Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Craftsman garage door opener
You can hear the motor running, but the chain will not move. Any suggestions.
  • 5 more comments
  • Anonymous Feb 14, 2008
    chain does not move when you press opener or the remote.the motor sounds like it is running but nothing happens help
  • trudeman Mar 01, 2008
    Motor hums but chain and gear won't move. How can I open the power unit and inspect/replace the gear parts?
  • Anonymous Apr 23, 2008
    m,otor runs does not open door
  • airborne08 Jan 02, 2009
    I cannot get the door to open or close and as above, the motor runs like it is going through the motion however the chain does not move at all. I have a liftmaster professional series opener that is 17 years old
  • ferron Feb 01, 2009
    I have the same problem! Chain came off now garage door only closes within two feet on floor and that is it. I put chain back on however nothing seems to work.
  • rudylee3472 Feb 03, 2009
    I can hear the motor working but the chain is not moving
  • Anonymous Mar 31, 2014
    motor runs but pulley will not turn to move cable chain to lift the door
You can order a new gear kit from amazon for $20. It's and easy fix.
Posted on Dec 22, 2007
What is the solution to this problem?. My opener is only 8 years old. Craftsman 1/2hp Sears.
Thanks, Scott
Posted on Feb 13, 2009
My problem is a little different. Chain was loose and when door hit my bumper ( car not all way in... ) chain poped off drive gear on top of opener. I got chain back on but drive gear was in a different place on chain. Door would only go down about 2 feet from floor and would hit upper limit peg at top (the one on the rail near opener motor.) I fiddled with the Up/Down adjustment screws on the side until it would go all the way up and down but it is over sensitive when down, hitting bottom and going back up or stoping about 3" from bottom with only a touch of adjustment to adjusting screw.
Should I take chain off and try to get it back in the range it was in before and adjust screws back in the range they were?
Posted on Apr 17, 2008
Remove the outside cover. You will probably see the plastic gear inside is stripped. I purchased a replacement one from readingfarmsusa.com.
Posted on Mar 04, 2008
This just happened to me. I took off the cover and found the gear was stripped.
Posted on Dec 21, 2007
I have a Craftsman/Chamberlain 1/2 hp 315mhz Garage door opener model 139.1845.DM just stopped working. The motor runs the chain moves, the door doesn't open. Whether I use the remote or pad still n
All garage door openers have a quick release. Have you checked to make sure that is locked in place? Most have a cord hangin from it and you pull it which releases it from the chain. Make sure that is engaged and it should work.
Dec 02, 2011 | Home Security
Have a Craftsman 1/2 HP Garage Door Opener, been working fine. Now when you start it you hear the motor running as normal but the chain doesnt move?
You must ensure the drive chain is engaged to the door puller.
Sometimes the emergency release if pulled (red cord) the drive and the coupling come separated.
Make sure the pin is back in place (pull release cord and make sure pin springs back in).
The run an open close cycle, it should pick up the drive again.
Please dont forget to vote this answer was helpful and accept my answer.
Many thanks
Feb 22, 2011 | Sears Craftsman LiftMaster Chamberlain...
Motor hums but door doesn't move. If I disconnect door and give chain a horizontal poke, it will move. When I reconnect door it returns to humming, without movement.
Remove the cover from the motor unit and you will find the drive gear has stripped. White sawdust all over. The part number for the gear kit is 41A2817 and it comes with instructions. It is available at any good door opener service company.
Feb 04, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftsmen garage door is not opening. It started
Your drive gear must be stripped. Remove the cover and you will most likely find lots of what looks like white sawdust and a stripped gear. It is white nylon and is just in front of the motor. The part number is 41A2817 if you want to replace it and it comes with instructions. Available at any good door opener service company.
Nov 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
I have a Sears Craftsman 1/2 horse garage door opener. When I push the button, I can hear it hum, but the chain won't move and it seems the sprocket is frozen?
If your door is stuck in the open position you will find the trolley is jammed against a bolt just in front of the motor unit. Remove that bolt and run the opener until the door closes. Now locate the 'up limit' control on the side of the motor unit and turn it 2 times in the opposite direction of the arrow printed on the cover. Replace the bolt.
Sep 03, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage Door opened but will not close. I opened
I think the trolley has jammed against the bolt just in front of the motor unit. Remove the bolt and then run the door until it is closed. With the door closed locate the 'up limit' control on the side of the motor unit. Turn this 2 turns in the opposite direction of the arrow printed on the cover. Replace the bolt.
Sep 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman opener motor works, but chain does not move.
If the motor is working but the chain does not move you must remove the cover on the motor and check to see that the chain is on the sprocket. If the chain is on the sprocket and the sprocket is not moving but the motor shaft is moving then the sprocket must be retightened onto the motor shaft.
Apr 20, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener motor runs, but the chain drive doesnt turn
If the chain is not moving and the motor is – you need a gear kit.
Unplug the unit - take of the cover – you will find white shavings inside – these confirm the diagnosis. .
Get the gear AND sprocket kit.
It’s a good DIY project but you MUST VERY CAREFULLY Follow the instructions step by step.
HOPE THIS HELPS
Mar 13, 2009 | Sears Craftsman LiftMaster Chamberlain...
Motor runs but door does not open
you have a stripped gear on your opener. Replace gear and sprocket kit
Feb 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman Garage Door Opener Won't Open
When mine did this, it was because the nylon gears that drive the chain had stripped. My wife had to live without the opener for a week or more, but I was able to find a new gear kit online and replace the damaged gears. It wasn't difficult.
The other option is to buy a new opener.
Dec 03, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
1,050 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
