Usb port overload
I have 4 ports on my laptop - I had 3 items plugged into the USB ports - when I added a 4th - POOF - nothing from any of them. I have tried to remove the drivers - reboot and "find new hardware" but that isn't working... what else can I do - or is there a "trick" in the previous I don't know about... THANKS
  • MomaRachel Dec 12, 2007
    Have I fried the USB ports? or is there some type of "overload protection" that causes it just to shut down when it is potentially overloaded that just needs "reset" or have I done that and now I HAVE to buy something to fix it?
  • 883 Answers
Difficult to diagnose...do not know of a "trick"...although one solution is to get a PCMCIA card (they are getting very inexpensive now) that has 2 USB ports...you can add a USB hub from one of them to again have 4 or more ports.
Posted on Dec 12, 2007
I kind of have the same problem. My desktop has eight USB ports, and at first they all worked fine, but now they're failing one by one. o.O Ack!
Posted on Nov 03, 2008
Did you try jumping the computer
Posted on May 11, 2008
Read replies at this site: www.oneafrikan.com/archives/2006/03/03/ibm-t42p-thinkpad-usb-ports-not-working/
Posted on Jan 12, 2008
USB ports are not charging on a PB5959
Overload has possibly damaged the motherboard. USB ports are not designed to charge heavy loads and are limited to less than 1Amp as a rule. They can run low power items or external powered hubs.
Jan 25, 2015 | Computers & Internet
USB port gives new message "unknown device"
hello allan213
my name is ausi.
is it on all usb ports only one of them if it is in only one of them then the message you getting generaly means one of thw follwng.
1- if it is in only one of the ports then try it with a different device as well to see if it is the actual port or not.
2- the device you have plugged in needs to have drivers installed. normally should have been supplied with it.
3- the device you plugging in is faulty and the system can not access it.
4- the system usb ports are overloaded. (too many usb devices connected simultaneously)
good luck
Jan 05, 2011 | Intel Motherboard
Acer USB Ports - Unknown Device - Will Run Mouse but not Printer
Sumtimez ports r damaged.somtimes not.. just chek other devices..if done..thn chek RAM!! lil chance tht u hv lost ur laptop!
Oct 12, 2009 | Acer Computers & Internet
Targus Travel USB 2.0 4-port Hub
sometimes usb hard drives will not work through a usb hub.
if the drive works connected to the laptop but not the hub then that's how you'll have to use it.
it's also possible the laptop cannot power both the hub AND the drive, in whaich case you'll need a powered hub (one you plug in to the mains).
Sep 21, 2009 | Targus PAUH217U 4-Port USB Hub
USB ports wont recognize anything I plug in
Are you using XP? If so:
Here is what you can do to refresh the USB ports:
1. Right click MY COMPUTER
2. Select PROPERTIES
3. Select HARDWARE
4. Select DEVICE MANAGER
5. Select UNIVERSAL SERIAL BUS CONTROLLERS
6. Right click on each USB CONTROLLER and select Uninstall
7. Uninstall all entries
8. Reboot your computer
9. As your computer re-boots it will reinstall all USB connections it detects
THEN, when all other USB items have been configured and connected by the system, you then should try connecting your USB device.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jun 02, 2009 | Acer Aspire 5100 Notebook
I added a 512mb stick to my ibm t30 think pad and one port is bad
You can plug a USB hub into the working USB port on the computer. The USB hub can have several ports so you can plug in several USB devices.
I suggest you get a powered USB hub because if all the devices that you plug into this hub exceeds 500mA then your computer's USB port will stop working because it could not supply enough current.
You will not need to plug in the power adapter into the hub if the device/s do not overload the computer's USB port.
Jan 08, 2009 | IBM ThinkPad T30 2366 Notebook
Usb ports quit working in gateway laptop
This article references a Dell computer but maybe it'll work for yours.
Jul 04, 2008 | Computers & Internet
Doesnt seem to work
Do you have your printer connected by a USB port? Do you have several USB items on your system? (Printer, mouse, keyboard, etc etc) It is possible that your USB ports are overloaded and cannot process the information. That's what the USB hubs are for - those little ports that you can get for as cheaply as five bucks some places, up to big bucks for the heavy duty ones.... you can plug up to four USB items into the hub, then only ONE USB plug goes into your processor.
I am really not sure if that is the problem for you, but worth a try. Also, it is possible that the USB port you have it in is wearing out - try another one if your machine has them available. They do die.... if it powers up, it is likely that the port isn't dead, so I am thinking that it is just too much for your machine to process, and it is ignoring all other requests to that port.
(PS - when the 1315 dies, it is not worth resuscitating! It isn't HP's finest moment, and was their earlier attempt at an all-in-one. I found it to be more hassles than it was worth!)
Apr 20, 2008 | HP PSC 1315 All-In-One InkJet Printer
Unresponsive usb ports
same thing going on with mine...sounds like hardware aka motherboard
Nov 25, 2007 | Compaq Presario Notebook
Open Questions:
Computers & Internet Logo
2,159 people viewed this question
Alun Cox
David Payne
David Payne
