Unable to delete print job
I have a Brother MFC - 665 CW printer -
Problem: tried to print document' it was 'hung up'; decided to delete - it is now stating 'deleting- error - printing'
this has happened before: I have forgotten how to delete the document in que.
can someone please tell me the process
thank you!
Unplug and move your files
Posted on May 25, 2012
  • 108 Answers
Switch off or unplug the printer and then delete it. make sure you have administration rights to delete print cue if your under active directory.
Posted on Dec 12, 2007
How do I set my Brother NFC 665-CW to print multiple pages?
do u mean the whole multi-page doc or multiple copies of the same page?
the former would be what u tell it to print (whole document vs current page). The latter would be in the printer properties config page.
Sep 21, 2014 | Brother MFC-665CW All-In-One InkJet...
Print job frozen on Brother MFC-6490CW
Power down your printer to clear the cache and re load from page 3.
Jun 20, 2017 | Brother MFC 6490CW InkJet Printer
My brother mfc 665-cw is saying offline no matter what I do to try to print wirelessly
Go to system settings and select the 'Printer' option.
Right-click on the printer and enable the 'Use Printer Online' function.
Cancel all the printing jobs till that moment and redo the process.
Sometimes the 'Printer Offline' message occurs due to a 'Job Stuck' issue.
Check all network connections and functions.
Be sure the network interfaces work properly.
Turn the printer off and on to see whether the device is working properly.
Apr 25, 2011 | Brother MFC-665CW All-In-One InkJet...
My Brother Printer MFC 665-CW just came up with a message Unable to Print 4F
Hi there
Worth a go/
With some Brother printers you can try this.
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, and then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart, hopefully without the annoying cannot clean message.
Some times this happens because of using cheap compatible ink cartridges if this is the case change the ink cartridges.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Oct 12, 2009 | Brother MFC 420CN All-In-One InkJet...
"unable to print" msg
you could try going into control panel clicking on your printer then click on printer top left and cancel all documents
Jul 30, 2009 | Brother MFC-5440CN All-In-One InkJet...
Brother MFC-665 CW with "unable to print 4F" error
My MFC 665CW popped this same "Unable To Print 4F" error recently making the machine fully useless. Just an annoying triple beep and repeat error message to screen when trying to do anything at all with it. I wrote Brother about it. They said to check all through the machine (with a light) for any paper torn off inside, or unwanted foreign objects. This is a good step to do anyway to help maintain the printer. If that is not it, they said it would be a mechanical malfunction. I tried "resetting" by unplugging it for a while as they suggested to no avail. Also while I did find a bit of paper torn off down in my MFC 665 removing it had no effect.
Jul 10, 2009 | Brother MFC 420CN All-In-One InkJet...
I have a brother mfc 665cw printer, had a printer jam, cleared the jam and now recieve unable to print 50 error, unable to copy or print. Have found some information about the encoder strip but I have no...
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 05, 2009 | Brother Multi-Function Center MFC-665CW...
Printer ERROR "Unable to Print 50! Unable to Print 30!" ???
Sep 04, 2008 | Brother MultiFunction Center MFC-440CN...
this is a complex machine, without its documentation it would be very hard to figure out, so the install and setup guide is available from brother, its available here
and here is the units operator manual, this will take you to it.
following the install guide is pretty straight forward and should result in a satisfactory setup.
Oct 17, 2007 | Brother MFC-5460CN All-In-One InkJet...
Printer message: Unable to Print
5A means that the purge cam stopps abnormally when it is in use. This could be of a broken cam shaft. You have to replace the whole purge unit. This is a service job to do!
Aug 27, 2007 | Brother MFC 420CN All-In-One InkJet...
669 people viewed this question
