The Canon 5010/5020/9080c/7580C etd are duplex scanner (can scan both sides in one go). If you select simplex i.e., only top side, you will get the image straight, unless you have changed the settings in the scanning software. I am assuming you are using CapturePerfect software. Please switch off the rotate option in Capture perfect and the scanner output will be as you see it.
S. Mohan
I have a canoscan N12220U I bought a new computer and downloaded a new driver 4.1 I think it will...
(More)
I have a canoscan N12220U I bought a new computer and downloaded a new driver 4.1 I think it will not let me set a link deletion
my canon printer ip1880 does not have a scanner feature..is there a program I can download so I can...
(More)
my canon printer ip1880 does not have a scanner feature..is there a program I can download so I can use it for scanning as well?
i need to replace a polaroid 4000 sprintscanner's film and slide carriers. do you know where i can...
(More)
i need to replace a polaroid 4000 sprintscanner's film and slide carriers. do you know where i can get them?
Hello! SIR I HAVE A SCANNER OF ACER MODEL NO 6696 OQE, SCANPRISA640P WE LOSS THE DRIVER CD OF MY...
(More)
Hello! SIR I HAVE A SCANNER OF ACER MODEL NO 6696 OQE, SCANPRISA640P WE LOSS THE DRIVER CD OF MY SCANNER PLEASE SIR,U SENT... (More) ( WINDOW XP2003.)
I'm trying to scan a test chart into a DR-5010 scanner. It's a little wider than a regular page. I'm...
(More)
I'm trying to scan a test chart into a DR-5010 scanner. It's a little wider than a regular page. I'm using paperport 11. I changed the width and legnth using the area tab, but it still cuts off about a fourth of the chart after it scans and goes on to paperport. It shows the whole chart when I preview it, but the output isn't the same as the preview. Any suggestions?
