Question about Bosch 24 in. SHU5305UC Built-in Dishwasher
Dishwasher repair My bosch dishwasher shu5305uc/u11 does not fill with water but the water valve appears to work.
  • 33 Answers
Make certain that there is water coming into the d/w if so and you are sure that the solenoid on the water valve energizes then its possible that the strainer on the water valve might be clogged if so its going to take a bit of work to remove and clean the strainer and reasemble it are you confident .
Posted on Dec 31, 2007
Bosch dishwasher doesn't work. water not coming
Hi Gilgol, The link below is a Bosh Dishwasher list of error codes, I believe your error code is E3....CHEERS..
http://removeandreplace.com/2015/10/09/bosch-dishwasher-error-codes-how-to-clear-what-to-check/
Bosch Dishwasher Error Code E3
Fault Condition: Not filling with water
Repair or Check: If the water supply cut-off valve on the dishwasher is completely open but the dishwasher will not fill with water then shut off the water supply and unplug the dishwasher. Remove the water fill line and check to see if the water inlet screen valve is plugged up. If so then replace the water valve. Cleaning the screen can make the issue worse so always replace if the screen is clogged. The valve can get stuck open from gunk and therefore flood or overfill.
Parts Required: Water inlet valve
Bosch Water Inlet Valve Assembly for Dishwasher
Apr 02, 2016 | Bosch Dishwashers
Bosch SHU3036UC/U11 dishwasher does not stop filling with water
It sounds as if the main program board has developed a fault - as it should come to a complete stop. The fact it kept the water valve open with the door open is a serious fault- so I would have it checked before using it again.
Most machines have a water-stop feature - so if it develops a leak - it will shut off the water. This clearly didn't happen.
Aug 05, 2009 | Bosch SHU3036UC Dishwasher
Bosch SHU3300 dishwasher stuck on hot water intake (w/ no power)
It sounds like the fill vlave is stuck open. This can happen if your pressure is low or if the machine is old. I would start by replacing the vlave.
May 12, 2009 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Contunuous draining turned into a flood when unit powered off
The fill valve is governed by the float switch. I doubt that your fill valve (solenoid) has failed.
Focus on replacing the float switch and you should be all set.
Good Luck!
May 09, 2009 | Bosch 24 in. SHU5305UC Built-in Dishwasher
I HAVE A BOSCH SHU5315UC THE MOTOR IS RUNNING BUT NO WATER IS COMING OUT CAN YOU GIVE ME AN IDEA WHAT TO DO?
I had this same problem, It seems to be caused by a sticking float. Try filling it with water by hand with a few cups of water and then try running it through the rinse/hold cycle.
Jan 29, 2009 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Bosch dishwasher---water filling from the bottom when off?
i would replace the inlet valve. it sounds like it is not closing all the way
Dec 29, 2008 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Bosch dishwasher not taking in water
May be open circuit water valve. Appliance will go to error mode if water level has not reached a certain height after a preset time. Check coil continuity with a multi meter. Should be looking for about 200 ohms.
Nov 11, 2008 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Dishwasher problem
there is a float in the tub looks like a little dome or such if its not touching the micro switch under it and pressing down on the leaver then the washer thinks its over filling and will not let the valve turn on remove the lower panel to see if its on the switch if not make sure the water is on then start the washer and see if the valve solenoid is getting power
Dec 30, 2007 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Bosch 24 in. SHU5305UC Built-in Dishwasher Logo
128 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
