Washing Machines
Problem for Washing Machines
Generic problem for all Washing Machines
We have a Kenmore Elite Calypso, it is not...
By samgalvan on Sep 15, 2009
We have a Kenmore Elite Calypso washing machine, we get an ''ld'' or a ''ca'' displayed every time we try to wash. This occurs 3-5 minutes after starting the cycle.
What does ''ca'' and ''ld'' mean? and what can I do?
Thanks
Best Solution
posted on Sep 15, 2009
Helpful)
jmorganti
Rank: Guru
Rating: 89%, 378 votes
"Ld" (Long Drain) flashes
Is the drain hose kinked or clogged?
Press STOP/CANCEL to clear the display.
• "CA" or "Cl" (Current Limit)
Is the washer overloaded?
Here is a manual:
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0102048.pdf
See page 17.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
Very Helpful)
rylee_smith
Rank: Guru
Rating: 88%, 1044 votes
Hi
Thanks for using FixYa. Error code LD means Long Drain. It flashes when washer takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets.
Error code CA means Average current limit. This error code will display if the load of clothes is more then the normal load. Also if current limit breaches then status signal comes back from the motor controller. The unit will return to standby mode and display CA. Average current trip occurs if the current draw at the motor windings is greater than 5.55 amps in 2 seconds. This error occurs if there is a problem with the drive motor, thermal protector or motor controller. Over-loading the unit may cause this problem.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Was this helpful?
Yes
No
Solution #3
posted on Dec 08, 2009
Not Rated)
Mook7898
Rank: Apprentice
Rating: 0%, 0 votes
I have a ld code how do I fix it
Was this helpful?
Yes
No
Popular Solutions for Washing Machines
Questions and Unsolved Problems for Washing Machines
Answer
whirlpool ultimate care ii washer LSQ9110PW2
Answer
Hello I have a Top Load washer model # sm 8525492, Before I got there My wife tried washing some... (More)
Answer
My Kenmore HE4T washer is leaking from the bottom, towards the front. This happens during the rinse... (More)
Describe your Washing Machines problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washing Machine Experts
Top Washer & Dryer Repairmen
in Sedona, AZ
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
