Question about Alpine IVA-D310 Car DVD Player
Bypass the brake or hook it up
How do i hook up my brake safty switch to a push button please help
  • 143 Answers
To make the unit work in a display cabinet
Put one side of the switch down to earth & the other to the parking brake sensor wire from the unit.
it will then assume the handbrake is on when the button is switched.
I do not recommend you do this on a driveable car ;)
Posted on Dec 15, 2007
A stuck shifter from park
Start car . Push brake pedal have some one check if you have brake lights if you have no brake lights your brake lite switch on brake pedal or directly behind it is bad or your fuse is bloen. if you have brake lights your neutral safty switch or wireing is bad. if this was helpful please leave good feed back.
Dec 25, 2014 | 2002 Volkswagen Jetta TDI
How to bypass safty switch or jump wire on cub cadet zero turn ?
Before bypassing any safefty switches I would check the safetyswitch on your clutch pedal and seat,make sure that the pedal is pushing in the switch and the seat make sure its plugged in,rarely I have seen a safefty switch go bad unless the mower is stored outside and one could possible get rusty and go from there! good luck!!!
Sep 03, 2014 | Cub Cadet Riding Lawn Garden Zero Turn...
Where does the pink wire on a vm9312 hook up to on a 2000 dodge durango
the pink wire is the parking brake wire... so should be hooked up to the paqrking brake...
OR , you can put a switch on it to bypass the safty feature.
Oct 07, 2011 | Jensen's VM9312 Car DVD Player
I do not no wer to hook up my parking brake wire. i have an 84 cutlass
ground it to permanently bypass it. or hook it up to the wire attached to the switch that gets pushed down when your e brake is applied
Aug 27, 2010 | Clarion VRX785BT Car DVD Player
I let go of the safety handle and it die a little but but still runs
american mowers are designed to kill the engine,and put the brake on the flywheel if you let the handle go.we in nz,bypass that
Jul 03, 2010 | Yard Machines 158cc Push Lawn Mower #11a...
Jensens UV9 By pass the brake
hook up the ground with the pink and when you are in am/fm mode hit the dvd set up button on the remote, input the no. 5, 4, 3, 2, 1, and 0 make sure it beeps after every no. has been pressed. then it should bring up the hidden menu select the hammer option and turn on the brake bypass option. your done.
i took this from the uv8 brake bypass. it works on the uv9.
Nov 12, 2008 | Car Audio & Video
I have a black & decker lawnhog mm875 lawn mower that just stopped working. the power to the mower is good. can you help
I had the same problem. Its the switch.
When you pull the plastic handle up, it pushes down a button switch located in the handle. Over time (and with use) the parts begin to wear and the handle is no longer aligned properly with the button. So, ........ when you pull the handke up the button is not pushed in far enough to start the mower.
I want to bypass the handle and hard wire the mower but I can't find a wiring diagram.
May 04, 2008 | Black & Decker 19" Electric Lawnhog...
Ebrake override
Take the E-brake wire coming from the stereo and ground it to any metal part on the car by securing it under a screw.
Dec 01, 2007 | Kenwood DNX7100 Car Video Player
The way you bypass the E Brake is you have to ground the wire to the radio sleev itself. There are two different peices. The radio itself and the sleeve that holds the radio in place. Take the yellow wire (the ebrake wire, not the yellow ignition wire) and open the metal connector up just slightly. Attach that wire to the top of the sleeve on 1 of the teeth located near the front of the unit. You have to make sure that the connection is good or it will not ground. Next slide the clear plastic over the wire so the only connection is with the tooth.
Then Insert a cd or dvd in the player. Press play on the remote and then push stop 2 X times on the remote. After you have done that press 26604 on the remaote and then press enter. This will permanently unlock the parking brake feature and allow you to watch dvds while in motion. If you need any further help you can eamial me.
Nov 19, 2007 | Jensen VM9510 Car DVD Player
Parking brake hook up
This wire goes to the "Hot" side of the parking break switch... When the Parking Break is put on, a switch is closed, thus putting an "Earth" on this wire.. Ya can often bypass this by connecting to earth. Sometimes this wire can be "Hot" +12v so B4 doing anything with unit "On" check this wire for any Voltage.
Aug 05, 2007 | Jensen VM9510 Car DVD Player
Alpine IVA-D310 Car DVD Player Logo
169 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
