Fn 5 does not function as it did
I own a Toshiba Satellite M60 series. I have used the Fn 5 function to display on other video devices. The last time I went to use it the three options I usually have were not there. I now only have LCD as an option.
Help if you can.
Eugene Decaire
  • 77 Answers
The alternative monitors/displays or TV must be properly connected BEFORE the laptop provides the option to use the external devices. Be sure you are connected with the proper cable and the cable is good.
Posted on Feb 10, 2008
Toshiba m60-104 screen dark new screen new iverter
Have you tried an external monitor?
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If the display shows on the external monitor that proves your video card is ok and your lcd screen is the issue. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
If is shows on the external monitor, then you would have to question if the new screen and lcd inverter is bad. Just because they are new don't mean they work. Are you sure you purchased the lcd screen and inverter that is for your model?
May 23, 2012 | Toshiba Satellite M60 Notebook
The monitor on my Toshiba P25-S5093 does not have any display of any kind; all black. I have display using external monitor.
Does the display show anything before you enter windows? If yes, then press the key to transfer video back to your original screen once you enter windows. It should be the function key "Fn" + F5 - F8. looks for the icon which shows a monitor or says "CRT/LCD".
If it doesn't show anything before you enter windows I'm afraid your screen needs to be replaced. Good luck.
Mar 08, 2011 | Toshiba Satellite P25-S5093 Notebook
My fn function dosent display
im pretty sure it doesn't function on its own you need to use it in conjunction with the F-series of keys at the top of your keyboard-each one delivers a different function--different pc's--different sequence-different function
Sep 06, 2010 | Toshiba Satellite L305-S5933 Notebook
ï have a toshiba satellite do i set the bluetooth communication switch to on ?
Utilize the FN and one of the F keys that has the bluetooth logo on it simultaneosly. That usually turns it on and off.
Aug 08, 2010 | Toshiba Satellite M60 Notebook
When i plug in to s-video port on my toshiba m45-s169 laptop to my television it doesnt do i enable the port?
Change the display settings on the laptop to 800x600 - right click on the desktop > properties > advanced tab You will need to select TV out to enable that function use the FN key and the F5 key together and each time you press it will toggle through an output, not necessarily in this order
❖ Built-in display panel only ❖ Built-in display panel and external monitor simultaneously ❖ External monitor only ❖ Built-in display panel and external video device simultaneously (This should be SVideo TV out) ❖ Other external video device only (This should be SVideo TV out)
Press the FN key and the F5 key 4 times
On the TV you will need to select the TV input for the S-Video connector - This may be by selecting an Input AV1, AV2, AV3 etc - without the make and model of the TV I cannot say which to select
Here are some instructions on how to use S-Video - it covers a number of laptops including Toshiba
This is a link to the Toshiba support site for that laptop
Apr 02, 2010 | Toshiba Satellite M45-S169 Notebook
Toshiba satellite fn key display problem
Just download this :) It will fix your problem. If it doesn't work, just search for Toshiba Value Added Package Vista/XP (that depends on what Operative System you've got) and download for your Operative System.
Jul 23, 2009 | Toshiba Satellite A15-S127 Notebook
S-Video Out Port
for A100 series, you can hook up the tv on your toshiba laptop through VGA port on S-video. you need to hook up the tv while the laptop is turned off. toggle the display by simply holding down the Fn button followed by the F5 button. and you need to set the mode on the tv as S-video. or you can go to display settings and set the tv as the secondary monitor. you can extend the display or do cloning.
i hope this info helps you.
Sep 11, 2008 | Toshiba Satellite A100-S8111TD Notebook
Does not detect input source
Hi Figburg
Press the Fn ( function button ) and while holding it down , press the button in your F-row with the 1 or 2 screens on it.
Should do the trick.
May 03, 2008 | Toshiba TDP-S8 Multimedia Projector
I'm using a toshiba 4300 satellite pro 4300 series laptop, i don't know how to dim the screen. i've tried pressing Fn and various F keys to no avail. Please don't reply in computer language because i'
Hi. According to the user manual, the Fn + Esc (key)displays the screen brightness pop-up window which are: super bright; bright and semi bright. You may want to check out Toshiba 32-bit Online User's Guide for Satellite Pro 4300 Series (5790)at Hope this works out ok for you. Regards.
Apr 09, 2007 | Toshiba Axiom 60GB HDD Satellite Pro 4300,...
Computers & Internet Logo
224 people viewed this question
David Payne
David Payne
