Question about Kenmore 62702 Microwave Oven
Kenmore over the range microwave oven
Initial problem started simply by not working at all. unplugged and plugged back in the outlet. microwave then said power failure. now the microwave doesn't heat and the power button doesn't work either all of a sudden. it turns on and turntable spins but no heat.what could it be
  • 5 more comments
  • jeff40cal Feb 27, 2008
    Possible short in the plug?
  • Lindamhf Jul 04, 2008
    No heat, just not cooking. We have unpluged and pluged back up stilldoesn't cook.
  • 450slc Sep 07, 2008
    Everything is working lites clock ... but it will not heat.
  • luluzc Sep 09, 2008
    -plug; unpluged, not working, only appears SE letters on the screen.
  • lyndseymama Apr 09, 2009
    checked the plug many times and it wasn't associated with the power...I've been told by many it was a tube fuse that needed replacing behind the top grill, but it costs more to fix then to buy a complete new microwave...this problem seemed like a waste of money
  • lyndseymama Mar 12, 2010
    Had a tech come out...They said a "magnatron tube" was blown...I guess it's some kind of fuse. But locally it's cheaper just to replace the microwave completely than to replace the part. Just the part was $159 plus tax, not including installation and Labor. So... opt for the new at $197 with a warranty. And companies wonder why people constantly throw out appliances...I guess this is only one example. Hope this solution hlps someone
  • ky308 May 11, 2010
    kenmore over-the-range just quitted and has no power at all. may be a fuse blown? how to fix that?
Hi how r u
i want to know what's the average power that i should put it on my microwave
thank u
Posted on Apr 21, 2008
Maybe a short in the plug somewhere?
Posted on Feb 27, 2008
Code, F-9
This is not usually a consumer repairable fault - but you may be able to clear it simply by unplugging from the outlet for a minute or two and plugging it back in again. Try it out and if it works, you're all set - otherwise it might need to be seen by a pro.
Apr 07, 2014 | Kenmore Elite Over The Range Microhood...
The switch button is not working..
Hi, kindly unplug the unit for five minutes. this will drain all power, and reset the main board. Once the five minutes have passed, simply plug the unit back into the power outlet. If the problem continues, the touch pad should be replaced asap.
Mar 27, 2011 | Amana RFS18MPS Microwave Oven
No power on Whirlpool Microwave MH7110XBG
There is a ceramic fuse inside the unit. You can order it from repairclinic.com. Use your model number to search for it. Sounds like your problem. Simply replace the fuse and you should be good. Remember to unplug the microwave before you open it up.
Let me know how this works out for you.
Benjamin
May 29, 2010 | Whirlpool MH7155XM Microwave Oven
Our GE countertop microwave key pad does not work. The start and clear button does not work. owners mamual jes1651 . unit is 2 years old.
HI. Kindly, unplug the unit for five minutes. this will drain all power, and reset the main board. Once the five minutes have passed, simply plug the unit back into the power outlet. If the error continues, the touch pad should be replaced asap.
Oct 19, 2009 | GE Microwave Ovens
Kenmore built in microwave displaying "D" and wont heat.
"d" may mean demo mode. The first thing to try is a "hard reset". Unplug it from the power outlet for 10 minutes, plug it back in, set the clock, then try again.
Jun 06, 2009 | Kenmore 62622 Microwave Oven
Power outage now microwave won't work
Most likely blew internal fuse. Pull the top/side cover off and check the line fuse. It should be behind the control panel in that area.
Nov 08, 2008 | Kenmore 62622 Microwave Oven
Microwave
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour.
Then let us know if the hard reset does not fix it.
But please reply back with your full model number so we can help you.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
Sep 15, 2008 | Kenmore 63672 Convection/Microwave Oven
Kenmore elite microwave touch screen stopped working
Same thing happened to us. We just came back from Sears, where we bought another. Just for giggles, my wife suggested unplugging the old one and plugging it back in again. It works now. New one's going back to the store.
Jun 06, 2008 | Kenmore 63793 Convection / Microwave Oven
Does the digital display light up at all? Is it completely dead? Are you sure it has power? Have you tried another outlet? If the outlet is good and the unit is completely dead, the internal fuse may have blown. You can try to take the cover off (with the unit unplugged) and look for a blown fuse. Try replacing the fuse with an EXACT fuse of the same rating. Try plugging the unit back in again and see if the unit comes back on. If not, you may have a power supply issue or defective Magnetron.
Please let me know what you find and we'll go from there.
Good Luck,
- Jim
Jan 28, 2008 | Kenmore 62702 Microwave Oven
Kenmore 62702 Microwave Oven Logo
318 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
