Question about Toshiba SD-V392 DVD Player/VCR
VCR thinks ALL tapes are write protected.
Every tape I instert into my Toshiba SD-V392 DVD/VCR immediately starts playing. If I try to record, it ejects the tape. It obviously thinks the record tab is missing, but it's not. This happens on dozens of tapes, tapes which CAN be recorded on in other VCR's
  • susan z Dec 13, 2007
    Is this easy to fix? Is it worth having fixed?
    President:
  • 4,402 Answers
The record tab detection switch inside the machine is broken
Posted on Dec 13, 2007
  • Cary Farah
    Cary Farah Dec 14, 2007
    well depends if the switch is dirty or broken and if broken where can try super glue if broken, if dirty i use a burnishing tool it's basically a small file you can get one here for a couple of dollars
    http://www.mouser.com/search/ProductDeta...
Our Toshiba VCR won't play tape. It ejects tape after a few seconds.
If you are trying to play older VHS tapes, you may have to run them through some fast forward-rewind cycles to condition them and relieve stress
Jul 20, 2013 | Toshiba D-VR4 DVD Recorder/VCR
When you record something with the vcr it doesn't play back in color anymore just black and white. Thanks Henry
hello henry!
looks like the drum head needs to be cleaned. use a cleaning tape and try after that if color is ok. if not then propably you need to replace the head with a new one. this is a typical symptom when head gets worn out...
regards
Feb 20, 2011 | Toshiba SD-V392 DVD Player/VCR
Can not play DVD made on Toshiba combo in computer
You might try downloading (free) VLC Media player; it has dealt with a variety of formats that others don't:
VLC download
If it works for you, comment back here (to this thread) for the benefit of others-
May 01, 2010 | Toshiba SD-V392 DVD Player/VCR
VCR Issue with Toshiba SD-V295KU
This may be a bit late but I just ran across these posts. All these problems can be caused by bad tapes. Commercially-made tapes will usually play properly. But home recorded tapes, or very worn tapes, may not play back properly in every VCR. If the VCR isn't getting the right information off the tape for proper playback, it's muting the sound and the screen so you don't see any snow. It's also possible that the VCR heads already need a cleaning. It takes just one worn-out or defective tape to clog up the heads and cause the "no picture" problem, although in this case sound isn't usually affected.
Dec 21, 2008 | Toshiba SD-V295
DVD
www.toshiba.com
go to consumer product and your will find the consumer product support,they could send you the book!
Jan 14, 2008 | Toshiba SD-V392 DVD Player/VCR
Vcr thinks all tapes are play only
At the back of all tapes, there is a plastic tab. To make the tape read only, you break out the tab.
All VCRs have a sensor (usually a simple switch) that checks to see if the tab is broken. This sensor has gone bad.
Put a tape in. Unplug the unit. Take the top off and look where the tape is. Find the location of the tab. You should see the sensor there. It will be a switch, and may use an actuator to "poke in the tab hole". Make sure the actuator is good (that it doesn't look broken or out of alignment). At the other end of the actuator should be a switch. You can try to spray some cleaner into the switch, and then work it. If this doesn't work, you could replace it but you would need to know soldering. Also, you might be able to get it to work by shorting the switch leads together (50:50), but you also would likely have to use solder. You might be able to twist a piece of bare wire around the switch leads. These solutions would cause the unit to think all tapes are recordable, even if the tab has been broken out.
If the sensor is not a switch, but an IR pair (a U shaped sensor) then there might not be much you can do. Make sure the actuator is working (it will usually have a flat piece on it that will fit into the U shaped sensor to block the infrared light, make sure it moves freely). Again, if you knew which side of the sensor is the transistor (it might be marked on the curcuit board with E and C) you could drop some solder on it to turn it on all the time. Again, this is 50:50.
Dec 03, 2007 | Toshiba SD-V392 DVD Player/VCR
Toshiba dvd Video player & vcr SD-V396SU2
Thanks. We have replaced the unit with a JVC but will give the SP/SLP a try just to see.
Anoyed
Nov 29, 2007 | Toshiba SD-V394 DVD Player/VCR
Some tapes will start and immediately shut down
the vcr is on threshold of belt life. try replacing (or cleaning with alcohol) the take-up reel belt. The vcr has a built-in time-out feature to protect the video tape. if it takes too long for things to happen, shut-down occurs.
Aug 30, 2007 | Toshiba M655 VHS VCR
Toshiba SD-V392 DVD Player/VCR Logo
211 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
