Question about Brother MFC 6800 All-In-One Laser Printer
Brother MFC 6800 printing all black.
All I get is black paper when I print or copy. It just started happening, not graduall. I have tried everything. Contrast does nothing, could it be the drum? There are no warnings comming up. THANX!!
  • NJMustang Dec 14, 2007
    Tried that. Yes, the scan lamp shines when I copy the sky. Any other suggestions?
    Thanx,
    J
  • Anonymous Dec 14, 2007
    error no.=18
  • Brother Master
  • 1,113 Answers
More likely the scan lamp, does it shine when doing a copy of the sky?
Posted on Dec 12, 2007
Hello - my Brother DCP 330C printer is printing horizontal faded lines on both color and Black and white copies. I have changed the toner in all areas but still no change. Could the problem be with the...
I have a brother MFC 3240C. My Black ink stopped printing(initially printed horizontal faded lines and gradually got worse), the other colors were printing fine. I tried cleaning numerous time( 50 -100 times over 1-2 weeks ). Still no improvement. The way I print now is:
1. I go to Printer Properties
2. Change Media type from "Plain Paper" to "Inkjet Paper".
3. Change Quality to "Photo".
This takes a long time to print 1-2 minutes per page. However, this works for me since this is my Home printer and use it for printing only few pages here are there.
Good Luck
RK
Jan 28, 2010 | Brother DCP-330C All-In-One InkJet Printer
I have a Brother MFC 240C printer that will not print black ink. I just changed all the cartridges. All the other cartridges print. I ran the clean cycle many times. No error messages just blank paper.
Good Luck
RK
Jan 17, 2010 | Brother MFC 240C All-In-One InkJet Printer
Brother 420CN printer will not print black ink. Have replaced the cartridge and after several cleaning cycles, it still will not print properly. Test Print shows colors are fine but black ink is hit and...
Good Luck
RK
Dec 20, 2009 | Brother MFC 420CN All-In-One InkJet...
When printing lines are running through the sentences.I have a brother mfc440cn printer
Good Luck
RK
Dec 09, 2009 | Brother MFC-440CN InkJet Printer
Black ink in brother 240c printer does not print new cartridge
This takes a long time to print 1-2 minutes per page. However, this works for me since this is my Home printer and use it for printing only few pages here are there. Better than throwing the printer.
Good Luck
RK
Nov 20, 2009 | Brother MFC 240C All-In-One InkJet Printer
Brother MFC-6800 - Mysterious Vertical Lines
This unit has a brom tube unit and need to be replacement . By repair tec.
Oct 05, 2009 | Brother Multi-Function Center MFC-240C...
MFC-6800 prints very very dark as printer gets warmer
It sounds to me that you are not using paper that is for Laser printers. Sounds like you have what is called thermal paper. If you hold a piece of this paper over a light bulb and it turns dark then it is thermal paper. Try using paper for laser printers only.
hope this helps
Jan 12, 2009 | Brother MFC 6800 All-In-One Laser Printer
Printer wont print black
did you try the 'cleaning' function yet?
Oct 28, 2008 | Brother MFC 210C All-In-One InkJet Printer
Printer
My Brother MFC-5460CN printer is doing the same thing. I installed a new black cartridge (I have it set to default greyscale) from a different company and it worked fine the first four or five days, but then it started printing light again.
Jul 22, 2008 | Brother MFC 6800 All-In-One Laser Printer
Brother MFC6800 not printing
To answer more effectively - how is the printer connected to the iMac? Is it a USB connection, a printer cable, is the MFC 6800 connected to a print server, an AirPor, etc? A second question I have is if you are trying any kind of tricky printing such as manualduplex printing.
Also, a shot in the dark...Is the Auto Reduction set to on or off? To check:
1. Press MENU/SET, 2 (Fax), 1 (Setup Receive), then 4 (Auto Reduction).
2. Press the up or down navigation key (keys located above and below the
MENU/SET key) until the display shows "Reduction: ON?".
3. Press MENU/SET.
4. Press STOP/EXIT.
Another item to keep in mind:
You can use three sizes of paper for printing your faxes and
copies---letter, legal and A4. When you change the size of paper you ha
ve loaded in the Brother machine, you need to change the setting for the paper size so your Brother machine can fit the incoming
fax on the page. To set the Paper Size:
1. Press MENU/SET, 1 (General Setup), then 1 (Paper Size).
2. Press the up or down navigation key to select LETTER, LEGAL, or A4.
3. Press MENU/SET.
4. Press STOP/EXIT.
Nov 20, 2007 | Brother MFC 6800 All-In-One Laser Printer
Brother MFC 6800 All-In-One Laser Printer Logo
212 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
