Question about Compaq tc1100 Tablet PC
The AC adapter light does not come on when plugged in
The battery shows fully charged, the AC adapter light does not come on, and it will not power up.
  • arnieo Jan 03, 2008
    The solution came to me from an engineer that had the same problem. Simply remove the battery for a couple of minutes and then replace. tc1100 is working fine. Thanks to the engineer.
  • arnieo Feb 05, 2008
    Thanks for your confirmation.
This happened to me recently. I did as the engineer said and it worked.
Posted on Feb 03, 2008
  • tabletmaven Feb 03, 2008
    The tablet on screen keyboard does not work any longer and I have not been able to find the driver or a download from HP to re-install it. Does anybody out there know where I might find it? I tried the driver CD that came with the tablet to no avail. Help!!!!
HiSense Sero 7 tablet. Why no charge, no power?
About 1,620 results (0.80 seconds) Search Results
    HQRP USB to micro USB Cable / USB Charging Cable for ...
    www.amazon.com > ... > USB Cables
    Amazon.com, Inc.
    Rating: 2.9 - ‎22 reviews
    1A AC Wall Power Charger Adapter Cord for Hisense Sero 7 LT Lite E270BSA .... If you try to use the tablet while it is being charged, no charging will take place.
    HQRP AC Adapter / Battery Charger / micro USB Charging ...
    Amazon.com, Inc.
    Rating: 3.7 - ‎6 reviews
    HQRP USB to micro USB Cable / USB Charging Cable for Hisense Sero 7 LT E270BSA / Hisense... ... HQRP Micro-USB AC Adapter rapidly charges your Cell Phone / Tablet PC ... This one does not. ... Yes No Sending feedback. ... $3.91. 1A ACWall Power Charger Adapter Cord for Hisense Sero 7 LT Lite E270BSA Tablet.
    HQRP AC Adapter Dual microUSB Charging Cable for ...
    www.amazon.com/HQRP-Adapter-microUSB-Chargin...
    Amazon.com, Inc.HQRP AC Adapter Dual microUSB Charging Cable for Hisense Sero 7 LT E270BSA... Do not wait until charging one of your devices to charge the second.
Feb 09, 2016 | Tablets & eReaders
Why it Does not fully charge
Have you ever let it completely discharge. Let it go say to... 5%. This type batteries for lack of a better word have memory. You must let them completely discharge a couple of times before hooking it up to the charger. Also do you have the correct ac charger that the tablet requires such as how many volts and how many mah does the tablet ac adapter need to be. Last ditch effort, I know it sound odd but plug it into a different outlet.
Apr 06, 2015 | Amazon Kindle Fire HD 7 inch Tablet with...
Why wont my nookhd wont charge
If it\'s only two months old it may have a defective charging cable or adapter. If it\'s a new purchase and you can return it. To check to see if it might be the adapter and not the charging cable you have a few cheap ways to test this out.
General charging recommendations.
If you get power leave it on charge at least 3+ hours. This is the minimum time required if the battery is totally drained. If the Nook turns itself on during this process manually turn it off. The battery charges faster and more deeply if it\'s truely powered down. Charging more than 3 hours won\'t hurt it. In fact some manufacturers claim leaving thier products on charge for an additional hour after the charging light glows green is good as it leaves a slightly deeper charge on the battery. Also I believe leaving it alone for that hour allows it to cool the battery. Most manufacturers also recommend tottaly draining the battery at least once a month and then fully recharging it 1+ hours after charging light is green. They claim this helps the battery maintain a healthy charge and extends the battery life. Simply disconnect any charging cables, turn the unit on and just let it set. Don\'t touch it peroid just leave it alone until it turns off because the battery is totally drained. Then just plug it in and leave it. Only if the unit automatically turns itself on do you manually turn it back off.
Well that\'s about in in keeping the battery life and charge at its maximum.
If your AC power adapter has gone south there are only three ways to get around this. 1. Purchase a generic AC to USB adapter. 2. Purchase a genetic DC to USB adapter. Most of these can be cheaply purchased at most drug stores ect.. these days. You can even get DC to USB ones at dollar stores such as Dollar Tree. Good way to maintain your battery if your AC one goes south or you lose house current.
One other way to charge your battery is to plug the USB cable into your computer. Some manufacturers don\'t recommend this as this more often than not doesn\'t fully tank up your battery.
You can also get replacement charging cables at the same place you got the adapters. Places such as Walgreens, or CVS often have these at around five dollars a pop.
Apr 26, 2014 | NOOK HD 7 Tablet
Vibrating when charging every 5 seconds. Message says battery disconnected?
Clean connections at battery source. Check adapter and plug of adapter for power and clean terminal of adapter and where it plugs into unit also.
Sep 21, 2012 | Samsung Rugby Smart 4G AT&T
How do I charge the iPad battery.
USB hubs typically don't generate the 10 watts necessary to charge an iPad when it's connected to your computer. This basically means you can't use your laptop to recharge your iPad.
Apple recommends finding an AC outlet and using 10-watt power adapter that came with your iPad.
Jan 08, 2012 | Apple iPad2 WiFi 64GB
My kindle will not turn on
  1. Connect Kindle to a different outlet and/or USB port. If available, also try using a different USB cable or power adapter
  2. Verify the yellow charge light in the power switch at the base of the Kindle is on. When fully charged, the light will appear green.
  3. Restart Kindle by pressing Home > Menu > Settings > Menu and select "Restart." Is the charge light on?
  4. Is the charge light off? AC adapter needs to be replaced.
  5. Contact Amazon if under warranty if those steps don't work
Sep 05, 2011 | Amazon Kindle Wireless Reading Device
I have a HP Compaq tc4400 tablet pc. The battery light flashes 8 times then stops when I try to turn the pc on. I can't find anything in any of the documentation that tells what the problem is. The...
Sorry about this.
Have you tried charging your tab to full capacity first. You need to plug it into ac mains and leave for a few minutes to allow the battery get some charge on/in it.
Secondly, I am persuaded your tablet PC is windows OS (I stand to be corrected on this please).
Was the system board confirmed fully configured/operational with all drivers installed?
Aside of drained battery in need of charge or boost; suspected fault may have to do with getting your tab PC to initialize boot sequence.
Oct 10, 2017 | Compaq tc4400 Tablet PC
The power button doesnt start the laptop
Toshiba Satellite R15-S822 Tablet: Battery is charged and operational power supply (charging light is on) is plugged into power port on back side of laptop: Problem is sliding "power on" switch does not start laptop - no sign of any electrical activity...
Nov 04, 2009 | Toshiba Satellite R15-S822 Tablet PC
?how do I charge the battery
You use one of two methods
Method 1
1. Install the battery in its compartment.
2. Plug the AC adapter
The battery will start charging, and the status light for the battery will appear amber. The light will remain amber as long as the battery is not fully charged. When the cahrge is completed, the light will turn green.
Of course, if your are using your computer while battery is being charged, it will take three to four times longer to complete the charge.
Method 2
Toshiba sells battery chargers which you can use to charge a battery outside of the computer.
Hope it helps.
Aug 26, 2009 | Toshiba Tablets & eReaders
Compaq tc1100 Tablet PC Logo
533 people viewed this question
Top Compaq Tablets & eReaders Experts
Vernon Taylor
tosin_christ
alibaba69
Are you a Compaq Tablet and eReader Expert? Answer questions, earn points and help others
