Compaq Presario PC Notebook
Problem for Compaq Presario PC Notebook
Ram change, how?
By graymack on Dec 12, 2007
how to access the ram on an Asus A2500S notebook, is there any manual available
Same Problem
Mar 04, 2008
-   how to change ram?-   Guest
Jan 13, 2008
-   Hello,
I have the same notebook. How should I access the RAM? I could not remove the grey cover over the keyboard. Thank you.
Felipe-   felipebr
Solution #1
posted on Jan 13, 2008
Somewhat Helpful)
felipebr
Rank: Apprentice
Rating: 70%, 1 votes
Felipe
Was this helpful?
Yes
No
Solution #2
posted on Dec 27, 2007
Not Helpful)
djward
Rank: Apprentice
Rating: 40%, 1 votes
remove the cover (with buttons) above the keyboard by gently prizing it off with a small screwdriver at either end.
lift the keyboard off and the ram is hidden under a silver plate held in place with two small screws.
Comments:
Dec 29, 2007
- i should have wrote the cover above the keyboard, slides to the left
Was this helpful?
Yes
No
Solution #3
posted on Feb 07, 2008
Not Rated)
dmit
Rank: Apprentice
Rating: 0%, 0 votes
Hey there. Had the same problem. The memory is under the keyboard. To get to it do this.
1. There's a small hole on the Right side of the panel above the keyboard. I thought that was a microphone hole, it's not. Stick a pin, paperclip or whatever will fit into the hole and slide the panel to the Left.
2. The keyboard will now slide up and out. Be careful of the ribbon cable in the bottom right.
3. The memory is under the aluminum cover near the center. There are two screws 1 long, 1 short that will remove the cover.
Reverse the above to put it back together.
Was this helpful?
Yes
No
Popular Solutions for Compaq Presario PC Notebook
Questions and Unsolved Problems for Compaq Presario PC Notebook
Do you recommend Compaq Presario PC Notebook?
Answer
Answer
when i scroll down the screen flicks down slowly
Answer
problem to find 2 option for @ on my keyboard on option work crt alt v but second option do nat vork... (More)
Answer
Constant ticking noise immediately on start up,also garbled sound; cannot mute this,updated... (More)
Answer
when i perform the memory test through bios setup the 10008 no warrenty id error code in the hard... (More)
Answer
my built in camera is not working..it appears all black
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Laptops Experts
Top Computer & Laptop Repairmen
in , AR
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
