Question about Dell DJ MP3 Player
Headphone Jack Audio Expert, I have a Dell DJ Version 2.20.07 MP3 player that will only produce sound in one headphone speaker. If I push the plug in real hard, it connects and produces sound in both speakers. How do I get the case apart? I'm sure that either the jack needs replaced or simply resoldered. Please help! Thanks! Jim
  • MrFaversham Dec 16, 2007
    I have the same problem with my Dell DJ30, only sometimes the sound cuts out on both sides. Like Jim59, I have to hold the plug firmly in place to get steady sound.
  • JAG1956 Jan 08, 2008
    I have the same problem - only one channel playing. Started taking apart the unit, but after getting the back off was afraid to proceed and cause damage. Gave up hoping to find a electronic geek to fix it for a few dollars.
    {Don't want to spend too much, as it is several years old, I assume the battery will die soon after I get a fix.
  • 3 Answers
The plastic pieces on the top and bottom are just stick on. pry them off gently and you'll find four of the tiniest screws on the top and bottom(you'll need a precision screwdriver) after you remove the screw pull the metal pieces on top and bottom off carefully with the screwdriver. the whole piece is shoehorned in, but it will push out just far enough to reveal the aux. jack. you'll probably find that this piece is cracked and that is why it only play through one or no sides. i'm still looking to find this piece.
hope this is helpful to you,.
Posted on Jan 04, 2008
I would like to listen to my saddisk with out using my hear plugs
The Sansa does not have any speakers. You need to have something produce sound. If you don't want to use headphones/ear plugs, you can plug some speakers into the headphone jack.
Jan 13, 2012 | SanDisk Sansa e140 MP3 Player
Suddenly no sound from speakers
First, we must determine if the problem is with the speakers themselves, or with hardware or software of the computer. Try plugging a set of headphones into the audio out jack of your system (often times, this will be a green colored jack). Play sound on the computer while listening to the headphones, can you hear the sound? If so, the problem is with the speakers, otherwise, you need to troubleshoot software/hardware of the system. Another method would be to try plugging these speakers into the headphone jack on an mp3 player, mobile cd player, stereo, or similar device. Aside from the system not putting out sound, the speakers could be plugged into the incorrect jack on the system (not audio out, OR not audio out on the correct device), or turned all the way down.
Sep 18, 2011 | Dell A215 Computer Speakers
I WANT TO CONNECT HEADPHONES TO 1/4 INCH PHONE JACK ON TECHNICS AMPLIFIER IN A WAY THAT WILL CUT OFF SPEAKERS SO THAT AUDIO IS SOLELY THROUGH THE HEADPHONE. HOW DO I WIRE THIS USING THE PHONE JACK ON THE...
Please plug/ connect this wireless headphone base unit in Line Out jacks at back of amplifier to get sound in headphone and turn down amplifier volume control to shut off its speaker sound.
Thanks.
Aug 11, 2011 | Technics DJ Headphones
No sound coming from headphones using my dj mixer. however through speakers sounds fine. Im using 2 pioneer cdj 1000 mk3 and a djm 800. The sound works perfectly through speakers. how ever nothing through...
hii there, pls try to use another headphone on your mixer, if you get the same problem. It means your headphone have no problem. Problem is with the the jack of your mixture. Open your mixture and check the jack properly attached internal.
Dj Ajay
djajay@inbox.com
Nov 15, 2009 | Pioneer DJm600 DJ Mixer W/Sampler Black...
The headphone jack opening no longer works.
The only thing that I would tell you is that if you want to fix it then you are going to have to take the player apart and check the headphone jack yourself but that may cause more issues if you have never done it before.
Oct 20, 2009 | Dell DJ MP3 Player
Headphone jack is wack
if you tried switching the headphones and have same issue, only a touch of solider will fix it. Microcenter has refurbed players for CHEAP with nice lcd video screens. http://www.microcenter.com/search/search_results.phtml?sortby=pricelow&web_group=hw_mp3_players&category=KB1
May 25, 2009 | Dell DJ MP3 Player
Sound Problem with Headphone
First try the headphones in a different machine, such as an mp3 player or cd player to make sure the headphones still work.
Try going to the start button, then settings and control panel. Then select "Sounds and Audio devices" Down at the bottom you should see "Speaker settings." Click the "Advanced" button and then select stereo headphones.
Then, place the headphones into the green audio jack (or the headphone jack up front if you have them), play some music, and then gently wiggle the jack to see if some of the sound makes it into the headphones. If not, try slowly pulling the headphones out of the jack while the music is plaaying. you might find that the jack has slipped a little and may play only if your connector is slightly pulled out or more firmly pushed in. If his helps, then your audio connector is loose and you should replce the sound card. If the card is on the motherboard, you can disabled it when you put a new card in.
Jul 09, 2008 | Compaq Presario 700 470024-192 Notebook
Lost right channel on Dell Digitial Juke Box
yes, you need to remove the roller (prod with screw driver at its base) then the plastic covers from the top and bottom of the dj must come off. this will expose eight screws total. remove them. then push the motherboard and the harddrive and bettery up through the case/shell. you will see the bad connections between the jack and the motherboard, solder them again to reestablish the connection. re assemble.
i am not saying this will not harm the dj, i did it a bit differently and screwed mine up. bestofluck
Mar 13, 2008 | Dell DJ MP3 Player
Headphone jack
I have the same problem with my DJ 30, and it exists with several different types of headphones.
I am thinking about trying a mono to stereo adaper, where the plug is mono, and the ear phones are stereo. I don't know if it will work or not.
Dec 16, 2007 | Dell DJ MP3 Player
Ear Jack
Theres a good posibility that the solder connections are the only thinbg wrong with the connections BUT theres a possibility that the Printed curcuit board its self is a flex board and that the flex connections are torn. If thats the case you probably wont be able to fix the unit. If you can open the unit then you can look at the connections and see if its just plain old solder connections?? Good Luck
Apr 22, 2006 | Dell DJ MP3 Player
Dell DJ MP3 Player Logo
91 people viewed this question
Top Dell Audio Players & Recorders Experts
jairo sanchez
Vernon Taylor
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
