Question about All-Pro Kerosene Garage Shop Heaters - All Pro PK115T Forced Air Kerosene Space Heater
All-Pro Kerosene Heater
Where can I find parts for a 60000 BTU forced air heater. Mine has a locked up fan motor.
  • Anonymous Dec 24, 2007
    Where can I find a Webster ignition transformer 120V pri. 10000V sec. This is on a Kelley Hot Shot space heater. I cant find any parts for this heater. Model # 120KSH.
I have a 100,000 allpro Kerosene heater I get sprake but won't lite I need help Thanks
Posted on Dec 03, 2008
  • 188 Answers
I manuafacturer has now closed down, so ALL-PRO, Master Heater, Universal, and Reddy Heater parts are getting harder to find. I have found that have all the parts I was looking for. I suggest you check them out.
Posted on Mar 06, 2009
  • 625 Answers
Most kerosene and propane bullet heaters are the same no matter which manufacturer made them. go to www dot desatech dot com for parts
Posted on Dec 12, 2007
Coleman evcon electrical furnace doesnt force air intermittently
It sounds like the fan is not functioning. With the breaker, SSU, and/or power off check the wiring, tighten any loose wiring, and make sure nothing is blocking the fan from spinning. Check to see if it will spin by hand, if there is access. If it does, and you have power, then the fan motor may need to be replaced.
Does this help? Let us know.
Ponder/Meditate/Pray for Peace.
Mary Oliveau { hugs }
Nov 30, 2013 | Coleman Propane Forced Air Heater...
My Master forced air kerosene heater fan motor hums but wont turn over, I tried replacing the capacitor with no luck. Do you know what the problem may be
Be sure you replaced the capacitor with an identical one. If it is and you have the right voltage to the motor then the start windings in the motor are bad and the motor will have to be replaced. But like I said, make sure the voltage and micro-farad ratings of the replacement capacitor are the same as the original.
Feb 03, 2011 | Milwaukee Tool Master Heater Pro Series...
Have a 115000 btu forced air kerosene heater.. used maybe 12 times over 3-4 years. when turned on motor is binding somehow. i maqnually turned blade and does not spin easilly. whats causing this?
Unfortunately it is the lack of use that has hurt this unit. Try using PB Blaster on the bearings and working the fan by hand until it loosens up. It will loosen up eventually, when it does give those bearings lubercation with a light oil. From running and shutting down and not using it for a while I would think that things got a little rusted up inside, this happens due to condensation forming on the warmed parts then it rusts. You can check the fuel pump but they usually are not an issue with the heaters.
Dec 27, 2010 | Reddy HEATER R115 115,000-BTU PORTABLE...
I have a All-Pro 115,000 btu multi fuel heater. When first plugged in fan runs, fuel sprays out the nozzle but heater won't fire. Any suggestions?
You probably have already checked this but is the ignitor trying to fire or not working at all ? Just curious. Thank you
Dec 17, 2010 | All-Pro Kerosene Garage Shop Heaters - All...
Hello i havent Used my ready heater 60000 btu since last winter. It was working fine when i unpluged and emptied when i plug it up i hear a hum and nothing else no blower or anything....could ude...
The fan motor is setup...
Tear it part and get some WD-40 worked into the motor at the shaft end... then when you get it spinning freely... get some light motor oil worked into the bearing...
Works best if you can tip the heater back so the WD-40 and oil naturally run back into the motor...
Dec 13, 2010 | Reddy Heater-30-55,000 BTU Variable
Have a Evcon Coleman Furnace shows three green blinking lights but will not ignight what could be wrong
I have had the same problem with mine for the last 2 years. Remove the motor on the side of the furnace(usually held on by 3 screws) and turn the fan blades inside by hand. after sitting all summer it seems to get stuck. If it moves freely, replace the motor and try to start it again. This fixed mine the last 2 years! Hope this helped.
Sep 29, 2010 | Coleman Propane Forced Air Heater...
An All Pro 60000 btu kerosene heater.
The fuel filter is clogged you need to clean it. Mine was doing same thing, easy fix.
Jan 05, 2010 | All-Pro Kerosene Garage Shop Heaters - All...
All-Pro Kerosene Garage Shop Heaters - All Pro PK115T Forced Air Kerosene Space Heater Logo
2,814 people viewed this question
Top All-Pro Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
T bone 1963
Are you an All-Pro Heating and Cooling Expert? Answer questions, earn points and help others
