Question about Muratec MFX-1430 Copier
Reset drum counter on a muratec mfx 1430 - Muratec MFX-1430 Copier
    Genius:
  • 1,218 Answers
Drum counter is reset by installation of a "NEW" drum.
There is a small fuse at the rear of the drum on the top( you will see the 2 brass contacts) When a new drum is installed, the fuse blows and resets the drum counter. Installing a used drum will not reset the counter as the fuse is already blown.
Posted on May 27, 2010
SOURCE:
Reset code for muratec mfx 2010
Is it the drum counter? You can only reset when you put a new drum it it.
http://www.fixya.com/support/t18621752-muratec_mfx_2010_reset_drum_amp
Jan 04, 2016 | Muratec Office Equipment & Supplies
Printing problem
You cannot use the "add-printer" wizard to install the 1430...unless you got the machine with the PCL Print option installed; the unit comes standard with only GDI printing.
For the GDI printer port to be created on your PC you must install the machine using the installation disc provided with the machine.
Jul 27, 2010 | Muratec MFX-1430 Copier
Muratec mfx 1300>> CAN I reset A "replace
YES....try the following...... Press PROGRAM,*,*,I(thats capital letter i) then press ENTER.
SHOULD RESET IT.
Jun 16, 2010 | Muratec - MFX-1300 Copier
Where can i find document rollers for document feeder?
document rollers is located immediately beside entering the paper or on paper if you use presenting with pallet
Oct 08, 2009 | Muratec MFX-1430 Copier
My computer does not detect MFX 1430 printer. I think I need the usb driver for the usb cable.
Yes you will need drivers to run a "Local" set-up which is what a usb connection is called. Install drivers BEFORE connecting usb cable. You can download drivers from Muratecs web site www.muratec.com
Jun 30, 2009 | Muratec MFX-1430 Copier
Muretec mfx 1430 streaking through the adf and its not the **** glass. Off the glass looks fine have swamped out the whole feeder twice same problem.
Hello sir; Let's try two things , 1st, make a copy go through by ADF. 2nd, make another copy direct from the glass. if 1st one coming out with streak line that's mean on the left hand side of the plateform have a piece long strip glass need to clean.
if streak line coming out from 2nd copy that's mean you need to replace drum cleaning blade.
Mar 13, 2009 | Muratec MFX-1430 Copier
How do I reset the drum counter on a Muratec F320?
Ok, this is how I resolved it for my fax machine.
I powered down the fax, removed the new drum and reseated it.
When I powered it back on the counter reset itself as it is supposed to.
Nov 12, 2008 | Muratec F320 Plain Paper LED Fax
Problem scanning on MFX-1430
I am not sure why all scan to email is deleted, but you cant use scan-to-email or any of those scanning features using a USB anyways. Must be connected to the network
If connected by USB, you can download some twain scan utility (purchase one or download free one online) on your computer and install/set it up to use the Muratec as the scanner. Anytime you want to scan, open and use that utility.
Jun 22, 2008 | Muratec MFX-1430 Copier
1,543 people viewed this question
Top Muratec Office Equipment & Supplies Experts
Scott Yeoman
Ed
Ed
Adorjani Laszlo
Are you a Muratec Office Equipment and Supply Expert? Answer questions, earn points and help others
