Question about Durabrand DWT2405 24" TV
TV will only show Air Channels
I am not sure what happened, but we moved the tv into my daughter's room and now it will only show the air channels? Any advice on how to solve this problem. The remote that we have is a universal remote and while acessing the menu there isn't an option to switch from air to cable...please help!!
  • Anonymous Mar 25, 2014
    need to know how to acess the menu
  • 3 Answers
TRY HOOKING THE CABLE DIRECT INTO THE TV AND TUNNING IT AGAIN.
Posted on Dec 12, 2007
No dvb signal found, please click ok to tune. Tune then does not work and no channels.
If you have another TV fed from the same antenna, I assume you have a splitter/distribution amplifier because you know you cannot just join two cables together don't you?
It is more than likely the splitter/amplifier, cable or connections rather than the TV but to make sure you must move the TV in the other room and try it on the suspect cable before condemning the TV.
Signal problems are usually due to water ingress and this could have happened on just one cable.
Failing that, the TV input could have failed. It is not common but does happen now and then.
Jun 03, 2015 | Panasonic Viera TX-32LX70 32 in. LCD TV
Hello! I recently moved my Toshiba 26lv610u-t from my father's place to my own. It was a short trip as we live across the street from each other. When I connected the cable to the TV, I found that all...
There are no analog channels anymore as far as I know, if you mean the channels that are local and provide an off the air signals, you need to connect an antenna for off the air signals, it may be possible that at your father's place the off the air signal was strong enough to receive them. Try going in to the menu signal type select "Air" to see if that makes a difference, of-course you will lose the cable channels until switch back to "Cable" .Hope this helps, KA
May 07, 2017 | Toshiba 26LV610U LCD TV
I just moved into my college dorm room and got the tv all hooked up to my cable outlet, but n=my channels dont show up. is there programing i need to do to make it happen?
Yes,Used ur tv remote.Push the button said Menu.Go into ur tv MENU go to SETUP go down to Ch.setup or something like that on down to all the option of the SETUP menu.Look for 2 words like AIR or CABLE.Pick CABLE if ur college dorm offer pay tv services.Press the Enter button to scan for pay cable channels after it done scanning for channels tv should have picture and working.
Aug 17, 2011 | Dynex DX-L26-10A 26 in. HD-Ready LCD TV
Can't access all the channels. I moved tv from one
You didn't say what model number, but check the setup menu to make sure it is set for cable (if you are using cable) and not AIR. Otherwise let me know the model number and what you are using for signal (cable, satellite, etc.)
Jul 04, 2011 | Sharp Televison & Video
Moved, no longer have cable and not getting any channels via attenna. Is it just bad reception or do I need a digital converter because of the change to digital stations?
Could be bad reception and or make sure the tv which was in the cable mode when you had cable now needs to be in air or antenna mode. IF you have another tv that works ok then you will know the channels just need to be reprogrammed for over the air signal. Go into the menu of tv and find program channels and switch to air or it might say antenna..
Oct 17, 2010 | Akai CFTD2083 20 in. TV/VCR/DVD Combo
Can this TV show local channels
Yes,Go to the tv menu,go to SETUP,go down to CH.press and select AIR.Will scan for over the AIR channels,u will get all the free air channels.After this u will get all the local channels,and other free air channels.
Apr 25, 2010 | Dynex DX-L26-10A 26 in. HD-Ready LCD TV
My remote is nt working for channels
before you try to change the channels, firts look for a button that says tv/video `press it ( some times more than once ) depending on how manny video jacks on your tv until it shows tv again, good luck
Dec 18, 2009 | Televison & Video
Have extended basic cable-all the channels not showing
Cable co. can place stations at any # they wish... my antenna CH3 is carried on 252. I have to have a CH guide to keep-up.
Feb 12, 2009 | Orion1934 19" TV
Tobshiba tv stays in one channel.
You might need to go into the menu options and set the input from cable to air or vice a verse. The tv in my kids room is like that if it's set to cable with no input at the cable jack then it only gets one channel even after you try to add channels.
Dec 06, 2008 | Toshiba 36A50 36" TV
Settting tv to a higher channel for cable`
Most TVs have a choice of air or cable in the menu portion of the tv. press menu go to setup and from there you should see an option that says air/antenna or cable. You will have to either toggle to get the air selection or highlight it. Then you should be able to get to channels you need.
An easier solution may be to go to the Dish receiver that controls the image on the tv you can't get to 73. With tv and satellite on (make sure both green and blue lights are on) press on your Dish remote #1 with the green tab on the bottom the following sequence: MENU - 6-1-5. tHIS WILL TAKE YOU TO THE MODULATOR SET UP PAGE. Move the highlight from cancel to the mode section an highlight AIR and press select. Then move the highlight back to the right to DONE and press select. Press cancel three times or view live tv. then go to the other tv and put it on ch 60.
Hope this assists you.
Sep 09, 2008 | Symphonic ST420FF 20" TV
Durabrand DWT2405 24" TV Logo
75 people viewed this question
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
