Question about LG L1720PQ (Black,Silver) Monitor
Monitor locked in energy saver mode
When I turn on my computer, my monitor light will turn blue and in seconds turns to yellow (energy saver) and I can not get the monitor to come on.
  • coloneld1 Aug 30, 2008
    LG1722PF It's not the computer but the monitor. Need help. Anyone else have this problem?
  • 51 Answers
If you have another computer available try to hook the monitor to it...that will help you determine if it is your monitor or your computer which has the problem
Posted on Dec 12, 2007
How to disable energy saving on KitchenAid Range
The Energy Saver Mode deactivates the display to reduce energy
To Activate the Energy Saver Mode:
1. Press and hold OPTIONS for 3 seconds. "Energy saver on."
will appear in the upper text area.
2. The setting will be activated after 5 minutes.
Any cooking function may be used with the range in Energy
Saver Mode by simply selecting the desired function.
To Deactivate the Energy Saver Mode:
1. Press and hold OPTIONS for 3 seconds. "Energy saver off."
2. The clock will reappear in the display, and the range can be
operated as usua
Oct 10, 2012 | KitchenAid Ovens
Why no video
a HP monitor. as old as 2006... (o0ps)
read the manual yet? on "power saver modes" turn off them?
i bet you dont know spec, on caps. it's not published by HP ever.
most are +80% - 20% for filters. (ever seen that?)
so a 100uf can read 180uF, or 80uf and is IN SPEC.
but no caps stated, by you, lots there are...
my guess you are
looking for the caps used in china long ago that all failed, every one.
first off you never fully stated whats wrong, in DETAILS.
first have good running pc , with live VGA output (using VGA are you)>? unstated...
the MON, will now live sync, now , Horz and vert, on both pins
the OSD screen now works, if not the monitor is bad.?
or see No/syn, no sig, out of range or no input errors.
Monitor Going to Sleep
see page 34? in your manual yet?
and page 31, turn of power saver ?
if OSD is dead, say so first.
OSD can be locked. push mon menu button for 10sec, now unlocked
then go to OSD screen
Power-Saver Feature
When the monitor is in normal operating mode, the Power li
ght is aqua-white or green (depending on model) and the
monitor uses the normal watts of power. For power us
age, refer to "Technical Specifications" (Appendix B).
The monitor also supports a power-saver mode that is
controlled by the computer. When the monitor is in the
reduced-power state, the monitor screen is
blank, the backlight is off, and the
Power light is amber. The monitor uses
minimum power. When the monitor is "awakened," a brief
warm-up period occurs before the monitor returns to
normal operating mode. The energy-saving reduced power stat
e activates if the monitor does not detect either the
horizontal sync signal or the vertical sync signal. The powe
r-saver feature must be activated on your computer for this
feature to work, << read that carefully?
turn this off ? first?
osd-vboix4tqi2kfzapulla5cn4x-5-0.jpg the early models of the monitor
had CCFL back lamps, and the 2 inverters are on the main power board. left side here
Sep 28, 2017 | HP Compaq WF1907 19" LCD Monitor
How do i turn off energy saver toshiba e studio 203d
When u press the Energy Saver button, The machine will enter Energy Saver mode where all the display lamps are light off. Just leave Energy Saver mode, just press again the Energy Saver butto
May 18, 2012 | Toshiba e-studio 203sd
Monitor switches on then goes into stanby
No input from Video card, try to connect second video cards head to your monitor.
Apr 19, 2010 | Dell E173FP 17" LCD Monitor
Child lock to turn off
Well you can please follow the below steps -
1. Locate the "Energy Saver/Dry" button on the dishwasher. The location of this button will be different depending upon the specific model number of the dishwasher, but should be easy to spot. If you have trouble finding it, you can check the diagram in the manual of your dishwasher for the exact location for your specific model.
2. Press and hold down this "Energy Saver/Dry" button for at least four seconds. Make sure that you do not release the button until at least 4 seconds have passed, otherwise the lock will not become disabled.
3. Check to make sure that the child lock indicator light has turned off. If this light is no longer on, this means you were successful at turning off the child lock. If the light is still on, repeat the process, but try to press and hold the "Energy Saver/Dry" button for a few seconds longer. If it still doesn't work, there may be a more complicated issue with your dishwasher. Consult your manual, or call to the manufacturer or repair man to determine if there is another problem with your dishwasher.
Good Luck!!
Mar 02, 2010 | KitchenAid Dishwashers
Dell E173FP Monitor requires unplugging/plugging back in to wake
Perhaps your computer is hibernating instead of going into standby which takes a little longer to wake up from. While you are playing plugs and cables it give it enough time to come out of hibernation.
When the computer is in this mode the USB ports turn off which disables keyboard and mouse so the only way to wake up the computer is to press the power button on the computer itself.
One tell tale sign a computer is in hibernation is that the power light on the computer will slowly blink.
I hope this helps.
Aug 08, 2009 | Dell Computers & Internet
Child lock shut off
Hold the button with the lock until the light turns off. Consult the manual.
Can you provide a model number?
Feb 18, 2009 | Dishwashers
Sharp light turns green thern turns yellow screen goes black
it is going into sleep mode, good luck with this.... i am currently asking how to get my hard drive to quite putting my monitor into sleep mode.
although it hasn't worked for me because my screen stays black, one of the options given to me is to try to start in safe mode and then adjust your settings to "never" on the energy/sleep/hibernate mode
some one else suggested that i remove and reseat the video card
hopefully one of those will work for you
Feb 14, 2009 | Sharp LL 172A-B 17" LCD Monitor
ENERGY SAver is stuck on
I know it's an older post, but you still may be waiting an answer:
What is probably happening is Your power board is failing to maintain power enough to run the bulbs and the rest.
That is why it takes long to start up and why it goes into sleep mode.
Does the power button stay lit (getting signal) or turn to amber (sleep mode) or does it flash.
Sep 04, 2008 | Proview PL926WBi 19" LCD Monitor
Monitor in power saver mode
try to restart your computer in safe mode and see if that affect the monitor, also you may have the setting to go into hybernation quicker, to save the most energy, check those settings
Jun 06, 2008 | Computers & Internet
LG L1720PQ (Black,Silver) Monitor Logo
118 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
