Home | Oster | 6232 / 6233 1500 Watts Toaster Oven with Con... | Oster 6232 toaster oven.
Oster 6232 / 6233 1500 Watts Toaster Oven with Convection Cooking
Problem for Oster 6232 / 6233 1500 Watts Toaster Oven with Convection...
By jjcarlisle on Sep 15, 2009
Knob broke. Need a new knob.
Best Solution
posted on Oct 15, 2009
Very Helpful)
mindpick13
Rank: Apprentice
Rating: 100%, 1 votes
trying to find a solution for a broken knob, i discovered that there aren't many decent options. so i took it upon myself to find one. my father actually recommended that i post the solution, seeing that there were so many with broken knobs. now this works on the timer knob on an oster 6232 toaster oven. it may work on the other knobs and possibly other models, but i cannot confirm that. the plastic stem of the knob that slips over the medal stem of the timer had broken. i crazy glued it back together and knew that there was no way in hell it would hold up with just glue. sorry for the lack of pics on this part. with the broken piece glued back in place, i went to home depot to find something/ anything that would securely slip over the stem of the knob. i tried all sorts of tubing. copper, pvc, steel and found nothing. in the plumbing isle with all the brass fittings and compression fittings, i found an "ander-lign compression nut" 5/8" OD w/ insert. part # A-304 961-P.
all you need is the brass flanged insert. if you can find it without the nut and compression ring, then more power to you. after buying this, slip the piece over the knob stem flanged end first. i used 5 minute opoxy to ensure it would stay in place.
i then used a cone shaped diamond bit in my dremel tool to notch out the two sides of the knob.
just cut the brass down enough to match the notches in the stem of the knob.
and there you have it. sorry for the 2 blurry pics. hope this can help some of you.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Sep 15, 2009
Not Rated)
wilson59
Rank: Guru
Rating: 87%, 178 votes
Here is an 800 number for Oster customer support:
(800) 334-0759
Surely a knob doesn't cost that much... ?
Was this helpful?
Yes
No
Popular Solutions for Oster 6232 / 6233 1500 Watts
Questions and Unsolved Problems for Oster 6232 / 6233 1500 Watts
Do you recommend Oster 6232 / 6233 1500 Watts Toaster Oven with Convection Cooking?
Answer
Answer
Oster 6232 toaster oven...timer twist know broke. Where can I get a replacement? Thanks
Answer
I need a knob for the timer on my Oster Toaster Oven model 6084. Where can I order the knob... (More)
Answer
How should I clean our toaster oven, I can not find the paper work on it.
Answer
the knob on the manuel time broke....where can i get another one?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Oster 6232 / 6233 1500 Watts...:
Top Toaster Oven Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Toaster Oven Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
