Question about Emerson NR303TT CD Shelf System
Emerson NR303TT Turntable won't work
I received an Emerson NR303TT and the turntable wouldn't drive. I found that the belt was off. I beleive that I repositioned the belt but it doesn't seem to be getting the power needed to turn. Any Ideas???
  • darrell
    darrell Dec 27, 2013
    i just went threw this with the turntable removed when you move the needle arm to play a record there is a swith that moves to turn it on close to center on record it a pin and a lever usly a spring is broke or gone that hold the lever swith against the moveing rod that attachedes to the arm
  • 104 Answers
Http://www.archive.org/details/Turntable_Belt_Installation
above is a generic video that applies to almost all belt driven turntables including yours that will show how to install the belt and a few other things. maybe something in the video will clear up exactly how to get the belt on right.
if motor won't spin, spin it with your fingers, sometimes a "dead spot" developes on these motors. if it then starts on it's own, just let it run for a few hrs and the problem may solve itself for a long long time.
Posted on Feb 12, 2009
Aiwa lx-110 turntable won't spin
chances are that is the drive belt for the platter, check you local radio shack, they used to carry or be able to order those kinds of things
Mar 09, 2013 | Audio Players & Recorders
Turntable doesn't play
If the turntable stopped spinning then then the turntable belt maybe broken or has slipped off the drive.
Mar 02, 2013 | Emerson Nr303tt Mini-Stereos
CD Changer won't finish loading a CD
I had the same problem and found the cure for it. The drive belt was streched and when it started to close on the disc, the belt would slip and eventually show loading error..The two belts cost $4.50 at belts plus. Hope this helps you
Feb 21, 2013 | Sony MegaStorage CDP-CX355 300-Disc CD...
NEED A DRIVE BELT FOR MY EMERSON NR303TT
www.partstore.com >emerson they will have the drive belt u are looking for
Feb 25, 2011 | Emerson NR303TT CD Shelf System
Turntable will not turn. the motor is not
After removing the rubber mat, you should see a clip on the spindle that keeps the turntable on. But you will still not be able to remove the platter until you remove the unit from the cabinet. Remove the bottom cover and flip the two clips and the turntable assembly can be removed.
Nov 21, 2009 | Emerson NR303TT CD Shelf System
Dont know how to put on the belt for my emerson turntable m-266oa
Merely take off the horseshoe clip from spindle(under rubber) and remove turntable. Put the belt around the circular raised area in the middle of the platter and reinstall platter over spindle. align one of the holes in the platter with the brass spindle and just pull belt around spindle. Good luck...
Jul 10, 2009 | Aiwa PX-E860 Turntable
Hi I have an Emerson microwave oven MW8998B. The turn table will not rotate while cooking. The smaller bags of popcorn just burn the bag. Does this need a repairman or can I fix it myself. Also, I am able...
Hi, I had the same problem with my Emerson microwave. As I rent out the house, and the turntable stopped working while I was away, my rental agent bought another Emerson microwave. On my return I tried using the new (brown) plastic turntable on the old microwave, and found it worked perfectly. Maybe it would be possible for you to order a replacement turntable part. Hope this helps. Good luck, Rosalind
May 13, 2009 | Emerson Black Microwave Oven
JVC LA -55 Skipping
How old would you say this turntable seems to look like?
Jun 28, 2017 | Emerson NR303TT CD Shelf System
Turntable won't turn
Hi!
Without any other information (and assuming you've checked to make sure there is power to the turntable and that it is turned on), the likely culprit is the belt drive of your turntable. Most, but not all, turntables have a "belt" that looks like a big rubber band on the underside of the turntable that connects the turntable itself to the drive motor. If the band has slipped out of place, stretched too far from age or usage, or broken, the turntable won't turn. To find out if this is your problem, gently lift the "platter" straight up (it should easily slide back into place) and visually see if the "rubber band" is in place. If it is stretched too far or broken, a new one should be availble form Teac or your local electronics supplier. If, by chance, you have a direct-drive turntable (unlikely), the problem will probably need professional work.
Good luck and please let me know if this helps!
Bob
Oct 09, 2008 | Teac Audio Players & Recorders
Turntable problems
buy a better record player
Sep 27, 2006 | Emerson NR303TT CD Shelf System
Emerson NR303TT CD Shelf System Logo
2,040 people viewed this question
Top Emerson Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
