1. Did you remove the inner top of the toner bottle? The clear one. That will create a mess. Only remove the black cap.
2. The seal between the toner hopper and the top of the photoconductor unit has been damaged. Need to replace or fix this. You can see the seal around the hole in the pcu when you pull the toner hopper out.
3. The claws in the toner hopper that grab the top of the toner bottle are bound up or the release mechanism (green handle area) is messed up. Clean if you can or replace worn parts.
4. If the copies are getting light, then the plastic 'scoopers' inside of the toner hopper are damaged. You will need to disassemble the receptacle the toner bottle fits into and repair the 'scoopers'. If they are still there, just glue them back on.
While taking test nr 6 I have noticed a colors displacement which sometimes is larger, sometimes is...
(More)
While taking test nr 6 I have noticed a colors displacement which sometimes is larger, sometimes is narrower, thus its dimensions are not constant.
Among the solutions I have resorted to were:
- ITB (which I cleaned);
- changed the reader unit afterwards;
- checked the mechaism responsible for the drums unit rotation.
None of the above solutions worked.
I would be extremely grateful for any hint or advice.
We have an old Konica 2330 copier system that is giving us a code 36-01. We are the Elks, so this...
(More)
We have an old Konica 2330 copier system that is giving us a code 36-01. We are the Elks, so this was donated to us, and we would like to repair it if possible and monetarily feasible. Please help.
error code 05701 on Oce 9600 The machine says optimizing and after churning away prints out a black...
(More)
error code 05701 on Oce 9600 The machine says optimizing and after churning away prints out a black copy
