Canon c3200 copier
Need to replace transfer unit can you help
    An user who is expert in 3 categories / brands.
  • 1,362 Answers
Posted on Dec 12, 2007
How to replace the transfer belt on a c3200
that procedure is complicated, you should refer to the service manual for appropriate procedure
Apr 28, 2014 | Canon imageRUNNER C3200 Copier
Printer prints with red smudges
Sounds like its a magenta drum going bad. It could also be the transfer cleaning blade assembly, or the transfer belt needing replacement. Do you know if any of these items have been replaced. Drums usually last around 40,000 prints. Transfer belts 300,000 and the blade 100,000. Hope this helps.
Aug 22, 2012 | Canon imageRUNNER C3200 Copier
Problem with the Canon imageRUNNER C3200 Copier In printing colors are 1 mm apart from each to other
You need to clean the rollers in the "Internal transfer belt". I'd suggest you contact Canon service, because you could easily break the thin Transfer belt if you do it wrong. Temporary solution is to turn the machine off and then on, following a FULL color calibration.
Feb 03, 2011 | Canon imageRUNNER C3200 Copier
Canon IR C3200--error code E000020-01b0 explain this code please
Hi there
Error code E000020-01B0
That code relates to the yellow drum unit.
The unit was probably damaged taking it in an out.
Needs to be replaced.
Or try.
1. Information UPDATE UPDATE - the Drum units are as follows:
Yellow - 746
magenta - 215
Cyan - 758
Black - 9
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 04, 2010 | Canon imageRUNNER C3200 Color Printer
Canon IR C3200 Out of registration. When i print out a test print the colors are all out of sink and not lining up on top of one another. was running fine and then it started having this problem
the cause of the problem is ,the transfer belt is not rotating properly ITB rollers must cleaned throroughly (cleaned by isopropyl alcohol) to prevent slippage of transfer belt that causes mis alignment /misregistration of color,but copying BW is ok,In other words ITB unit needs servicing
Jul 16, 2009 | Canon Office Equipment & Supplies
My Canon IR c3200 started to print olors out of focus... I read 3 manuals through, transfer belt is clean, auto calibration process gives nothing, horizontal lines printed fine but colors misplaced in...
you have miss regrestion there are several ways to correct this process 1-go into service mode -function-clear-dc con -ok then take machine off unlug from wall outlet replug turn machine on 2-replace your itb assy. 3-there is another way but you have to be next to the machine and fimilar with second level service mode.
Oct 21, 2008 | Canon imageRUNNER C3200 Copier
Removing transfer belt
The Intermediate Transfer Belt (ITB) slides out from the right hand side. Open the manual feeder, pull out the right side transport, remove one screw and remove the cover behind the manual feed door, lift the sensor bracket above the transfer belt,lower the handle inside the front cover and pull the ITB straight out the right hand side.
May 24, 2008 | Canon imageRUNNER C3200 Copier
ImageRunner c3200 Color Registraton
With my experience, it's not the registration nor calibration problem, it's either transfer belt is bad or inside the transfer belt is dirty or dusty as well as transfer rollers. here is what I do first
take the transfer belt unit out of the machine, take transfer belt out from the unit, clean inside of transfer belt with damp cloth and rubbing alch. clean all rollers and reinstall.
What it is if the transfer belt and transfer rollers are dirty and dusty, it slips and make it like it's not align. I think most of time it fix the problem with my exp. if not replace new transfer belt
Jan 15, 2008 | Canon imageRUNNER C3200 Copier
Copy Problem
this could be two things first, the transfer belt is slipping. It can be cleaned on the inside of the belt and the rubber drive roller. second, the laser units need to be timed, its not hard to do but a service tech will need to do both. it should be running great. the 3200 is a great box
Dec 06, 2007 | Canon imageRUNNER C3200 Color Printer
