Question about GE WSM2480DWW Unitized Spacemaker Washer and Gas Dryer
Fixing a clogged pump on GE Profile washer
What is the quickest way to access the pump to check/clean for clogging? my ge spacemaker washer/dryer combo spins but will not drain. i believe my pump is clogged, so i removed the front panel and have access to the pump, but the machine is full of water so i am afraid of leaking - what to do?
  • 4 more comments
  • UP TIGHT May 11, 2008
    how do i get to the pump, there is a panel on the back but kind of up high, do i turn the washer on its front side, and look into the bottom to access the pump ? thank you UP TIGHT
  • brosello Dec 23, 2008
    my washer makes a squeaking sound while on the spin cycle and doesn't seem to spin as fast as it used to. When I open the lid it stops spinning very quickly (unlike before) The tub also does not release all of the water. Is it the pump or the belts? It seems to work well during the wash cycle though
  • Anonymous Jan 02, 2009
    There is water left in the washer after the cycle. How do I fix this?
  • rmbalas Jan 07, 2009
    water flooded the condo and the hallway. Should I get this fixed or cheper to buy the new one???
  • Anonymous Mar 30, 2014
    My washer has some water leaks,
    after each washing operation.
  • Anonymous Apr 01, 2014
    Want to replace lid switch that controls drain and spin cycles on washer/dryer combo ge
    Novelist:
    Champion:
  • 244 Answers
Waht u need to do is get a bucket now take the outlet hose and place it into it low to the ground if water comes out then it will be that your pump is faulty and needs replacing but if it doesnt the only way to do it is towels on the floor and with a low pan place this under the sump hose which should be in the middle of your drum which then leads to the pump pull slowly but not enough for the water to push the hose of do this until empty the only other way is to take it outside and pull the outlet hose of this is the quicker and dryiest out of them all but do do the first part to c if the pump is faulty m8
Posted on Dec 12, 2007
My GE Spacemaker dryer will run but the washer will not start in any cycle (stacked unit)
It looks serious problem. You should go to your nearest repairer to solve the problems if you don't want to stay without your washer.
Mar 13, 2014 | GE Spacemaker Washer and Dryer Electric...
Wsm2700dawww dryer will spin laundry still wet
Possible that the speed is of the spin is not enough, check the belt , check for friction to the shaft in the washer.
finally check the drain valve /pump as if there is water logged on without flushing then the valve is clogged or dirty.
Aug 23, 2012 | GE WSM2480DWW Unitized Spacemaker Washer...
My washer will not drain. I heard that this could be caused by a loose belt on one of the pumps. What is the best way to access this?
Sorry to read about your problem, I hope this helps you out.
Their is no belt for the water pump..you may have a defective or clogged pump
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
323m3m
Dec 21, 2010 | GE Spacemaker Washer and Dryer Electric...
My GE Profile Harmony dryer won't dry. The drum is turning but the clothes just won't dry. Circuit breaker is not tripped.
Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance. Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct.
Dec 01, 2010 | GE Profile Harmony DPGT750EC Electric...
The GE Profile Dishwasher does not drain completely. The bottom drain shows no obvious clog and the screens are clear. The overflow drain in the back of the washers the only reason the dishwasher does not...
Uncouple the drain hose connection under the sink and use a wet/dry vacuum to **** out the drain hose and the stub on the sink drain plumbing to clear any possible clogs. There may be a blocked check valve near the pump that might have to be cleaned or replaced. Check the hose itself for any kinks or collapsed section. There might be a damaged drain impeller on the pump. Hope this helps!
Mar 11, 2010 | GE Profile PDW8400J Built-in Dishwasher
GE profile dishwasher (2004) will not drain properly. Is the drain clogged? If so, how do I open and clean it?
check the hose first alot of times the hose canbe clogged . disconnect the hose hit the drain on the machine and normally the clog will be seen. if that doesnt work then its the drain pump thats clogged.
Mar 06, 2010 | GE 24 in. Profile PDW9880JSS Built-in...
Washing machine will not drain
Hi
The drain line is probably clogged. Maybe that a sock or other piece of clothing get between the clothes tub and the outer tub that holds the water. In this case it may then get into the drain hose that's attached to the pump.Remove the hoses from the pump and pull the item out. In case it clean there, check the outer tub port- open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then,try to remove the clothing through the port.
Thanks for contacting Fixya.com
Oct 11, 2009 | GE Spacemaker Washer and Dryer Electric...
Pump leakage
yes but the coin trap just may be misaligned try to open it and lock it back in place...let me know
Sep 27, 2008 | GE WSM2480DWW Unitized Spacemaker Washer...
Not Draining
Your pump, or the hose between the drum and pump, might be clogged.  Check it out.  You might find coins from unemptied pockets.
Oct 14, 2007 | GE WSM2700W Unitized Spacemaker Washer and...
Take a putty knife and slide it in between the front panel and top to pop the clips that hold on the top. Remove the front panel and you will see the pump down in the front corner. Remove the hoses (watch for water) and you should see any clog. Check hoses and drain line (home) to be sure there is no clog in those while you have it apart. Be sure to unplug your machine before working on it as well. Good Luck!!! Jim
Sep 09, 2007 | GE Profile Prodigy WPSE4200A
GE WSM2480DWW Unitized Spacemaker Washer and Gas Dryer Logo
934 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
