Bose SA3 Is it possible to blow and Bose SA3 Amp when hooking up the Aux input
  • 66 Answers
While hooking up the RCA'S? I wouldnt think so
Posted on Dec 12, 2007
My Bose SA3 2 channel amp keeps blowing when I raise the volume with non-bose speakers, why is this happening?
Could be the impedence of the speakers that you're connecting. The bose amp was designed to drive 8 ohm speakers.
Aug 31, 2016 | Bose Lifestyle SA-3 2-Channel Amplifier
How to install a bose sa3 to a bose v35
How to install a bose sa3 to a bose v35....http://m.topix.com/forum/who/bose/TOH8RAETEKGB8966I/p2. See the link above . Sometimes audio cable quality n the ohm makes a difference . 12_27_2013_11_17_29_pm.png
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sam_bbe602d2c68da69b
Dec 12, 2013 | Audio Players & Recorders
Sa3 bose not sound from boselink but external input yes
It depends on the Bose system you connected with the amp and the type of Bose remote you are using?Does the indicator LED at the rear of the amplifier stay solid green when you press the ON button on the remote?If not,check that your room code setting on the remote correspond with the micro switches setting at the rear of your amplifier.
Feb 08, 2013 | Bose SA3
Bose sa3 amp, blew a fuse in it, replaced it and now it won't power up. Nice little amp, would like to find out how to test out what is wrong and fix it
If you can,check with your multimeter to see if the two voltage rectifiers are good.If they are OK,you may need to replace the 2 audio amplifiers.This will require proper tools and good experience.
Jan 06, 2013 | Bose SA3
How do I connect 2 jbl ct 26 speakers in a series to Bose sa3
I don't know the impedance of these speakers but the Bose SA3 amplifier is 100watts per channel.A higher wattage speaker may damage the audio amplifiers.
Aug 28, 2012 | Bose SA3
Need a diagram to hook my Bose CinemaT speakers. When I hook it directly to the tv no problem but can't figure out how to hookup my reciever and CD player to work also? Help Please
You'd be better off hooking the speakers to the RECEIVER'S speaker outputs, THEN hooking your TV audio output to an unused receiver input, such as AUX. The signals from your receiver cannot reach the TV; thus your CD player and radio will not play through the speakers if the speakers are hooked to the TV. All receiver INPUTS are designed to accept the same signal level; thus, you can use any input for your TV audio, such as Aux, DVD, CD, etc. Just remember which input you're using for the TV audio, and everything should work fine. Almost all receivers have an AUX input; hopefully yours also has a dedicated CD input to avoid confusion. The you simply select the AUX input to hear your TV through the speakers.
Dec 26, 2008 | Bose Cinemate Digital Home Theater System...
Best way to use US-Bose SA3 amp in Europe ?
Bose say you should pay to get it converted because over time the slightly different power cycles can effect it, however it will still works fine if you change the voltage with an adapter - like I did!!!
Dec 12, 2008 | Bose Lifestyle SA-3 2-Channel Amplifier
Connecting input & output on my TOA 900 series amp
http://www.toaelectronics.com/Manuals/P-906_12_24MK2.pdf.
Jan 07, 2008 | TOA Electronics P-924MK2 Amplifier
238 people viewed this question
 Grubhead
Grubhead
