Question about Motorola Mobility RAZR V3i Cellular Phone
Start up problem
I forgot my unlock code and security code, so i try to flash my v3i using Rsdlite, after that it can not start, when i press power button light comeup for short time and trun off. Any help.
  • zandus Feb 14, 2008
    my phonebook new entry is locked & i had forgot the code. how can i unlock the application. help me plz
    Problem Solver:
  • 8 Answers
Whenever ask for code ...click menu and enter 000000,
and reset ur new password
Posted on Dec 15, 2007
My motorola rokr e6 is having security code which is forgot by me ? i want to restore factory setting ,give me a better way pls help me
There is a way but you will lose all save items in your phone (messages / phone book entries.Download drivers for motorokr e6,firmware and RSDLITE v.3.4. Install them and using your cable connect your phone and open RSDLITE, your phone will be detected. Find your phone's firmware and press START and it will format and update your phone with the chosen fimware. Default sec codes 1234 or 000000
Jun 26, 2011 | Motorola Mobility ROKR E6 Smartphone
I have forgot my locked code? please help me
flash your rokr e6 . and your code is be default ....
for flash help go to this link..http://www.gsmindia.in/forum/p2k-series/11437-flash-your-motorokr-e6-at-home.html
or try this step..
Go to your Dial Pad and dial: WWW008W. To make the W hit the menu button while in the dial pad, then hit insert->insert wait to make the W .
You should see something like:
R533_G_11.12.08P
BP: R533_G_11.12.08PB
PFlex: GSZMCAUT678SW016
DSP: 63343400 TECHNOLOGY
Look at the numbers at the end of the first line for the version. The version shown here is .08P.
The Following are all Generic Firmware
R533_G_11.12.02P
R533_G_11.12.06P
R533_G_11.12.08P
Change Log - Nothing has changed until 08p which includes an EQ for Real player & Screen 3.
1. Download the file Motorola_USB_Driver_32_v2.7.6 to your PC and unrar it to your desktop so you can easily find it.
2. Install a program called "RSDLite" on your PC. To Download RSD lite Click thread for the file. For trouble free installation, if you are running Windows XP, you should have Service Pack 2 installed.
3. Download the firmware file that you want to flash to and unrar it to your desktop.
4. Start up RSDLite on your PC. You may be asked to install a number of drivers (5 or 6) to your PC. Point it in the direction to the motpcsdrivers folder you unrared.
5. Put the phone in Bootloader Mode - MBM mode by turning on phone while also holding down the Camera Button and the On/off button (These need to be all be held down together). The phone should start up with a red screen and say its in MBM mode.
6. Plug phone in using usb cable.
7. RSDLite should list the phone (this may take a minute or so. If it does not close down RSDLite and restart it). Start the flash process, by clicking the button on the top with the ??? and select the firmware file to install then click ?Start?. The process will take several minutes so be patient, the screen on you phone will turn off, but RSDLite will still show progress.
8. When the "Found New Hardware" screen pops up, select ?NO? for ?Can Windows connect to Windows Update?? then select ?Y? for ?Install Software from a specific location? and point it to the motpcsdrivers folder you unrared. Once the driver has installed, click on ?Finish? on the ?Found New Hardware wizard? to continue the process.
9. You will need to install quite a few drivers ? so just keep repeating. It may ask you to manually restart the phone ? if so, unplug the cable from PC, remove the battery for 5 seconds (make sure unplugged first!), put battery back in then turn phone back on.
10. Once its fully on, go to Setup --> USB Mode and change mode from "Mass Storage" to "Modem".
11. Plug phone back into the PC using the cable. RSDLite should say "complete" or ?PASS?
12. Unplug the phone again, turn it off and on. All should be complete.
You can now restore all your contacts, calendar and tasks back to your phone using MPT. (Be sure to remove the SIM card before doing this as the recovery function from MPT deletes any contact on SIM for some reason!)
Try This This Helps
by....ASHISH KUMAR
Jan 29, 2011 | Motorola Mobility MOTOROKR E6
My phone is locked
hi
follow these procedure to unlock your phone
first download drivers for motorokr e6,firmware and RSDLITE v.3.4.
install drivers and connect Ur phone through cable and open RSDLITE as it will detect your phone.After that browse firmware and press START and it will format your phone with brand new software and security codes will be default 1234 and 000000 but be aware that your messages,phone book and everything will be lost.
if you still having any problem contact your service provider..
thank you
Dec 22, 2010 | Motorola Mobility MOTOROKR E6
MY motorocker phone is locked
hi
first download drivers for moto rokr e6,firmware and RSDLITE v.3.4.
install drivers and connect your phone through cable and open RSDLITE as it will detect your phone.After that browse firmware and press START and it will format your phone with brand new software and security codes will be default 1234 and 000000 but be aware that your messages and everything will be lost.if still having problem means contact your service
thank you
Forget security unlock code for motorokr e6 help
install drivers and connect ur fone through cable and open RSDLITE as it will detect ur fone.After that browse firmware and press START and it will format ur fone with brand new software and security codes will be default 1234 and 000000 but be aware that ur msgs,fonebook and everything will be lost.
Jul 31, 2009 | Motorola Mobility ROKR E6 Smartphone
Hey good day :) my moto v3i just stopped
my moto v3i just stopped turning on. everytime i press the power button, the keypads just lights for about 1 second ands then turn off again. i tried to use the combination key, POWER BUTTON (+) * (+) # and then the screen displays the BOOT LOADER thing so i thought this phone might be ok
Jun 05, 2009 | Motorola Mobility RAZR V3i Cellular Phone
Forgot a security code
First Trick : For Master code calculation http://www.nokialockcode.com/calculate.php and enter it to unlock. For IMEI *#06#
Second Trick :
1.press "unlock" button
2.then press "back"
3.then deep press unlock and then suddenly press *
4.that's all you unlocked the phone successfully.
NOTE: it will not work on all nokia phones so please check the nokia phones before practising the trick;but the trick can effectively work on most non java enabled nokia phones
Third Trick :
Remove Your Sim Card, Power The Phone On
Press # From The (Insert Sim) Screen
Enter codes WITHOUT spaces.
Press * 3 times fast for (p)
Press * 4 times fast for (w)
Press * 2 times fast for (+)
Verify code before pressing the last #
Fourth One:
The only way you can reset the security code is to take it to Nokia or some mobile store where they will reset it using a flash cable.
Oct 15, 2008 | Nokia 1100
Boot problem
u need to flash if using smartmoto
Dec 10, 2007 | Motorola Mobility RAZR V3i Cellular Phone
Forgot my unlock code!
i changed my unlock code and set it so my phone locks as soon as you turn it on. But I forgot the code.... And i cant acess anything in the phone without it.. Help me plzzz
Oct 30, 2007 | Motorola Mobility SLVR L7 Cellular Phone
Motorola Mobility RAZR V3i Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
