Question about Mitsubishi WS-55807 TV
Tv problem inverted image overlay at the top of the screen on a mitsubishi CK-3526R CRT television
  • ae_7fam May 11, 2010
    So is the entire picture upside down? Or a ceartin frame, layer or color?
  • 927 Answers
Good Day;
Sounds you have a bad vertical output IC that is defective along with some caps. Change IC > LA7838 > IC401 and ALL CAPS like cap off of pin #6 1ufd 25v and etc.
Good Luck, big IRISH.
Posted on Sep 25, 2008
How can I remove the rectangular block on the screen
Check for and find your set function set buttons and use the vertical expand to go up and down and the horizontal expand to go wider.
Sep 12, 2014 | Mitsubishi CK-36310 36" TV
Tip
Mitsubishi parental lock removal/v-lock redo
Models:
Color Televisions
CS-20EX1, CS-20301, CS-26EX1, CS-26201, CS-26301, CS-2725R, CS-27EX1,
CS-27MX1, CS-27TX1, CS-27200, CS-27201, CS-27301, CK-27304, CK-27306,
CS-27401, CS-27403, CS-3135R, CK-3136R, CS-31AX1, CS-31FX1, CS-31MX1,
CK-31MX2, CS-31301, CK-31302, CS-3525R, CK-3526R, CK-3527R, CS-3535R,
CK-3536R, CS-35X7, CS-35AX1, CS-35FX1, CK-35FX2, CS-35MX1, CK-35MX2,
CK-35MX3, CS-35201, CS-35201A, CS-35203, CS-35205A, CS-35301, CS-35401,
CK-35402, CS-40FX1
Projection Televisions
VS-40VA2, VS-4517S, VS-45VA1, VS-45VA2, VS-4561, VS-4562, VS-5016R,
VS-5017S, VS-50VA1, VS-50VA2, VS-50VF1, VS-50VF2, VS-50VX2, VS-50VX3,
VS-5061, VS-5062, VS-6017R, VS-6026R, VS-60VA2, VS-60VF1, VS-60VF2,
VS-60VX2, VS-60VX3, VS-6061, VS-7017R
This system locks only the entire TV. The TV will display a screen that
will indicate "Parental Lock ... Now the lock is on" and request the
personal four digit code when the TV is powered on.
IMPORTANT> You must use the original remote control that came with the
TV to release the Parental Lock, you cannot use a remote
that came with a VCR, Audio System or from any other
manufacturer.
1. Depending on which remote came with your TV, press the button at
the top labeled TV,OR set the TV/VCR switch in the upper left
corner of the remote to the TV position. .
2. Press the button on the remote labeled POWER.
The TV will turn on and display an information
screen that indicates "Parental Lock ... Now the
lock is on" and ask for the four digit personal code.
3. Press the #9 and the QV buttons at the same time.
The TV will turn on.
4. Press the button labeled MENU.
The "TV Main Menu" will be displayed.
5. Press the ADJUST UP or DOWN button to move the arrow next to the
"Advanced Features" selection and then press ENTER.
The "Advanced Features" menu will appear and
indicate that the lock is ON.
6. Press the ADJUST button to move the arrow next to the "Parental
Lock" option, and then press ENTER.
The screen will change to indicate "Parental Lock
... Now the lock is on" and ask for the four digit
personal code.
7. Press the #9 and QV buttons at the same time.
The screen will return to the "Advanced Features"
menu and indicate that the lock is off.
8. Press the MENU button twice to return to normal viewing.
The original lock code has now been erased and the lock canceled.
on May 16, 2010 | Audio Players & Recorders
Screen blank but sound ok
This problems the two long circuit boards called the inverter board is dead.These two long inverter boards give ur tv a screen light called a backlight that where ur tv getting it light for the tv images.Take ur tv a parts and replaced these two long inverter boards.U will get ur tv picture back.Tries websites like Shopjimmy.com,Ebay.com to buy those two long refurbish inverter boards for the replacement.
Aug 28, 2013 | Sanyo 42 in. LCD TV
Mitsubishi CK-32308 No sound on most stations
Turn off TV. Turn on TV, use remote to turn off SAP. Now I have sound on all stations.
Sep 12, 2009 | Mitsubishi CK-32308 TV
Mitsubishi CK-3526R TV
not sure what light picture has to do with problem  but no there is no  vertical hold control  prob bad electrolytics invertical feed back circuit, need tech..
Dec 07, 2008 | Mitsubishi WS-55807 TV
Tv problem
Hi and welcome to FixYa,
Based on your description of the fault on a conventional CRT TV , initial suspect would be a capacitor in the vertical circuitry. There would be a number of capacitors within the vertical area, the probable faulty one would be the biggest of the bunch. It would be relatively close to the vertical IC that is mounted on a heatsink. Incidentally, the technical name of your describe fault is "vertical foldover".
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Nov 29, 2008 | Televison & Video
Mitsubishi vs5003r troubleshoot
I found this in another website... i hope this can help you. I'll try too...
Found this on the web, hope it helps.
Thank you for contacting Mitsubishi Digital Electronics America, Inc. We
are pleased to be able to assist our customers via our website. Here is the
information that you have requested:
TV Lock #8
Models:
Color Televisions
CK-35402, CS-40FX1
manufacturer.
personal code.
Oct 26, 2008 | Televison & Video
Blury screen with rainbow image cannot read words on screen
The convergence integrated circuits have failed and most likely the 2 5A fuses have opened as well. I would find a local Mitsubishi service shop.
Sep 28, 2008 | Mitsubishi WS-65908 TV
Mitsubishi CK-3526R (PIP model)
GOOD DAY; 1. CHECK C218 4.7 UFD 50 V, AND C220 47 UFD 35V ON THE SIGNAL PCB. 2. CAN BE OBSERVED AS DISTORTION ON DC PEDESTAL PORTION OF STAIR STEP PATTERN. SUSPECT C222 OPEN. LOCATED ON PCB-SIGNAL AT IC200 PIN 35. (10UF 35V) 3. SHOWS UP ON COLOR SIGNALS ONLY. OK ON B/W PICTURES. CHECK X600 AT IC200 PIN 13. SHOULD BE 3.58MHZ. LOCATED ON PCB-SIGNAL. PT# 285P02905 4. (COLOR LINES) CHECK C601 47 UFD @ 35V ON THE COLOR CONTROL OFF PIN 36 OF IC200 ON THE SIGNAL PCB. 5. SUSPECT C222 OPEN. LOCATED ON PCB-SIGNAL AT IC200 PIN 35. (10UF 35V) . REMOVING CRT SOCKET, YOU MAY HAVE CORROSION ON THE PINS OR POOR CONNECTION ON CRT BOARD, AND BY REMOVING IT COULD HAVE CLEANED THE PINS A LITTLE. TRY CLEANING PINS ON CRT AND SOCKET. GOOD LUCK, big IRISH.
Aug 16, 2008 | Mitsubishi WS-55807 TV
White lines & inverted picture at top of CRT TV image
This problem is normally the Vertical filter capacitors. You need to have them changed before it burns out the Vertical Chip.
Good Luck
Ed
NC Electronic
Mills Wyoming
Jan 07, 2008 | Televison & Video
Mitsubishi WS-55807 TV Logo
88 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
