Question about Panasonic PT-47WX53 47" Rear Projection HDTV
RED color wont converge with + PT-53WXD63
I am hving this issue where RED color wont converge at top right and bottom left corner of the screeen can any one guide me chainging the IC and converging the tv
    President:
  • 4,402 Answers
Http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Dec 14, 2007
Convergence issue on Curtis Mathes CM19033S TV
try this will help u when my tv shows the problem i refer to this site onlyhttp://www.answers.com/topic/television-...
Nov 26, 2007 | Curtis CM19033S 19" TV
I own a Panasonic HDTV projection monitor PT-47WX42C I am having convergence/warping issues; There is a large green/red curve in the bottom rear of screen about 4 inches tall, and stretching over more...
Replace the convergence ICs they will be big black ICs and will have Part number on them example STK392-110
Mats Electronics has them for 9.95 each you will need 2 .
1-800-628-1118
Sep 10, 2010 | Panasonic PT-47WX42 47" Rear Projection...
Very blurry picture all of a sudden
sounds like you convergence generator is gone out, when this happens it is common for one or more of the colors to go out of alignment and not able to adjust, or hold the adjustment. typical cost for this type of repair at a shop is $250-450
Mar 27, 2010 | Panasonic PT-53WXD63 53 in. Rear...
RED ARCH ON LEFT BOTTOM CORNER
This is a very common failure on Projection TV sets.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
You can see some example photos and find a solution here...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Jul 16, 2009 | Panasonic PT-47WX53 47" Rear Projection...
My colors on the screen were way off
I would suspect the convergence IC's are bad, look for STK392-110; replace.
Feb 20, 2009 | Panasonic PT-61G54 61" Rear Projection...
Convergence issue
try fixing the convergence 2 after your've aligned the convergence 1 - the second (accessed via the set up control) let's you adjust on 9 different axis to align the red and blue tubes to the green. you select which + sign you want to adust by pressing the corresponding number for the + ie 1 for the top left, and 9 for the lower right corner.
good luck (note - you cant change the green only the red and blue, if the whole edge is a mess try moving the image (you need to be in zoom mode, and then access the position adjustment via the pitcure set up screen.
Nov 05, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Picture is bowed down from top left corner to top right corner and bowed up from bottom left corner to botton right corner. Colors are seperated a little in corners and middle top and middle bottom.
Convergence ICs are faulty what is your model number? I can post which ICs you need and where you can get replacements that come with free instalation instructions so you can do the repair yourself
May 07, 2008 | Televison & Video
Converge Problem
Replace the two STK392-110 Convergence IC's. I had the same exact issue and I replaced mine last night. When I turned it back on, i just went the two convergence options and it looks better than i ever remember!
Oct 31, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Converge problem
Sounds like convergence issue--replace Stk IC's mounted
on large heat sinks. Check power supply for open fuse device.
Re-check convergence alignment.
Aug 11, 2007 | Philips 60PP9352 60" Rear Projection...
Panasonic PT-47WX53 47" Rear Projection HDTV Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
