posted by derik on Dec 12, 2007
I just recieved a replacement lamp and I believe it is the wrong one. I have a Sony kf-50xbr800 3lcd rp tv and reveived a xl2000u-c as a replacement?? It is half the size and the wrong shape what part do I need???
Best Solution
posted on Dec 18, 2007
The lamp you received is correct. I own a lamp replacement company. It may of been pakaged incorrectly or maybe you received just the bulb and not the housing or vice versa (housing included). First, unless housing is damaged NEVER buy a new one...just the bulb will do. Housings are the biggest markup on replacement lamps. They are manufactired at a low cost and usually retailers drive up the lamp price because they include an uneeded housing. The bulb itself (XL-2100U) should be a round bulb. Check out my listing and compare this to what you received:
http://rearprojectionlamps.com/2000u-lamp-p-2277.html
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Sony XL-2000U Projector Lamp for
Email this problem
Email this problem
Can you Help with these Multimedia Projector Replacement Lamps problems?
Continuity test for a projector...
Can I use an ohm meter to test... Answer This...
invert image on projector
i have a generic chinese... Answer This...
magnavox replacement remote...
a some where to purchase one in... Answer This...
Repair Service
Find Multimedia Pro. Repairman Near You:
