Question about Mitsubishi WD-57732 Projection Television
Picture perfect for about 15 minutes after bulb replacement...
Just replaced the bulb in my set and the picture was clear and crip for about 15 minutes and now it's very, blurry (Like the white is being overdriven). I reset all the settings back to factory default however, that still didn't work.
  • 4 more comments
  • chiverall Dec 28, 2008
    same as last replaced lampnow picture fuzzy
  • Ron K Dec 29, 2008
    Yes, I have the same exact problem. It looks like the white is overdriven and is bleeding over the edges of the images.
    Ron Keller
  • Anonymous Jan 20, 2009
    same problem, picture is to bright and it bleeds into everything.
    Blacks look gray.
  • hottamalie82 Feb 01, 2009
    changed the blub and picture is very blurry. How do I fix it?
  • jmoore_30 Mar 19, 2009
    Changed lamp about 6 months ago. Picture is now blurry. Its really noticeable when black meets white on the screen. The colors bleed into each other. Any Ideas how to fix??????
  • kevpadil
    kevpadil Feb 25, 2013
    same problem I have. Anyone find a fix yet? Try a different bulb?
  • 1,153 Answers
Is the screen kinda pink and blurry with white bars?
Posted on Dec 12, 2007
color wheel issues replace light engine
Jul 07, 2013 | Televison & Video
TV turns on, hear sound but no picture. Bulb isn't coming on. TV goes off after about 2-3 minutes. Bulb was just replaced 5 months ago.
Need the model number of the set and also if any lights on the TV come on or blink when the picture goes out or not.
Feb 09, 2013 | Televison & Video
Mitsu #WD52327 DLP replaced bulb but hazy picture
Did you clean the small mirror. Dust will cover this mirror and give you a very hay picture. This is easy job and takes 15 minutes at the most. Someone posted detailed destructions on how to do this already if you look for it under WD52525 hazy picture.
May 27, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Picture color washed out
have authorized servicer do a memory intialization this is ussually for a pinkish or reddish picture
Mar 26, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Model 42mf231d/17 42" plasma
If the loss of picture is either on top half or bottom half of screen. there are y buffer boards that go from top to bottom on left side of screen when looking at back that control those sections. when there is loss of half of picture then buffer associated with that area would be at fault and would need to be replaced. when i see a degrading symptom such as loss of picture on top half or bottom half leading to no picture issue normally you would check heat syncs on y sustain board and if not heating up after a few minutes of being turned on would recommend replacing y main and both y upper and lower y buffer boards as they complete a circuit
Jun 04, 2008 | Philips Magnavox 27MS343S 27" TV
No picture.
The lamp is turned on by a high voltage ballast, very similar to the ones in your fluorsecent light fixtures. Your ballast is starting to fail. You should have your TV serviced by a JVC authorized service center because they have the training to deal with this issue. Waiting until it fails could very likely cause more servere damage especially if it fails shorted then the power supply will need to be replaced as well.
Mar 23, 2008 | JVC HD-52Z575 52" Rear Projection...
Mitsubishi WD-57732 Projection Television Logo
321 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
