Question about Ionic Pro 901P2RIP04 Air Purifier
My Ionic Pro doesn't turn on
I have enjoyed my Ionic Pro for the past few years. RecentlyI plugged my Ionic Pro in and it doesn't turn on at all. Does anyone have any solutions?
  • 3 more comments
  • Anonymous Dec 16, 2007
    I have four of these units. One day one didn't come on at all and a few weeks later two of the Quadras quit working but the green light comes on. I have cleaned them, but do note that the red light had never come on for any of the units. Now the last one has no power..
    Should I take them all back??? Got a new store just down the street!!
    sd
  • kmeek Feb 15, 2008
    I have th esame problem. I used the ionic pro for several years no problem. One day it just quit. No lights, nothing.
    I have cleaned it well and still nothing.
  • Anonymous Feb 28, 2008
    Have the same problem, checked the micro switch interlock -- it's Ok. I did not see any fuse, still pondering. Is there a wiring diagram??
    -- dan_gregoria@yahoo.com
  • Anonymous Apr 19, 2008
    I did the same. And try different outlet in my home
  • thecuzzer Apr 20, 2008
    I got the same problem. I had it in my daughter's room and it just quit working after it produced a noice. I tried the troubleshooting tips from the Ionic Pro site and from the manual and the light wont work. I tried different outlets and wont do nothing still. Has anyone taken the item apart? please share if it worked or not or if you found something useful. thecuzzer@msn.com
    Problem Solver:
  • 12 Answers
I have taken the unit apart and found that if there is a broken wire you have to be a magician to fix it even if you had spare wires.
also found a small fuse in the bottom of the unit but it is soldered in. i am currently in the process of replacing and will post results asap.
Posted on Jul 27, 2008
  • lachapelle Aug 03, 2008
    i did replace the fuse wich was almost impossible to find and it works great again. this is not something for the impatient to try to repair!
    Problem Solver:
  • 13 Answers
Same problem!
I will try lachapelle's approach, but will also post back some info so everyone else doesn't end up driving while blind ;)
Posted on Aug 20, 2008
  • fullvsht Aug 20, 2008
    No lights?
    Here is what I did, removed 6 screws in base, removed tiny screws down grill center (front and rear).
    Fuse is located on main circuit board (somewhat of a pain to get to), I just reached in with side cutter and cut both wires, removed from harness so I had room to work.
    You can either go all the way and replace fuse, or do as I did and simply add an inline fuse.
    To be honest I simply eliminated the fuse, the fuse was protecting the capacitor and as far as I am concerned the capacitor itself is a good enough fuse for me, take care
  • fullvsht Dec 03, 2017
    Amazing, Im not the only one who still has this air freshener? It still works, just like new but minus a fuse.
I have bought Ionic Pro Turbo Air Purifier recently in USA and moved out of the country after the purchase. When I plugged in with right electricity voltage & watts, my purifier starts with green light...
Hi Sathish, I work for the Ionic Pro company. What country are you trying to use the unit in? This will help me determine how to assist you. Thank you, Mary
Feb 15, 2011 | Ionic Pro TURBO Air Purifier
Why does my ionic pro turn off for 2 seconds and demand to be cleaned even though it's been cleaned and dried and reset correctly?
I work for the Ionic Pro company. Please call customer service at 800-875-8577 and they will do some troubleshooting with you. Thank you, Mary
Dec 27, 2010 | Ionic Pro TURBO Air Purifier
Ionic pro turns off after one minute
Hi there. I work for the Ionic Pro company. Please call customer service at 800-875-8577 and they can do some troubleshooting with you. If they are unable to resolve it, they can give you the steps on how to get a replacement. Thank you.
Oct 19, 2010 | Ionic Pro TURBO Air Purifier
I have cleaned my ionic pro several times works for a few minutes and then says clean again what can I do?
Please call customer service for Ionic Pro at 800-875-8577. They will provide troubleshooting instructions and if they do not correct the issue, they will give you instructions on how to get your unit replaced. Thank you.
Feb 08, 2010 | Ionic Pro TURBO Air Purifier
I placed the filters back in , but the clean red light is still on. this is an ionic pro compact cleaner
Try unplugging it, for a few minutes and wait then plug it in again and see if it resets.
Otherwise you need to reset it.
Most appliances that displays warnings have to be reset after it is corrected.
even your trusty automobile check engine light.
good luck.
Jan 30, 2010 | Sharper Image Ionic Breeze 3.0 Air...
Red...cleaninh light..
ame problem. I returned it to the store and they gave me a new one. So Far so good. My little ionic pro now keeps shutting off by itself. Have no idea why.
Jun 07, 2008 | Ionic Pro CA500 Air Purifier
Ionic pro problem
Try cleaning the springs the the blades connect to, they're probably making a bad connection due to dirty springs.
Apr 20, 2008 | Ionic Pro CA500 Air Purifier
Ionic Pro Turbo
When you turn on it goes to clean but unit has been cleaned.
Dec 25, 2007 | Ionic Pro TURBO Air Purifier
Can't clean Ionic Pro CA-500 inside?
This unit is a pain in the @$$ to disassemble but it CAN be done. The way I always look at it: Someone ASSEMBLED it.
Remove the four screws on the bottom stand followed by two screws on the bottom side of the unit. Then remove the tiny little screws up each side that hold the grill together (you will need a precision screwdriver).
Carefully pull apart- don't force it.
One half comes off (clean that half) in bathtub. The other half does not come off-vacuum that half out and use q-tips.
When re-assembling, watch for two things: First the wire cleaner (that slides) runs on a track on each half- pull it out a little to best allow for fitting. Second, there are little tabs at the top that fit under the control panel-watch for those.
email me at originalpairadice@yahoo.com if any problems.
Oct 19, 2007 | Ionic Pro 901P2RIP04 Air Purifier
Ionic Pro 901P2RIP04 Air Purifier Logo
1,420 people viewed this question
Top Ionic Pro Air Purifiers Experts
senbukan
Level 1 Expert
Tom Chichester
 Russ Hill
Russ Hill
Are you an Ionic Pro Air Purifier Expert? Answer questions, earn points and help others
