Question about Westinghouse L1975NW Monitor
No input... I hooked up the monitor to my laptop and its not sending the picture. I dunno if i have the right drivers for it or not. Can you tell me what i'm doing wrong?
On mine I have to go to display properties and set device choices. If you have a display icon on your taskbar right click(display properties, output to..monitor)
Posted on Jun 08, 2009
  • 383 Answers
spacer.gif spacer.gif spacer.gif Service and support team is available:
Monday through Saturday
9 AM - 9 PM Eastern Time
1 (866) 287-5555
Note regarding LCD Drivers
Since Westinghouse LCD (TVs and Monitors) are plug-and-play devices, they do not require any drivers. If your computer is unable to display at the recommended resolution, please check your graphics card to see if it supports the recommended resolution. You can periodically check the graphics card manufacturer's website for any update.
Good Luck, Please dont for get to VotNo input... - spacer.gifou.
Posted on Dec 12, 2007
How to hook up my toshiba c655 to tv and have audio
If you have HDMI out on your laptop, it should send the sound and picture to your TV (make sure appropriate drivers are installed).
If you only have VGA out, then it will not send sound. Tthe only other option is if your TV has Audio IN (either 3.5mm headphone jack, or RCA Left/Right), then you could connect the headphone jack of your laptop to the TV that way.
Jun 19, 2012 | Toshiba Satellite C655-S5082 Laptop
How do i connect my laptop to my kde p42xs1
You will need a vga to vga cord....hook one end up to your monitor out on your latop and the other end to the monitor in of your tv....power tv on and select the correct input...(monitor or vga-rgb)....Power on your laptop and find on your top keys (f1-f10) your monitor picture. Should be f8 or f5...when you find the right one, push and hold your function key and while holding it tap the key with the monitor on it...on my laptop its f5....That should send a signal out to the tv.....Some pcs if you do it again you can see video on both pc and tv at the same time...gd luck
Apr 11, 2012 | Televison & Video
Hooked my laptop up to monitor and picture will not appear, no signal detected, any quick fixes?
Did you tell the laptop to turn on the external video output? Most do not have this on unless you tell it to. What kind of a laptop is it?
Feb 14, 2011 | ASUS VW224S 22 inch Monitor
My monitor comes on for about three seconds when I turn the computer or the monitor off/on and then it fades to black. It looks like the computer is booting up fine when I can briefly see the screen but...
Connect the monitor to the "video-output" port on your laptop, to see if the monitor is working correctly.
You make have to tell the laptop to send the video-output to "both" the internal LCD screen and the external monitor.
If it works, then your monitor is OK.
Restart your computer, and keep tapping the F8 key, until you get a menu of startup items. Choose the 'VGA' startup option, to select the "minimal" device-drivers for your video-card. With the "minimal" drivers, your monitor should still be working.
May 31, 2010 | Computers & Internet
Samsung Syncmaster 760V doesn't have picture
You might have a resolution-too-high problem, or more likely, the laptop is sending output towards a different video port. Some laptops have a function + key labeled "CRT/LCD" or sporting a small stylized video: try checking that first.
Dec 04, 2009 | Samsung SyncMaster 760vTFT Monitor
My laptop is on and plugged to the monitor, but the monitor says no signal
You have to switch your laptop to a different display mode. Usually it's done by pressing Fn key and F8 - look for a description near this key showing rectangle / rounded rectangle, or text "CRT / LCD".
Usually there are 3 modes:
LCD (internal laptop display) only
LCD + CRT - the picture shows on both displays
CRT - the picture shows only on the external display, allowing you to set a different screen resolution, equivalent to the external monitor's optimum resolution.
Oct 29, 2009 | Acer AL1916W 19" LCD Monitor
No picture
If you mean you hooked up an external monitor and you want to see the display there. Well there should be a Fn key combo to toggle the displays. It should be one of the keys that looks like a monitor plus the Fn key at the same time. Otherwise go into the Control Panel -> Display -> Settings and you can switch to the other monitor there. Hope this helps.
Jan 18, 2009 | HP Compaq Presario v4000 Notebook
I hooked up my monitor to my Sony Viao laptop.
when upower up press F8 key also check there u set laptop as primary dispaly and second as monitor.
Jan 05, 2009 | HP Pavilion F1703 17" LCD Monitor
I DON'T GET A PICTURE WHEN I HOOK UP MY LAPTOP TO MY TV MONITOR.
on your laptop keyboard, press function button & monitor button at the same time .
Oct 18, 2008 | Computers & Internet
LCD screen displays everything in inverted colours
Do Rick's 1st solution of trying the external monitor.
If thats messed up too then it's software. (Windows, drivers, settings, etc)
If the monitors fine then you've got problems send it to an expert at that point.
Mar 21, 2008 | Lenovo 3000 C200 Notebook
Westinghouse L1975NW Monitor Logo
118 people viewed this question
Top Westinghouse Computers & Internet Experts
Steve Allison
Steve Allison
Jim Goldsmith
Jim Goldsmith
Are you a Westinghouse Computer and Internet Expert? Answer questions, earn points and help others
