Question about Microsoft Xbox Console
Xbox wont work
When we turn on our xbox the ring around the eject button flashes red and green over and over again. we tried turning it off and on a whole bunch of times and it still wouldnt work. we even tried everything on fixya.com
The thing where the disk goes in wount open hit top of the xbox beacus this was happeanig to me to
Posted on Dec 12, 2007
When i turn my xbox 360 on the green light stays on for 30 seconds and then turns red and wont play what would be wrong
While on the RED light. Press and hold the "SYNC" button (don't let go if it during any of the stages). Now press and release the "EJECT button. Note the amount of flashing lights. Do this three more times (still holding the sync button) each time noting the amount of lights that flash. This will give you a total of 4 numbers. Go here to see what the issues is. https://xbox-experts.com/
Oct 19, 2014 | Microsoft Xbox 360 Console
Trying to turn xbox on and getting blinking red ring around power button
If you are having three red lights flashing around the power button with upper right corner not flashing, it means that your Xbox 360 is having a general hardware failure. This is caused by the internal components of the console experiencing a malfunction. You can contact Microsoft Xbox Support for it to be repaired.
May 10, 2010 | Microsoft Xbox 360 Console
What is wrong with my xbox it says error 65?
Error 65: DVD Drive Error.... DVD Timeout, Wrong firmware, dvd is without f/w chip, etc. This can also be caused by the tray not being fully closed on boot.
Flashing red:
1.the av cable cannot be detected
Make sure that the AV cable is correctly connected to the Xbox 360 console.
Disconnect the AV cable from the Xbox 360 console, and then reconnect the AV cable to the Xbox 360 console.
If the four flashing red lights continue to flash, try wiping the metal area of the AV pack with a dry cloth. The metal area is the end that plugs into the console. Wipe the metal area thoroughly, and then try the AV Pack again.
If the AV cable is correctly connected but the four red lights are still flashing, substitute a different AV cable if you have one available.
2.general hardware failure
Try restarting the console.
If restarting the console does not resolve the behavior, follow these steps:
Turn the console off.
Unplug all the power and AV cables from the console.
Unplug the power cord from the wall socket.
Firmly reconnect all the cables.
Turn on the console.
If these steps do not resolve the behavior, turn the console off, remove the hard drive, and then turn on the console. If the 3x Red LED error light is no longer displayed, turn the console off, re-attach the hard drive, and then turn on the console.
Also examine the lights on the power supply. When you turn on the console, the power supply light should illuminate green even if the three lights on the RoL flash red.
The specific type of hardware failure can be determined by a "hidden" error code
Turn the xbox 360 on, and wait till the 3 red lights are flashing.
Press and hold the sync up button (the small white one), while holding that button press the eject button.
The LEDs will now blink the first number in the code (as described below).
Release the eject button and press it again.
The LEDs will now blink the second number of the code.
The LEDs will now blink the third number of the code.
The LEDs will now blink the forth number of the code.
The LEDs will go back to the 3 red flashing lights.
You should be able to determine the difference between the 3 flashing lights and the error code lights by the rate in which they flash.
Here is how you interpret the LEDs to get the code number:
All four lights flashing - 0
One light flashing - 1
Two Lights flashing - 2
Three lights flashing - 3
0001 power supply problem
0002 Network Interface problem
0003 Power problem could be the PSU could be the GPU/CPU, somehow the console isn't getting clean power from the power supply.
0010 over heating
0011 over heating - If you are receiving this error after disassembling your console make sure to all 8 of the heatsync screws are tightened securely to the board/heatsink holes.
0012 over heating
0013 over heating
0021 DVD Drive Time out - Can be caused by problems with a firmware flash. This is also speculated to sometime be caused by a problem with the southbridge chipset on the motherboard.
0022 GPU Error / GPU Overheating
Feb 08, 2010 | Microsoft Xbox Console
Help me
did you press the controller locator and the console locator at the same time?
Dec 20, 2009 | Microsoft Xbox 360 Controller
One flashing red light on xbox360 ( not red ring)
Once you get this code, go to: http://forums.xbox-scene.com/index.php?showtopic=484726
To get the reason for the code.
Sep 15, 2009 | Microsoft Xbox 360 Console
Xbox 360 freez crash problem unique
you should at least get the red lights of death. try holding in the sync button and press eject 4 times see if the lights change
Feb 24, 2009 | Microsoft Xbox 360 Console
I got three red rings and it wont read any discs
If you are experiencing this problem, you can submit a console-repair request online. However, before you submit your request, first try the following two steps to verify the problem:
  1. When you turn on the console, look at the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply light is not green, please follow the steps in one of the following Microsoft Knowledge Base articles: 906101 (http://support.microsoft.com/kb/906101/ ) Troubleshooting your Xbox 360 Power Supply when the light is red 906102 (http://support.microsoft.com/kb/906102/ ) Troubleshooting your Xbox 360 Power Supply when the light is orange 906103 (http://support.microsoft.com/kb/906103/ ) Troubleshooting your Xbox 360 Power Supply when the light is not illuminated
  2. Turn off the console. Wait 10 seconds, and then turn on the console again to see whether the problem re-occurs.
Additional support loadTOCNode(2, 'moreinformation'); If the steps in the previous section did not resolve your issue, your console may have to be repaired. For more information about how to start the online repair process, please visit one of the following Web Page links: United States customers - Online console repair (http://support.xbox.com/support/en/us/nxe/LiveIDSignIn.aspx? redirectUrl=http://support.xbox.com/support/en/us/nxe/registerdevice.aspx? step=repair) Outside the United States - Online console repair
Feb 03, 2009 | Microsoft Xbox 360 Console
Original xbox red ring of death
you have to take the xbox apart open the dvd/cd rome and clean the eye and the disk spinner then put it back together and it should work fine
Dec 28, 2008 | Microsoft Xbox Console
My xbox 360
Call Microsoft and send it back or go to www.llama.com to get the parts and instructions to fix it yourself.
Aug 22, 2008 | Microsoft Xbox 360 Console
When i turn on my xbox is flashs red and green
well your tray is stuk it happens i usually push the eject butten then push in the disk and if thet dosent work i sometime hit (not hard) right above the disk tray and for your other problem try checking all the plugs and if all are good then it is most likly the inside of your xbox if you lost your warenty then i would look it up on google and see if you can fix it your self or send it to some1 (or u can buy a new xbox prices today are cheap $150-220)
Sep 02, 2007 | Microsoft Xbox Console
Microsoft Xbox Console Logo
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
