Question about Akai LCT4216 42 in. LCD Television
Akai LCT42Z6TN scrambled squares in all 4 corners of screen display also scrambled and when i do get a pic thin white lines running across the screen seems when i turn it on and off several times i get some results but it is getting worse. In additional any connection, hdmi, composite, have problem displaying pictures.
I had the exact same problem already and my LCD is less than 8mo old. One of the techs from AKAI told me that its a known problem and many tv's were coming back "unserviceable". They now have a "supposed" fix for the problem. I only hope it really works and its not just a "carry-over" until the warranty ends. I am beginning to think its a quality issue and the units may just be defective. Thismay be thier way of doing a quick-fix vs. recalling all those tv's. This is what he gave me to as a solution to give the serviceman when he comes to fix the LCD.
AKAI model LCT42Z6TM: If there is no image or a badly distorted image with horizontal static lines, usually with four boxes in all four corners of the screen, there is a possible fix for this. There are four capacitors on the main board that have been identified as the primary cause of this symptom. Replace the capacitors at location numbers C280, C302, C320, C323 - 100UF 35 VOLTS [dxh]
Posted on Dec 28, 2007
We have a 50" Vizio plasma TV with a persistent blue, sometimes white, pair of vertical lines on the right side about 1/4 from the right edge.
if those problems were present when you got it back from repair, then, the guy didn't fix it fully.
if those are new problems - then you are now finding out why electronics and plasma displays wear out after ten years, replace the unit, don't pay to 'get it fixed' as the rest of the parts are old and about to also fail.
Mar 25, 2018 | Vizio Televison & Video
Thin white line across laptop screen
check lcd display data cable if cable is fine problem in display unit
Apr 27, 2014 | Computers & Internet
Tv had thin black line when turned on today whole screen scrambled
need to access the ez menu to reset the parameters u will need a tech to fo this
Jul 19, 2013 | Vizio VF550M 55 in. LCD HDTV
Philips 47PFL5609D/30 White screen displays on 3/4 of screen
It sounds that the connection between t'Con board to panel have some problems; loose contact etc. Check it. Re-seat them once, and check. If you wish to get more details about faults to Philips PFL series flat panel TVs, check this link.
Feb 05, 2013 | Philips 47 in. LCD HDTV
Very thin black vertical line moving across tv screen left to right on tv
The screen voltage to the picture tube is more than normal. Adjust it by the help of screen pot-meter integrated with Line Output Transformer. Visit the site named 'Electro-help' for more details. Check this link and select the site named above. View it in 'Flip card' option, which can be selected from the drop down box menu at the left top corner or the display window. It will make search easy.
Aug 05, 2012 | Panasonic CT-20SL14 20" TV
White thin line running across horizontal on my hp laptop
You got a bad LCD screen. no immediate resolution aside from getting the LCD replaced. if your system still has warranty call Dell for replacement.
Hope it helps!
Feb 18, 2010 | Dell Inspiron 9100 Notebook
Thin red horizontal lines across screen
replace the focus block or try to adjust the screen control on the focus block for red only. this will affect the white balance of the set so adjust it carefully. the focus block is located on the front inside the set. remove the speaker cover then the 4 screws on the front plate. the focus block is 3" x 2" black box with 6 adjustment posts three for focus and three for screen. adjust only the affected screen (R).
Mar 13, 2008 | Sony Grand WEGA KDP-57XBR2 57" Rear...
Thin line across computer screen
Your Display cable (inside your monitor) needs to be replaced.
I would look on ebay to try and find the part and then take it to a local tech to replace it for you as I would not recommend anyone take apart a monitor (LCD OR CRT) if you had never done so before.
OR, Buy a new monitor.
Mar 08, 2008 | Gateway FPD1975W 19" LCD Monitor
Akai lct42z6tm
This works like a charm. "Replace the capacitors at location numbers C280, C302, C320, C323 - 100UF 35 VOLTS." I purchased the capacitors, cost me $1.07. Changed them all, that was the hardest part, took hours just to locate them. Burnt myself a few times, but by midnight, it was like new. So if you don't mind, doing something that would cost you over $500 by a profesional, I can assure you that this solution works. Email me if I can help, csclarke@gmail.com.
Nov 27, 2007 | Akai LCT4216 42 in. LCD Television
Akai LCT4216 42 in. LCD Television Logo
326 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
