1994 Dodge Caravan Logo
Posted on Sep 15, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where can I find a diagram to put my serpentine belt back on my 3.3 L 1994 Dodge Caravan
  • owlman1969 Sep 15, 2009
    There is no routing diagram anywhere on the vehicle and I have no owners guide either?
Anonymous
Level 3:
  • Master 1,111 Answers
  • Posted on Sep 15, 2009
Anonymous
Master
Level 3:
Answers
1111
Questions
Helped
453704
Points
3685
There should be a diagram directly on the core support under the hood or some manufacturers put it under the hood itself ...also if not there your owners Manuel may list it if not check your local parts store or even the library on the subject
  • Anonymous Sep 15, 2009
    try wiki site or Google it
Anonymous
Level 3:
  • Master 484 Answers
Anonymous
Master
Level 3:
Answers
484
Questions
0
Helped
270779
Points
1505
The manufacturers place a label on either the underside of the hood or on the crossmember at the front of the engine bay with the belt routing diagram.
Regards,
matt
  • 1 more comment
    You're welcome. All cars with serpentine belts have the diagram under the hood. It isn't our fault if you don't see it. We answered your question, why are you criticizing us?
  • Anonymous Sep 16, 2009
    Enter your car's info on this page. The listing for the serpentine belts are on the left and they aren't highlighted, so you have to look kinda hard for them.
    Hope this helps,
    matt
    It is a LOOOOONG list of engines on that model, so make sure you pick the right one. There are FlexFuel, Natural Gas, etc. engines on the list, so really scroll through.
    matt
1994 Dodge Grand Caravan. Does anyone know what could cause the serpentine belt on a Dodge Grand Caravan to come off every time it rains?
Tensioner badly adjusted or pulleys are misaligned.
Take it back to the shop and ask them to fix the tension under the repair warranty.
There should be enough tension that the belt can't jump the pulleys. There is a small chance is is misrouted.
https://www.2carpros.com/diagrams/dodge/grand-caravan/1994
https://www.google.com/search?q=94+dodge+grand+caravan+serpentine+belt+diagram
Putting a serpentine belt back on a 1999 Dodge Caravan
You can look that diagram up in the DAYCO belt routing guide at this link.
Diagram for 2010 dodge caravan serpentine belt 3.3l
i need to see a diagram for a 2010 dodge grand caravan with a 3.3 liter It has air condtion
1helpful
2answers
We need to replace the serpentine belt on our 1996 dodge caravan but the diagram has been removed.
Get the replacement belt, and then note the pulleys that have smooth finish, and note the pulleys that have the grooved finish.
Just 'thread' the serpentine belt, one pulley after another alternating between the smooth and grooved until the last remaining pulley is the tensioner pulley.
Use the breaker bar to allow the pulley to accept the belt, and you're done.
2helpful
Fix serpentine belt on 1998 dodge Caravan
If it's the diagram you're looking for, click on the link below and enter your engine size. You will be directed to a page that has a Belt Routing Diagram. Select the appropriate one (some Caravans do not have AC) and you will receive the diagram for your vehicle.
1998 Dodge Caravan Serpentine Belt Diagram
5helpful
3answers
I need a 1998 Dodge Grand Caravan serpentine belt diagram.
The belt routing diagram is shown on a decal located on thehorizontal metal support above the radiator and under the hood support rod (passenger's side near the coolant overflow tank).
PT Stanley
2helpful
2answers
Serpentine belt diagram:
The belt routing diagram is located on the top radiator cross member by the hood latch. You should see it when you open the hood. If it is not there, all Chrysler, Dodge, and Plymouth minivans, from 1993 to at least 1999, used the same 3.3L engine setup, so find someone with one and look for the diagram where I described.
Top Dodge Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Dodge Expert? Answer questions, earn points and help others
