoo in the machine it could have ruined the pump as well.
Was this helpful?
Yes
No
Popular Solutions for Bissell 7901-1 ProHeat
Questions and Unsolved Problems for Bissell 7901-1 ProHeat
Do you recommend Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum?
Answer
Answer
water is not ejecting...why would this be??? please help...thanks
Answer
When using cleaner water is not ejecting from the tank. Checked and cleaned all, still nogood. Why?... (More)
Answer
I am having problems with my Bissel 7901-1. It isn't working at all. If I remember right it didn't... (More)
Answer
belt assembly diagram. Looking for a picture to see if something is missing holding the belt on.
Answer
I want to clean fluff from underneath the transparent front panel of my Bissell 11 7901. I have... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Vacuums Experts
Top Vacuum Repairmen
(502) 348-4900
Authorized Dyson and Miele Service center. Work...
VACUUM SOLUTIONS
(877) 822-8227
When you browse our large selection by vacuum...
Vacuum Cleaner Shop
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
