Question about Refrigerators
Replacement of Light globe in Ice Dispenser
I have a Side by side Jenn Air fridge and the light has blown in the ice dispenser. I have taken the light to several lighting and electrical places but they only seem to have the 7 watt globe and not the 5 watt globe which is the one I took from the fridge. Does anyone know where I can get a replacement globe from? thanks
USE LESS THAN 5W GLOBE IF AVAILABLE
OR
7 W IS A STANDARD GLOBE BEING NORMALLY USED, WILL & SHOULD NOT AFFECT THE POWER CIRCUIT AS PER MY EXPERIENCE
BEST WISHES
Posted on Dec 12, 2007
  • ASHOK KUMAR Dec 12, 2007
    YOU CAN EVEN USE 15 WATTS/240V GLOBES IN FREEZER SECTION,
    HOWEVER 7 WATTS WILL BE EXCELLENT.
    FOR SOURCE OF SUPPLY GO TO "GOOGLE" SEARCH FOR "GLOBES SPECIFY WATTAGE & VOLTAGE".
Jenn air french door water dispenser broken
You have two sides to your 67006531 Dual Water Inlet Valve, so it is very possible the side that controls the water flow for the dispenser is defective. Replace the 67006531 Dual Water Control Valve and I believe your fridge water will work fine.
I will be here should you have more questions, Thanks Sea Breeze
May 20, 2012 | Jenn-Air JFC2070KRS Bottom Freezer French...
Ice maker doesn't work. changed filter. light on ice maker door still on.
You need probably to change the dispenser solenoids which swith water on dispenser
Apr 05, 2008 | Jenn-Air JCD2389G Side by Side...
I have a Jenn-Air refrigerator #JCD2389DES. The ice maker became stuck and kept delivering ice cubes even after dispenser was released. I finally opened the freezer door and got it stopped. Now it...
Yes it could be either, BUT I would go back and make sure that everything you did to stop it the first time is undone. Is everything setted correctly? Is the switches in the right place?
Neither the solenoid or the microswitch could cause the problem you had before, so I would suspect something is not right with the ice maker itself.
Jun 16, 2011 | Jenn-Air JCD2295HES Side by Side...
We have an ice glacier building up behind and below our ice maker inside our Jenn Aire side by side refridgerator model JRSD 2450.
WATER LEAKS ON YOUR WATER SUPPLY CONTAINER TO THE WATER DISPENSER OR CONDENSATION PROBLEM RELATED TO FRIDGE DOOR FAULTY SEAL
Nov 09, 2010 | Jenn-Air JCD2389G Side by Side...
The temperature alarm is beeping and the fridge and freezer continue to get warmer.
Hi i have a jenn-air side by side ice & water dispenser and the ice & water bottons keep beeping and flashing, what does this mean
Jan 26, 2010 | Jenn-Air JCD2389G Side by Side...
Jenn-Air side by side you already answered once!
hi thanks, it could be the water valve at the back of the fridge a fridge with a water dispenser and ice maker has 2 solenoids on 1 valve 4 wires if you don't have a water dispenser just the ice maker then olly 1 solenoid 2 wires you can check by using an old electrical cord install on cord the connectors you see on the valve disconnect the wires that are there now and install cord you just made up disconnect fridge before you do this if the water comes out with this new cord you need a ice maer if it does not. replace the water valve thanks the appliance doc
Sep 17, 2008 | Jenn-Air JCD2389G Side by Side...
Ice and water hook up for Jenn-air JSD2789GEB
The water coupling is usually located at the bottom rear of the Fridge and will require an installation kit (easily obtained at your local Home Improvement Store) and tapping into an existing copper cold water pipe (the kit will/should includes the line tap).
Apr 26, 2008 | Jenn-Air JSD2789GEB Side by Side...
Jenn-Air "replace filter" light
each dispensor is a little different, but youll need to hold down a button(perhaps even a combonation of 2) for3 seconds to "reset " the filter indicator.
Mar 19, 2008 | Jenn-Air JSD2789GEW Side by Side...
Whirlpool side by side fridge freezer
 if posible try turning off over night, if its ok when you start it back up after 24hours, defrost not happening, ice builds up air flow is restricted
Oct 18, 2007 | Whirlpool ED2FHEXN Side by Side...
Refrigerators Logo
167 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
