my 15 inch kicker sl7 has a bad voice coil or atleast for the only way for u to make bass and not make loud noises you have to put a blanket it on it to keep a litle pressure on it down. is there anyway i can fix this or get a new voice coil
-   i have a kicker l7 solo-baric and it only works when in motion at high volumes. i push it in and it comes on, and also, it has a scratching noise as i do this. it's an older model and i hear it can be fixxed. how and where can i get this fixxed?-   kid420_06
Hello. I do speaker reconing and amp rebuilds for a living and the L7's often suffer from tinsel leed wire breakage which can cause "poping" and "screaching" noises in the sub in various cone positions. You need to remove the sub and push straight down on the cone repeatly and determine if you can feel or hear crunching noises to make sure the voice coil and/or spider are not damaged. A faulty leed wire can usually be identified by a dark spot or obvious breakage. All of the L5 and L7 models can be successfully repaired as long as they are the older models that have a center cap in the cone. The newer capless models will have to have an upper brace cap glued to all of the cone's fingers and will have a rather ugly appearance. Leed wire overhauls usually run around $30.00 for the older models. Voice coil and spider overhauls run around $90.00.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Kicker 02S10L74 Car Subwoofer
im intrested in buying 2 15'' Kicker CompVR 07CVR154 speakers, and i'd like to have the best idea...
(More)
im intrested in buying 2 15'' Kicker CompVR 07CVR154 speakers, and i'd like to have the best idea for box demisions, but keep in mind my MAX width is 40'' for the enclosure and if it helps at all my vehicle is a 94 isuzu rodeo, (small suv type vehicle)
i got a new car & the set only works for a few sec. then restarts all over can u help set #...
(More)
i got a new car & the set only works for a few sec. then restarts all over can u help set # cn-hds700td
connected new sony player.no sound or display showing.theres power to unit as cd can be put in and...
(More)
connected new sony player.no sound or display showing.theres power to unit as cd can be put in and ejected as normal
